Question about Maytag Neptune MDE5500AY Electric Dryer
My dryer will run but does not blow hot air, is it the element or thermostat?
  • Maytag Master
  • 3,053 Answers
Hello, angel I was trying to help you out here. I wasgoing back to some customers that asked questions in the past and it appearedthat no one answered them, so I thought I would take some of my personal timeto see if I can help. Here is a link to about everything you want to know aboutyour dryer, from repair to trouble shooting it. If you go to this link andclick around, I am sure you will find out so much about your dryer, you willknow more that the company that made it. Here Is the link for you to click onhttp://home.howstuffworks.com/how-to-repair-a-dryer.htmPlease if this helped you at all, if youcan find the time to rate my help and some kind words written would beappreciated for my free help , I would appreciate it. Here is also my direct link to my own pagesof other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks So Much, Mike http://beta.fixya.com/users/mc1bean
Posted on Oct 26, 2011
Kenmore elite electric dryer runs but then gets hot and then shuts off, replaced thermal fuse, dryer vent and tubing not plugged, dryer runs gets hot blows thermal fuse again.
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
GOD IS still GOOD !!!!
Apr 28, 2015 | Kenmore Dryers
How I can bring back hot blowing air to my ken more dryer,which is blowing cold air.
CHECK THE HEATING ELEMENT WITH A MULTI METER, CHECK THE THERMAL CUT OFF AND HI LIMIT THERMOSTATS LOCATED ON THE HEATER. AND LASTLY ARE U GETTING A FULL 240 AT THE TERMINAL AND HOUSE OUTLET? IF NOT , U WILL HAVE ENOUGH TO RUN MOTOR BUT NOT HEATER
Feb 25, 2015 | Dryers
Replace fuse dryer model GEQ8821LLO
Hello;
My name is Peter. I am a retired field service appliance technician.
You never explained what the problem was. Dryer not running? No heat? Dryer shutting down. It could be as simple as cleaning out your dryer hot air distribution manifold. A dryer will not run if you do not have good air flow due to lint blockage. A dryer will not run if you have a bad door switch. You can Ohm components out with a multi-meter, setting the meter to the lowest Ohms (Omega Symbol). You should get a reading of "0" if the component is good.
1.) Dryer Door Switch - This switch replaces your dryer door's switch.
  • You may need to remove your dryer's lint screen and lint screen housing before lifting its top panel to reach its existing switch.
  • Be sure your dryer is unplugged during installation.
This Dryer Door Switch part #3406107 Cost $20.00
Dryer Door Switch - Unplug the dryer before replacing the door switch.
This Dryer Door Switch part #279782 Cost: $22.00
Thermal Cut-Off- This component is located on your heating element housing,. you may be able to access it at your hot air distribution manifold in the back of your unit.
  • When replacing your dryer's fuse, replace its thermostat, too. The thermostat should have prevented the dryer's existing fuse from blowing. The high-limit thermostat is functional to 250 degrees (Fahrenheit) and the thermal cut-off fuse to 360 degrees (Fahrenheit).
  • Install the fuse in your dryer's heater element housing box. Be sure your dryer is unplugged during installation
  • Part #: 3977394 Cost: $33.00
    25432459-jpgjqed1aonpcy4b0i04xdgb-5-9.jpg Cost: $34.00
    The high-limit thermostat replaces your dryer's thermostat.
    • The thermostat is functional to 250 degrees (Fahrenheit).
    • Install the thermostat in your dryer's heater element housing box. Be sure your dryer is unplugged during installation.
    This High-Limit Thermostat part #3390291
    Hot Air Distribution Manifold:
    This is in the back of your dryer and easily unbolted. If you are plugged up with lint your unit will shut down. Remove this component and clean the lower discharge end.
    25432459-jpgjqed1aonpcy4b0i04xdgb-5-14.jpg So, tell me what the problem is, and I will tell you how to fix it.
    Peter,
    Glen Burnie, Maryland, USA
    Feb 15, 2015 | Whirlpool Dryers
    I have a kenmore 110.87561601 dryer, it blows warm air but not hot, is this the norm for it?
    Check power at the outlet. If you're not getting the full 240v then it'll come out warm but not hot. Otherwise I would go with the timer.
    Oct 01, 2014 | Kenmore Dryers
    Dryer runs but not blowing hot air.
    It is either the thermal fuse but not likely because you wouldn't get power at all so most likely its the heating element.
    Mar 10, 2010 | Whirlpool LER4634J Electric Dryer
    Unit runs, blows regular unheated air. element looks good. got new element, unit still not blowing hot air.
    Most likely, it is the thermostat which controls the heating element. The Bios Thermostat will have two wires connected to a round disc which has a flange and screw holes to hold it next to the blower vent or the center of the drum. Use an ohm meter to see if it is open or take it to an appliance parts store to have them check it for you. You may also see a thermal fuse and a high temperature cut-off thermostat which should not read open with an ohm meter. Any open thermostat will prevent the heater element from turning on.
    Feb 19, 2010 | Dryers
    Dryer runs but will not heat. Replaced fuse and
    your cycling thermostat needs changed too. the thermal fuse is your last safety measure that goes, which means your cycling thermostat is not shutting down the heat element once it detects the right temp hot air in the blower housing so it let the heat element glow until either the high-limit sensor shuts the heat down or the thermal fuse blows. Change the cycling thermostat and good luck
    Mar 06, 2009 | Whirlpool LER4634J Electric Dryer
    Maytag dryer not blowing hot air (2yrs old)
    If the vent is blocked, it will not stop the heat, it will only restrict the air flow.
    Generally a couple of things can cause the heat to stop.
    Either the thermostat or the element.
    I would first suggest the element.
    It may be fatigued therefore the internal wire within the element becomes fragile and eventually breaks down. Although it is an electrical item, it is mechanically built and can fail.
    In some dryers the element is held in clips.
    These clips can cut into the element.
    The thermostat maintains temeperature but again, it is mechanically built and can also break down.
    If you are not capable of inspecting or troubleshooting the internals of the dryer (i.e remove the cover and look for the failurer), then have it inspected by a repairman. There is not too much that can go wrong with a dryer. The most expensive part wuld be the motor that spins the drum.
    Sep 16, 2008 | Dryers
    Wont blow hot air
    check that you have 240 volts to the dryer terminal block
    if so check the element and the element thermastats
    May 07, 2008 | Estate EED4300SQ Dryer
    Dryer does not get hot
    pleas4e help my dryer is working but it won't get hot it just blows cold air please help me fix this problem
    Jul 20, 2007 | LG DLE0332 Gas Dryer
    Maytag Neptune MDE5500AY Electric Dryer Logo
    Top Maytag Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Are you a Maytag Dryer Expert? Answer questions, earn points and help others
