Monitor does not work
I just bought a LG 1755S monitor, but when i connected in my pc, the lead indicated only "energysave" . I call LG assistence and they said to change in my BIOS the herts from 60 to 75 hz and and screen size to 1250 x 1440 pixels My mother board is a M825VXX and I cant find where to change this setup. Do you think that you can help ! tks in advance
    Champion:
  • 214 Answers
Hai there
follow the tips
Right click on the desktop(in a blank space)
select properties
In the display Properties dialog box click Settings tab. There u can change the Screen resolution to the required 1250x1440 it its availabe. It not, click the Advanced button.
In the dialog box shown, select Adapter tab.
Click on List all Modes button.
Here form the list select the resolution, Bit rate and frequency.
if you don't find the required resolution, u will have to install the driver for the Graphics Adapter of the motherboard. It is available in the motherboard CD.
Hope this will solve ur problem
good luck
Rabby
Posted on Jun 16, 2008
When I turn on my PC Windows starts fir 4 seconds then I see on flat monitor LG "Analog Power Saving Mode" and LG monitor goes off (yellow light on monitor panel). Please help.
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to fail to detect a hard drive continue on a cycle or to shutdown
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA and
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
problems
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Dec 11, 2010 | LG Computers & Internet
Monitor will not stay on
First of all check your mains lead make sure it is not fused. then check the lead from the monitor to the computer make sure it is connected ok then check your video card You can try connecting the monitor to another computer to see if it works on that one
May 01, 2010 | LG 22" FLATRON LCD Monitor
The green light indicating power is blinking on and off and nothing is showing up on the screen.
when the green light is flashing it means it's not getting a signal from the computer..
1. try toggling through available sources with the source button on the monitor.
2.check all cables leading from the pc to the monitor.
Apr 02, 2010 | LG Flatron L1718S LCD Monitor
LG screen goes in stand by. I was using two monitors for several months, everything OK, now I decided to get a new LG Flatron instead of one of the monitors... and only this one goes in safe mode!! Two...
oke having a similar problem atm, this is what i have found so far. was trying to help a friend who has bought the same 19" LG monitor. When i connected the monitor to her PC i noticed that it was not the same connection as the previous one but it had the smaller blue connection..this shouldnt be a problem but it was. The monitor when powered up, showed LG logo then went into power saving mode. My next step was to try the monitor on my own PC to make sure it was working, When i did this the monitor got a signal but on the initial boot it did say that this monitor was not compatible currently the way i had it set up ( where i had it plugged in? the only place it can be) because of my graphics card. oke so atleast i knew the monitor was working and was recieving a signal.
the only difference i can see is when i put it in her PC it is not giving me this information which also did give 3 steps to solving the problem but didnt seem legit. the next step i will take is to try my monitor on her PC although im not sure i expect it to work.
i think it must be a) PC is now faulty or b) PC is not sending a signal to the monitor ( possibly due to the fact it is not the same connection as before.)
what i have seen on other similar posts says you should also listen for your PC starting up normally.
another thing i would like to know i think it can be usefull for this topic. are the people who are experiencing this problem in the same situation as me i.e. changing the type of connection used by the monitor from the larger to the smaller type?
id also liek to note that the monitor i have was bought on a tight budget from PC world.
only other help i can give to people with this problem is that it is much easier to see where the fault is when you have 2 PC's and 2 monitors i know this is not viable for many but if atall possible interchanging parts with the PC that is working correctly and the one black screening can help you see exactly what the problem is,
as far as i know aswell the main reason for a monitor to sleep is that its simply not getting a signal from the PC BUT on rare occasions it can be a fault in the monitor. IF you have another monitor with the same connection that you can get yto work on the same PC its the monitor with the problem, if u have a monitor that u know is working on another PC with the same connection but is not working on the PC in questions its a PC fault.
sorry for the jumble of words in this answer i tryed my best to explain, all my knowledge of PCs is from friends and self tought so ... hope it helped
Feb 26, 2010 | LG 19" Widescreen Flat Panel LCD Monitor
My monitor comes on for a sec blue light then nothing. thought it was my computer took it to shop fix it told nothingwrong with comuter. So it must be the monitor.
could be monitor or lead. could also be the resolution of the graphics card. If the system was previously working with this monitor it won't be resolution and if a new lead doesn't work then it has to be a faulty monitor. play around with connections until you are sure as leads are cheap. you've had the pc checked on another monitor now try the monitor on another Pc if you can.
Jan 07, 2010 | LG L1915S 19" LCD Monitor
Speaker connection for LG W2053TX monitor
This model of monitor does not come with speakers. In fact very monitors have speakers. You will need separate speakers for sound. Some monitors do come with external speakers which hook onto the monitor at the sides but they are still connected to the PC via a lead with a 2.5mm stereo plug into the sound output..
Dec 12, 2009 | Computers & Internet
Out of the blue one day, monitor started displaying "anaolog power saving mode." This is a stand-alone computer which has never been hooked up to internet.Took tower unit to PC World to see if it was a...
you go to control panel starting your pc ,, then display settings,, from there,, screen saver tab, then make screen saver to none, and click on button power,, there you make everything to never,, and then see. it should work good
Sep 27, 2009 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Monitor not displaying any thing but green linght is on
Ok on that case your monitor is going bad and you just need to throw it out however if it is a new monitor then take it back to where you bought it and tell them what's going on. If you need anything else please let me know!
Apr 08, 2009 | LG Studioworks 77M Monitor
Connecting an LG TV to my PC
dear sir
i think u have screen resolution pro.
change your system resolution to 800x600 .reso.then restart .
i think your problem is solved
Mar 16, 2008 | Computers & Internet
Computers & Internet Logo
75 people viewed this question
David Payne
David Payne
