Question about Cyberhome CH-DVD 300 DVD Player
No Video Hello, I recently moved. In trying to reconnect my CH-DVD 300 with a Sharp VCR, which is then connected to my tv (tv is old and the only way to connect it is through the video cable at the back of it and the one on the VCR). This used to work. Now I am getting no video - just audio. I tried turning off and then on the DVD player, and then pressing the stop button for 20 seconds, as suggested in a previous thread. This, sadly, does not work. Any help is appreciated. MJ
  • shoresm Jun 14, 2008
    My apologies. I connected to a Sharp VHS. The VHS appears to be working. I did tighten all connections and even changed them out. Any other ideas are welcome.
    Thanks for your prompt response.
Hey i dont have a solution but i have the same problem. what are the "connections" and how do i tighten them or change them out?
Posted on Mar 21, 2010
  • 29 Answers
Try changing the channel on the vcr, tighten connections and changing them out. Make sure the vcr is operating by putting a tape in. Basically you have to isolate the problem.
Posted on Jun 14, 2008
  • Christa Dening
    Christa Dening Jun 14, 2008
    Call your manufacture for help. Tell them what you did. You may need service, have your model number and serial number ready.
How to use the video source to watch a movie when i have time warner cable service
are you talking about VCR / DVD or DVR source. for VCR or DVD your connection shall be for VCR, cable out from the TW box to VCR in and VCR out to TV (VCR ch selector and TV must be set to ch 3)......... DVD connection out from DVD to TV's yellow/white/red (digital in on TV), to view dvd using remote change source to the digital source (av1 or av2)... for the DVR you must call TW to make sure your box is set up to record and view....
May 07, 2011 | Televison & Video
Hook up to view dvd's to tv video cables with yellow white and red plug ins.
Hello, here is a sample for auxilary connection for the chdvd300: . Use the AV (Audio/Video) cable
provided to connect the DVD player to
your TV as shown in the diagram.
. Your TV must be equipped with AV
inputs like those pictured to the right in
order to connect this unit.
. If your TV does not have AV inputs, you
will need a RF Modulator to connect this
player to your TV's antenna/cable input.
RF Modulators are available at major
electronics retailers.
Connect the DVD Player to
your TV
CH-DVD 300 Quick Setup Guide
. The goal is to see the DVD player's splash screen on your
TV. To do this, select the Video Input channel on your TV
that corresponds with the input the player is plugged into.
This procedure differs among TVs, but is normally done by
pressing the VIDEO IN or INPUT button on the TV's remote
control to select the Video Input.
. When the DVD player's splash screen appears on your TV,
you're ready to go!
4 Select the VIDEO INPUT on your TV
TM
Pr/Cr
PROGRESSIVE SCAN
COMPONENT VIDEO OUT
Y Pb/Cb
VIDEO
S-VIDEO
L
R
COAXIAL
TV
ANTENNA / CABLE IN
CH-DVD 300
VIDEO R - AUDIO - L
. Plug the DVD player's electrical
plug into a wall socket or power
strip.
2 Plug-in the Power Cord
3 Turn on the DVD Player and your TV
. Press the POWER BUTTON on the front panel to turn the
DVD player on. The POWER LED should now change
from RED (STANDBY MODE) to GREEN (ON).
POWER LED
You can find an quick install wiring schematic at retrevo.com, just type your model number in the search window.
Aug 11, 2010 | Cyberhome CH-DVD 300 DVD Player
I recently installed a Comcast digital adapter to my SONY RDR-VX515 DVD Recorder/VCR Combo and then onto the TV. Now, when I try to program the VCR to record, the only channel options are Ch 4, Line 1 and...
Hi and welcome to FixYa
Initially, postback the model number of the Comcast digital adapter and the TV.
Offhand, if the Comcast digital adapter is connected to the Sony through a coaxial patchcord, then the Sony would really have to be set to Ch 4 (or 3). Channel selection is done on the Comcast digital adapter. It is not possible to record one channel while viewing another.
Good luck and thank you for asking FixYa
May 22, 2010 | Sony RDR-VX515 DVD Recorder/VCR
When I try to play a DVD or VHS on my GO Video DVD/VCR Combo machine, I get audio but no video & the TV (Sanyo 37" HD) says "No Input". I've checked connections, the TV has multiple video inputs but I...
  1. I found the problem - on the back of the VCR/DVD unit there are 3 outputs: L (Wht) & R (Red) Audio + Yellow Video out. The cable from it to the TV was labeled Red/Audio,White/Video, and was connected to the R & W outs, but actually the Wht should have been connected to the Yellow Video out. There is so little space in the TV cabinet/stand that even though I turned the unit around to see the connections, I couldn't see the other (Yellow - Video) out until I pulled the cables out. It's working fine now - I'm not sure how things got connected wrong, since it was working OK before - possibly when I signed up for AT&T U-Verse & the installers moved things around. I'm very happy with that service, by the way - better than Comcast & cheaper, and didn't mean to imply the connection problem was their fault. I may have moved things around in the new cabinet & not realized I hooked up to the wrong outs...
Jan 03, 2010 | GoVideo Go Video DVD/VCR Combo
CONNECTION??
red goes to red, yellow goes to yellow, and white goes to white.
Jun 24, 2009 | Cyberhome CH-DVD 300 DVD Player
How do i connect my dvd player to my dish cabel box
what conection do you want? Adio/Video? Conect to amplifier? Conection to tv... Look the word Video out from dvd and put it on Video input of your tv same proceedure of the audio.
Apr 13, 2008 | Cyberhome CH-DVD 300 DVD Player
Macrovision
This sounds like a compatability issue.
If you buy a new DVD, you gotta buy a new T/V to go with it.
Alternatively, you could try a scart box and cable through that.
Or try outputting through the antenna via coax, see if any of these resolve your problems.
Regards Mike @ Compurepair.
Feb 22, 2008 | Televison & Video
Cyberhome CH-DVD 300 DVD Player Logo
48 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
