Question about DeLonghi AR1070 Retro 1500 Watts Toaster Oven with Convection Cooking
Removing face of DeLonghi AR1070
I am trying to clean my DeLonghi AR1070 (just bought it at an estate sale and want to give it a complete cleaning) and would like to remove the face of the unit for a better clean. I have removed the screws, but the catch on the left is preventing me from completely removing the face of the oven. How can I unhook the catch to remove the face? Thank you!
  • kjeetsd Aug 09, 2008
    My toaster oven, which is about a year old has failed to work. Its "toast control", the middle knob became intermittent and shortly after became inoperative.
    Can I get a replacement and instruction for replacing it, In case it can be replaced?
This is a two slice Delonghi toaster, model CT12 and is has stopped heating on the right side
Posted on Jun 27, 2008
Fuse in Delonghi Toaster XU 20L must be out...looking for repair manuel or a solution from someone with experience Thank you Chuck Kinder
Use this address: http://www.delonghi-accessories.com/index.php?cPath=184_224 to go to a page with owner's manuals and you will find yours to download.
This address: http://www.delonghiusa.com/index.php?service will give you a page where you can search for a service center.
This address: http://www.delonghiusa.com/index.php?texts&pid=3 will give you contact info via e-mail, phone, or regular mail to DeLonghi for help.
Mar 28, 2011 | DeLonghi XU120 Alfredo 1500 Watts Toaster...
How to change the lower element on a delonghi AD 699 toaster oven?
  • Preheat ovens only when necessary. With conventional ovens, keep the preheating time to a minimum. Unless you're baking breads or pastries, you may not need to preheat the oven at all.
  • Food cooks more quickly and efficiently in ovens when air can circulate freely. Don't lay foils on racks. If possible, stagger pans on upper and lower racks to improve air flow.
  • Use glass or ceramic pans in ovens. You can turn down the temperature about 25°F and cook foods just as quickly.
  • Do not open the oven door often to preview the food. Each time you open the door the oven temperature drops by 25°F. Watch the clock or use a timer instead.
  • Full-size ovens are not very efficient for cooking small- to medium-sized meals, it generally pays to use toaster ovens or microwave ovens.
  • Check to be sure the oven door gasket is tight. Adjust or replace gaskets as required.
  • If you have a self-cleaning oven, consider using the self-cleaning feature immediately after regular baking when the oven is still hot. Less energy will be required to reach the cleaning temperature. Try not to use the self-cleaning feature too often.
  • Keep range-top burners and reflectors clean; they will reflect the heat better and save energy.
  • Match the size of the pan to the heating element; more heat will get to the pan and less will be lost to the surrounding air. A 6-inch pan on a 8-inch burner will waste over 40% of the energy.
  • On electric stove-tops, use only flat-bottomed pans that make full contact with the element. A warped or rounded pan will waste most of the heat.
  • When cooking with a gas range-top burner, use moderate flame settings to conserve gas. Also make sure the pilot light is burning efficiently, with a blue flame. A yellowish flame indicates an adjustment is needed because the gas is burning inefficiently.
  • Whenever possible, use a pressure cooker. By cooking food at a higher temperature and pressure, cooking time is reduced dramatically and energy use is cut by 50-75%.
  • Hope this work ..........
    Jul 07, 2010 | DeLonghi AD699 Airstream Digital 1500...
    How to clean the inside walls of a delonghi alfredo toaster oven?
    pour water in the pan with little detergent for dish,and heat it on 30 deg Celsius for about 30-50 minute,and wipe the walls with cotton rag.
    Jun 29, 2009 | DeLonghi XU620 Alfredo Ultima Bake 'N'...
    My delonghi toaster oven knobs broke! as
    Hi, you can purchase them on amazon. Here: Amazon com delonghi knobs. I think this was helpful, Have a nice day
    Jun 12, 2009 | DeLonghi EO1260 1400 Watts Toaster Oven...
    Delonghi AS690 toaster oven lower element won't turn on.
    Cactus Bob Is WRONG. I've had these replaced; and then, when it happened subsequently, bought the part and replaced it myself. You have to take the entire thing apart. but it can be done.
    Mar 13, 2009 | DeLonghi AS690 Airstream Stainless Steel...
    Delonghi toaser oven
    I need a Euro-Prox toster oven manual
    M# TO160L
    could you please help me.
    Aug 04, 2008 | DeLonghi AR1070 Retro 1500 Watts Toaster...
    Delonghi Toaster Oven Color Select Dial does not turn off
    This sounds like a defective timer switch that is not turning the oven off at the end of the time selected. You will need to replace the timer switch. The switches are available but unless you're able to do this kind of work you will need to take it to a repair shop. If you want to DIY you can find the switch at www.thegourmetdepotco.com or www.applianceparts.com. If you don't have a part # you will need the make and model # to get the correct switch.
    Jun 19, 2008 | DeLonghi EO1258 - Stainless Steel Toaster...
    Oven temperature
    Test and eventually replace the temperature probe. When the problem is not the temperature probe it is a faulty timer board.
    Nov 12, 2007 | DeLonghi AR1070 Retro 1500 Watts Toaster...
    DeLonghi AR1070 Retro 1500 Watts Toaster Oven with Convection Cooking Logo
    175 people viewed this question
    Top DeLonghi Toaster Ovens Experts
    Dave
    Dave
    Angel Joseph Jr.
    Angel Joseph Jr.
    Are you a DeLonghi Toaster Oven Expert? Answer questions, earn points and help others
