Question about Vizio L37 Television
Vizio l37 screen blank but power light on. What can be the problem?
  • 11,361 Answers
It can be T-CON board, main board, 24vdc power supply, backlight inverter board. Please read below.
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there is some troubleshooting you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Please post back what you find.
Posted on Nov 06, 2010
Screen went blank no lights displayed unplugged waited plugged back in held power button down no results
The power supply module and the backlight inverter boards should be inspect and check for shorts, burnt parts, etc.
Please read my guide to understand how LCD TV works.
Aug 12, 2010 | Vizio L37 Television
37 inch vizio has black screen. the vizio display
L37HDTV10A THE TV ON NO VIDEO NO MENU SAON OKEY
Jan 16, 2010 | Vizio L37 Television
Tv wont blank screen
Try to unplug the power for a few minutes and plug it back in. If it still not work then the main board has gone bad. Replace the board will fix it.
Apr 22, 2009 | Vizio L37 Television
LCD controller board location on Vizio L37
Display controller is usually under the Main board which you remove to get access to it. Display controller connects to the suis-boards which then send signal to the screen of the TV.
Mar 17, 2009 | Vizio L37 Television
My Vizio L37 is on with no picture
Most likely a defective power supply module which can be repaired to component level. A local svc co. would be your best bet now.
Feb 26, 2009 | Vizio L37 Television
Vizio TV (L37) will power up but no picture
The backlight is powered by its own supply (although it may receive input from the main supply) and it sounds like the main supply or one of its outputs has failed disabling the video and sound processing.
Dec 24, 2008 | Vizio L37 Television
L37 tv turns off on own and then will not turn back on
I have same problem and i put in a new power supply and this did not solve problem. I will be changing out main board next and post results.
Jan 31, 2008 | Vizio L37 Television
Vizio L37
you probably changed the input mode.
Nov 10, 2007 | Vizio L37 Television
Vizio L37 Television Logo
90 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
