Question about Mtd 22" Yard Machine Push Mower
How much oil does the sump require in a talon AM3050 lawn mower? Can't find my manual
    President:
  • 1,140 Answers
It's very difficult to find information for this specific mower, however, most petrol mowers have a reservoir size of 1 pint / 0.5 litre. You should have a dipstick for checking the oil level anyway.
Basically, I suggest you drain the sump and add 0.5 litres of oil to ensure that the machine is neither low on oil or overfilled. Then call/email the manufacturer on Monday for clarification and/or a new manual.
Talon Tools contact:
tel: 1300 804 213
customerservice@husqvarna.com.au
Regards,
BElectric
Posted on Nov 06, 2010
Hello, I have a talon mower model no. am3050. I went to use it today but cord won't pull out to start. what could this be ? thank you.
Sounds like the starter dogs may be out of place so it can't engage into the starter like it should. And if the cord won't come out then it could be pinched between the starter cup and the pully.
Oct 20, 2017 | Garden
What type of fuel do I in use in a Maxicatch 400ST Lawn Mower Serial number 1509924
if it is a 4 stroke then regular unleaded is good
make sure that there is oil in the sump
the fuel type is in the owners manual
Sep 19, 2015 | Garden
Oil leak on deck of Lawn Mower
Because you mentioned the smoke and hard to start it could be that the engine is flooding or overfilled. Check for fuel in the crankcase. Be sure cranckcase is not overfilled. An engine with too much oil will force excess oil out somewhere. If the mower has been turned on its side lately it could have put oil in places that it should not be and its trying to burn off this oil. Be sure your air filter is not saturated with oil or fuel.
If all that checks out we will look for oil leaks.
As far as oil leaks go the three most likely places for your engine to leak are from the head gasket, dipstick tube seal, or the sump gasket.
Check for proper torque on the head bolts ( 125 inch pounds). Headbolts can come loose over time. After that check that the seal at the bottom of the dipstick tube is in good shape and a tight fit. This seal usually leaks when the engine is running because at rest the oil level is just below this seal. Lastly, if everything else checks out then the sump gasket is leaking. To replace the sump gasket drain oil from motor and remove air filter. remove blade and self propel belt. remove engine stop cable. remove the three motor mount bolts from under deck and remove motor. place on work bench upside down. some fuel may run out carb or tank cap. remove sump bolts from bottom of motor and remove sump. Do not remove governor gear or cam gear from cranckcase. At this time it will be obvious where the gasket has failed. Remove old gasket. It may need to be scraped off. Take care to keep material from going into crankcase and clean out any that does fall in. install new gasket and torque sump to proper specs and reassemble.
Jul 20, 2014 | Briggs & Stratton Garden
Do i put an oil/gas mixture in gas tank?
the 4 stroke engine only needs petrol in its tank . if your motor has a dipstick for oil it is a four stroke ,,only two strokes requires oil and petrol mix as they have no oil sump in their design
Jun 01, 2014 | Yard Machines 158cc Push Lawn Mower #11a...
Talon am3050
Does in lift off the post?
Nov 19, 2013 | Garden
Talon mower wont rev
may have to bend arm where governor spring goes
Jun 10, 2013 | Talon Rotary Lawn Mower
Talon lawnmower service manual
Try to Google the full model number with "service manual" or visit the maker's site.
Jun 15, 2012 | Garden
Drain sump oil
What kind of oil did they put in? The drain is on the lowest part of the engine, a small plug either in the block or at the end of a pipe, just find a container to fit under there and pull the plug, then fill it back up with the fresh oil. Don't forget the plug!
Feb 18, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
When i start the mower, smoke is coming from the vent on the side and a little oil splatter. I have checked the oil sump and it had enough oil. Can't find the manual.
hello
either to much oil in the engine or it as tipped over and ther is oil in the breather case the most common problem
Mar 15, 2009 | Garden
Mtd 22" Yard Machine Push Mower Logo
420 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
