Question about Garden
Losses revs when under cutting pressure - Garden
You need to get your mixtures right. It is probably running to lean. wind your low mixture screws in counting every half turn as you go so you can remember the factory settings (ex. L 1 & quarter turns, H 1 & half turns). Then wind them back out, winding the low mixture out a lil further (eigth of a turn) while running, rev it a bit, try a cut with it, then wind the High mixture screw out a bit if it hasnt improved. You will eventually stumble on the right mixture for the weather conditions.
Posted on Nov 06, 2010
Engine cuts out (sometimes) when accelerating from, eg, a stop street, traffic lights, then will start again straight away
I would suggest a fuel pressure test. It sounds like you may have a clogged fuel filter or a fuel pump that is not maintaining adequate pressure under load. Obviously the fuel filter is the simplest and quickest place to start and might be best to change before doing the pressure test. Good luck.
Nov 07, 2015 | Cars & Trucks
Idles but losses power
Fuel pump not giving enough pressure out of idle...seeing that you have changed the carb....you are having a fuel air ratio problem. Check carb again and then check your fuel pump.
Dec 03, 2013 | 1983 Ford F150
1993 dodge spirit losses rpms and power in passing gear
Lack of fuel maybe? When was the last time the fuel filter was changed?
Nov 12, 2011 | Cars & Trucks
14tdi, Turbo boost up to 3000 rpm , cuts out and
my 1.9 polo dti revs to 3000 then losses all power and starts to smoke
Jan 23, 2010 | 2001 Volkswagen Jetta TDI
2001 blaster losses power under a load.
check the compression and if thats good, remove the air filter and try to start. or possible air fuel jet needs adjusting.
May 06, 2009 | Yamaha YZ 250 Motorcycles
98 gsxr cuts out around eight g when accelerating but fine in N
Sounds like you're running out of fuel. It doesn't take much power (ie, fuel) to rev it in neutral, which might explain why it does that fine but falls over under load. Checked your fuel pressure/pump/filter?
Apr 15, 2009 | 1998 Suzuki GSX-R 750 W
Renault Scenic Missing and cutting out
could be spark plugs coils, we have had this various times
Apr 07, 2009 | 2004 Renault 181
2003 Nissan Sentra SE-R Spec V
I have the same car and I know there was a TSB for the ECM . I know the ECM issue has cause some cars to stall while driving
Jan 22, 2009 | 2002 Nissan Sentra
Gdi 1800 cedia wagon-odometer 80,000km exact, starting, no power
Hi it sounds like your high pressure pump needs replacing. the pump can be repaired but you will have to find someone who knows about it, i fix a lot of them before. there is a spring that pushes out the piston in the pump so it can compress the fuel that spring losses its ability to extract the piston back out. i have pictures of one if anyone wants to see
Jan 03, 2009 | 2002 Mitsubishi Lancer
Garden Logo
70 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
