Question about Dell Inspirion Mini 884116022442 Notebook
My Mini 10 arrived as I left for vacation. I used it after clearing off my desk when I got back and found that sometimes the unit, not the speakers, emits a crackling noise. After 4 lengthy chats and 2 repair visits in whick corporate replaced the speakers (1rst time) and found nothing wrong (2nd time) I asked for a return ticket and got turned down. When does this happen? The worst way, inconsistently. Sometimes I use it for an hour or 2 and sometimes during startup. Where does the sound occur? Not the speakers but internally. HELP? This is my 7th or 8th Dell unit and I am really frustrated. Yes it is still under warranty.
SOURCE: No Sound! HELP ME PLEASE!...Dell laptop Inspiron-SigmaTel Audio, running XP
Joey, Be sure to use the Dell website to search for your problem. "B130 no audio device found?" or whatever the message is. Had exactly the same problem and it was do to a switch turned off, I think in the Computer Administration folder. I cannot rember what itwas, but I believe you can find the answer. There are 266 Search Results for B130 no sound device search on the Dell community site.
Posted on May 23, 2008
  • 3940 Answers
SOURCE: sound is working but internal speaker is not working
Connecting headphones to the system will disabled the internal speakers until the headphone jack is disconnected, at which such time the internal speakers should function again.
If you disconnect the headphones and the internal speakers are not re-activated, then there may be damaged to the microswitch in the jack. (Try rebooting after the headphones are disconnected too)
Posted on Mar 02, 2009
foxyreign
  • 52 Answers
SOURCE: dell inspiron 1525 notebook will not start windows
Usually this happens when the vista boot loader fails. During boot up, keep tapping F8 and then select Disable Automatic Restart... and get the stop error code which usually starts with 0x
Posted on Jun 10, 2009
  • 110 Answers
SOURCE: Problem in internal speakers in dell inspiron 1440
Probably just a software setting...many different things in software could cause this.... OS, driver, something... but could be bad speakers.
Try external speakers in the headphone jack.. if they work fine, then probably bad internal speakers.
Software is the most likely culprit.
Posted on Sep 08, 2009
buffalonyman
  • 1865 Answers
SOURCE: Battery won't charge (Dell mini 9 Linux).
The software has nothing to do with the charging system. There was a recall on some batteries, and that may be why they issued replacements.
Posted on Sep 13, 2009
KARA ILCO FRONT DESK UNIT 780 SAYS READER ERROR OR INVALID CARD, CAN THIS BE CLEARED BY RESETTING?
We have 2 front desk units Kaba ilco 780A1, one of - Fixya
www.fixya.com/.../t4588452-2_front_desk_units_kaba_ilco_780a1_one
Apr 19, 2010 - Question about Simplex Kaba Ilco Unican 1000 keyless lock ... the grand master authorization card is swap it shows a message that says ''reader error or invalid keycard''. .... How to reset grand master keys front desk unit 780.
Hotel Lock - Front Desk Unit - Kaba
www.kaba.co.uk/68244/front-desk-unit.html
Kaba GroupMulti-track keycard encoding and reading; Drop and swipe reader track with ... Front Desk Unit brochures can be found on the Sales and Support page.
Dec 25, 2015 | Locks & Locksmithing
Mini fridge doesn't get cold anymore
Is the unit running? If so then,
by shutting the unit down for a long period may have exposed a pinhole leak of refrigerant at an external brazing point. or you may have caused an issue in cleaning it This is something that would require a licensed technician to resolve.
Oct 15, 2017 | Emerson Refrigerators
Jag 2005 diesel 2.0 where is the fuse front right headlight
found this, hope it helps!
X-Type Fuse/Relay identificationpicture.php?albumid=77&pictureid=795
picture.php?albumid=77&pictureid=796
Engine compartment fuse box - fuses
Fuse Fuse Rating Colour Circuit
No. Type (amps)
F1 Cartridge 20 Blue Dip beam, High Intensity Discharge (HID) light relay.
F2 Cartridge 50 Red Ignition relay feed.
F3 Cartridge 60 Yellow ABS.
F4 Cartridge 30 Pink Rear window heater/heated mirrors relay.
F5 Cartridge 30 Pink Automatic transmission control module relay.
F6 Cartridge 30 Pink Heater blower relay.
F7 Cartridge 50 Red Power supply to passenger compartment fuse box.
F8 Cartridge 80 Black Blower module.
F9 Cartridge 50 Red Engine management system power relay.
F10 Cartridge 20 Blue Headlight power wash pump relay.
F11 Mini Not used.
F12 Mini Not used.
F13 Mini 30 Green Heated front screen right-hand side.
F14 Mini Not used.
F15 Mini 30 Green Heated front screen left-hand side.
F16 Mini 20 Yellow Left-hand dip beam, day time running lights, autolights.
F17 Mini 20 Yellow Right-hand dip beam, HID lights.
F18 Mini 20 Yellow Throttle motor supply.
F19 Mini 15 Blue Screenwash pump, rain sensing system.
F20 Mini 5 Tan Navigation display.
F21 Mini 15 Blue Side (Parking) lights.
F22 Mini 20 Yellow Accessories relay.
F23 Mini 10 Red Air conditioning compressor clutch.
F24 Mini 15 Blue Door lock power.
F25 Mini 15 Blue Direction indicators (GEM).
F26 Mini 15 Blue Horns.
F27 Mini 10 Red Automatic transmission control module, transit relay.
F28 Mini 15 Blue Ignition switch.
F29 Mini 30 Green Starter motor solenoid.
F30 Mini 30 Green Accessory sockets.
F31 Mini 10 Red Engine management relay coil.
F32 Mini 5 Tan Engine management control.
F33 Not used.
F34 Diode D3 Not used.
F35 Diode D2 Engine management control relay diode.
F36 Mini 10 Red Canister purge valve, airflow meter, throttle motor relay, power wash relay, air conditioning relay.
F37 Mini 15 Blue Engine management system, blower speed controller, road speed sensor (if fitted).
F38 Mini 30 Green Oxygen sensor heaters A.
F39 Mini 5 Tan Variable intake valves.
F40 Mini 15 Blue Automatic transmission control module.
F41 Mini 10 Red Injectors.
F42 Mini 30 Green Oxygen sensor heaters B.
Passenger compartment fuse box - fuses
No. Type (amps)
F60 Mini 20 Yellow Power windows left-hand.
F61 Mini 20 Yellow Power windows right-hand.
F62 Mini 7.5 Brown Rear fog lights.
F63 Mini 7.5 Brown Right-hand - front side light, side markers, rear tail lights.
F64 Mini 7.5 Brown Left-hand - front side light, side markers, rear tail lights.
F65 Mini Not used.
F66 Mini 30 Green Left-hand power seat switches, heater module, lumbar pump.
F67 Mini 5 Tan Battery back-up sounder, transit relay, HID/dip relay, automatic transmission control module.
F68 Mini 15 Blue Cigar lighter.
F69 Mini 7.5 Brown Telematics display, In-car entertainment head unit, antenna module, navigation module, VICS (Japan), parking aid, amplifier premium 1 system, phone handset, phone power supply module, instrument cluster, PATS module.
F70 Mini 30 Green Right-hand power seat switches, heater module, lumbar pump.
F71 Mini 15 Blue VICS (Japan), telephone transceiver, telephone handset.
F72 Mini 15 Blue Radio head unit, CD player, navigation electronic control module, Jaguar diagnostic connector/OBDII connector.
F73 Mini 15 Blue Sunroof unit/module.
F74 Mini 15 Blue Instrument cluster, Premium ICE amplifier unit.
F75 Mini 7.5 Brown Mirror fold back module, battery back-up sounder, air conditioning ECU.
F76 Mini Not used.
F77 Mini 7.5 Brown Left-hand and right-hand heated seats modules.
F78 Mini 5 Tan Phone power supply.
F79 Mini 10 Red Automatic transmission only: Reverse lights, reverse light switch, reverse park aid, electrochromic mirror, instrument cluster.
F80 Mini 7.5 Brown Park interlock, heater switch, OBDII, blower relay.
F81 Mini 20 Yellow Fuel pump control module.
F82 Mini 10 Red Variable power steering, alternator.
Manual transmission only: Reverse lights, reverse light switch reverse park aid, electrochromic mirror, instrument cluster.
F83 Mini 15 Blue Not used.
F84 Mini 5 Tan Instrument cluster, passenger airbag fascia light, seat weight sensor.
F85 Mini 7.5 Brown Right-hand high beam light.
F86 Mini 7.5 Brown Left-hand high beam light.
F87 Mini 15 Blue Front fog lights, master light switch.
F88 Mini Not used.
F89 Mini Not used.
F90 Mini 7.5 Brown Stop lights, cruise control.
F91 Mini 10 Red Sunroof, electrochromic mirror, power windows, power mirrors.
F92 Mini 10 Red Manual transmission cruise control clutch switch, ignition coils, automatic transmission rotary switch.
F93 Mini 30 Green Windscreen wipers.
F94 Mini 20 Yellow HID module.
F95 Mini 10 Red Airbag restraints module.
F96 Mini 7.5 Brown ABS module.
F97 Mini 7.5 Brown Glove compartment light, instrument cluster lights, licence plate lights.
F98 Mini 10 Red Mirror heaters.
F99 Mini 10 Red Luggage compartment light, footwell lights, puddle lights, vanity mirror lights, interior lights, aircon control unit, roof console unit.__________________
02 X-type 3.0l
04 S-type 3.0l
07 X-type 3.0l
Apr 05, 2012 | 2004 Jaguar X-Type
Need to know on a 2003 Jaguar X Type what fuse goes to the Fuel pump? The fuse box cover only lists the fuses by number.
The fuse box in the passenger compartment has the fuse you want, it is the F81 Mini 20 Yellow Fuel pump control module other fuses in that compartment are.
F63 Mini 7.5 Brown Right-hand - front side light, side markers, rear lights
F65 Mini Not used.
F72 Mini 15 Blue Radio head unit, CD player, navigation electronic control module, diagnostic connector/OBDII connector.
F76 Mini Not used.
F87 Mini 15 Blue Front Fogs master light switch.
F88 Mini Not used.
F89 Mini Not used.
Jan 07, 2011 | 2003 Jaguar X-Type
Doesn't hold left margin it will make a noise and margin moves over, sometimes to the far left and sometimes to the right to the middle of the carriage.
Try doing a comlete clear to see if it helps....this will clear all memory.!
Switch the unit Off...then while holding down the margin release key switch the power backON.
The machine will begin printing lines of a pre-programmed test page.
Switch the unit back OFF.
Wait 5~10 seconds and switch the unit back on. At this stage the unit is back to factory defaults.
The only other thing to try is to check the silver shaft the carriage slides across on....make sure it is clean, and lubricate the shaft with a lightweight oil.
Oct 14, 2009 | Olympia Supertype 330 Typewriter
When on vacation you can't go anywhere
are you using windows xp or vista on vista this happens
Jun 07, 2009 | Electronic Arts The Sims 2: Bon Voyage
BassCube 12 Startup Problem
same here. happened after moving residences
Jun 30, 2008 | Cambridge Soundworks BassCube 12 Speaker
No sound from main left and right speakers
no, the yamaha system would shut down if the amplifiers had a problem. I would check the bose system, try directly hooking the speakers to the mains in stead of thru the bose system if you can. the easy way to check the amps is to plug in a set of head phone in they are directly tied to the mains.
Mar 23, 2008 | Yamaha RX-V2092
Dell Inspirion Mini 884116022442 Notebook Logo
Alun Cox
