Question about Water Pik Hand Held Shower
I have little black pieces coming out of my water pipes that I filter out of everywhere except the WaterPik handheld shower. If I use the filter there, I get hardly any water coming out. So the little black pieces from my water pipes clog the holes in my shower head. How do I get rid of them. In other words, how do I take the showerhead apart to clean it from the inside?
  • 21 Answers
For starters check fo rotten washers get rid of black pieces take shower head some where to blow high presure air thru head good luck
Posted on Nov 06, 2010
Waterpik troubleshooting
Make sure the washer is setting inside the shower head properly. If you over tighten it you could crack the body of the shower head making it impossible to repair. Be careful. Remember you may need thread sealant too.
May 18, 2013 | Waterpik EcoFlow Watersense with...
Continuous flow through shower even when off
you probably have galvanized pipes still, each time you turn off the water bits of rust will break loose and travel throughout the system , which in turn clogs , or holds open valves,, what you need to do, ( or have someone do for you) remove those valves that have been effected, and clean them out( you can do this easily by just turning on the main slightly with the valve out ,, But be ready for a wet mess ,, do it quickly and for just a short burst,, you'll more than Likely see that the toilet fills slowly since they get clogged also
Aug 02, 2010 | Water Pik Waterpik& Elements& Handheld...
Replacement cord for dental irrigator
You did not specify, I hope you are talking about the TRS-559 or TRS-553. Both come with a lifetime warranty, go to waterpik.com or call 1-800-525-2774
Mar 14, 2009 | Water Pik Waterpik& Elements& Handheld...
Water pressure drops after a few seconds to almost nothing...
In the hand held shower head where the hose attaches to shower head. In the head there could be a flow restrictor. It may be rubber or plastic. In some cases you can remove it, or check if something is blocking it. Also try running the shower without the head on to see if there is some debris in the hose, and to check your water flow.
Jan 29, 2009 | Water Pik Waterpik& Elements& Handheld...
Hot and cold water in shower comes out in a triclkle
shut off the water from the main pipe.
use a allen screw driver take the handle off the shower control.
pull of the wall cover.
pull out the pin that stablized the cartridge in the control body. (remember how it is, before you take it out. or take a digital pic of it). pull out the cartridge. and bring it to any home center or plumbing store.
install in reverse.
Jan 04, 2009 | Water Pik Waterpik& Elements& Handheld...
I have one turn handle in the shower. When I turn it to the right for cold wter, the cold water comes out fine - good pressure. When I turn it to the left to get some hot water, the water goes down to a...
Alot of newer shower controls have a tempering valve on them. You need to open up the front of the unit (hopefully you have your owners manual and adjust the inner workings) this should solve your problem
Water Pik Hand Held Shower  Logo
320 people viewed this question
Top Water Pik Home Experts
Donni Steen
Are you a Water Pik Home Expert? Answer questions, earn points and help others
