Question about GE Profile Prodigy WPSE4270A
I have a ge profile prodigy washing machine .The problem is when it goes into a spin cycle the machine starts to surge and the lights dim on and off.
3 Suggested Answers
  • 151 Answers
SOURCE: GE Prodigy Washing machine making clunking noise
One common problem area is the clutch assembly. The clutch is built on top of the motor, the motor drives the clutch and the clutch assembly drives the rest of the washer. The clutch gets very noisy when parts inside are worn out. The shoes lining that drives the inner drum of the clutch wear off and you will get a metal on metal sound. Clutches often can be rebuilt, but sometimes they are too worn and replacing the whole clutch is the best repair. Please use this link here for clutch replace and repair info. The belt and pump may be the next items to check for noises. How to access the washer. Clutch repair help.
Posted on May 03, 2009
Fix it Matt
  • 14 Answers
SOURCE: ge profile prodigy make clunking before spin cycle
Is there a humming sound? Check you have the hot and cold water supply turned on. Check the water inlet hoses are not kinked.
GE profile top loader, agitator and spin start and stop
Is this a newer model washer? I have one of the newer models and it does the same thing. It is supposed to do that.
May 23, 2017 | GE Profile Prodigy WPSE4200A
I have a GE Profile Prodigy top load washing machine. Sometimes the spin cycle does not spin, sometimes it spins. It makes a clicking noise during gentle cycle
The gears maybe going out. Sometimes it is able to engage in the other direction which the spin, sometimes not. Washing machine have complex gears that in one way agitator works, and the other the gear locks to turn the whole tub. The clicking noise is probably the locking mechanism in the gears that has caused the whole intermittent problem.
Jul 01, 2009 | GE Profile Prodigy WPSE4200A
May 03, 2009 | GE Washing Machines
Ge profile prodigy make clunking before spin cycle
May 03, 2009 | GE Profile Prodigy WPSE4200A
GE Profile Prodigy filled with water & won't start
If you don't hear a click when you close the lid, replace the lid switch.
Jan 29, 2008 | GE Profile Prodigy WPSE4200A
Spin and Agitate problem on GE Profile Prodigy WPSE4200A
This machine uses an electric water pump. I would check to motor. Remove the front panel and operate the machine to see if the motor is working. Check this by listening to the motor and watching the belt. If you hear the motor but the belt does'nt move then there may be a problem with the pulley or motor clutch assy.
As far as not draining or pumping water ? Check the wiring from the pump to the control panel. If these wires are alright then i suspect the pump.
Nov 15, 2007 | GE Profile Prodigy WPSE4200A
Lights but no action
Sounds like a faulty control board. This board controls ALL functions of this machine. This can be a major expense for the age of the machine.
Nov 09, 2007 | GE Profile Prodigy WPSE4200A
WASHER JAMS UP
from the description it sounds like the motor might be getting weak or something is getting caught underneath does it make any funny noises. let me know
Nov 05, 2007 | GE Profile Prodigy WPSE4200A
Washing Machine will not spin
Possible your outlet filter is blocked. This requires cleaning depending on your usage. Clean this out and refit. Good luck. Plug off the wall first.
Jun 11, 2007 | GE Profile Prodigy WPSE4200A
Will not drain during spin???
Most likely your outlet filter of the machine is choked with dirt or something; clean out the filter & refit. Of course after taking of the wall plug & siphoning out the water from washer.
Sep 21, 2006 | GE Profile Prodigy WPSE4200A
Washing Machines Logo
65 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
