It's leaking on the floor as soon as we use it, so how do you stop the leaking
  • 1,711 Answers
You should check the drain hose it should be cogged
Posted on Nov 06, 2010
The roller stops as soon as machine turns on, then air leaks with poor suction. How do I fix it?
Hi there, it's Jack at Dyson.
I'm sorry to hear you're having difficulty with your DC39 Multi Floor, but from what you've described it sounds like your machine may have a blockage in the floor tool, wand, hose or inlet duct. This is simple to resolve by following each of the steps shown in our video guide:
If you continue to have issues with the suction performance or the brush bar in the Triggerhead floor tool after checking for and removing any obstructions, our experts are on hand to help you further. You can reach the Dyson Customer Helpline a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Apr 11, 2015 | Dyson DC39 Multi floor canister vacuum...
When I push on the break pedal oil comes out on the inside
from the Break pipe or cylinder ....... when all the liquid had leaked you will no longer have working breaks so stop driving the car and have it picked up and taken to garage asap
Mar 29, 2014 | Toyota Corolla Cars & Trucks
Magic Chef DU55CA-01 unit runs but when pump kicks on for discharge cyle water leaks on the floor from the what appears to be the solenoid part. The leaking stops as soon as the pump turns off. What part...
Leaking from drain valve shaft seal. If you just replace the seal it may still leak. Replacing the pump is a lot of work and not really worth it to cure a small leak.
Jan 24, 2010 | Magic Chef 24 in. DU6550 Built-in...
Freon leak
its a tipe of gas form it can make a mess somtimes but use sumthing ele than bleace and clorox
Dec 15, 2009 | Refrigerators
GE FRONT LOADER WASHER LEAKING WATER
inspect the door boot the rubber thing between the tub and door also inspect the hoses inside the machine you will see the leak
Aug 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Maytag LA212 Toploading Washer - leaks as soon as a load is started. Will continue to leak until washer is stopped. Not a small leak - there is a puddle two days later in the floor below it. Removed...
It appears that from that area the problem may be the water inlet valve or it's connections. See diagram https://www.searspartsdirect.com/model-number/LA212/3048/0153000.html?searchType=modelSearch&q=LA212&searchTerm=LA212
Nov 02, 2017 | Maytag Washing Machines
Heating & Cooling Logo
29 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
john h
