Question about Sharp Microwave Ovens
Our Sharp R-3A86 (corrected product ID#) microwave oven stops intermittently. The timer keeps counting down, the light stays on, but carousel stops, fan stops, and heating stops. Sometimes it works fine for a several minutes, then suddenly stops. A faint plucking sound happens when you it the "start" or "stop" buttons, but I don't know if that happens normally, as it's faint enough to be drowned out by the fan. Sometimes it will work for several minutes, other times for less than five seconds. I've tried leaving it unplugged for a while with not results. Any ideas? Thanks!
MicrowaveSvc
  • 9047 Answers
SOURCE: No Heat
This is probably due to a bad door switch, most likely the top one. The microwave got hot because the cooling fan was not running. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your model number here: http://www3.sears.com/
Posted on Apr 26, 2007
SOURCE: Fans continues to run.
door switches or control circuit, may be loose contact or open check all wiring and circuit...
Posted on Dec 18, 2007
Coldcut
  • 1554 Answers
SOURCE: Emerson Microwave MW8115SS
there is a thermal fuse inside that is likely blown.
easy to replace just have to google bullet thermal fuse.
Posted on May 12, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Sharp R-1450 microwave
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
On these, it's usually a broken tab on the upper switch holder.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
That sounds like what's happening when you hold the Start pad - maybe you're moving the frame and chassis enough to help it work.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can probably find exploded views and order parts by entering your model number here at the Sears parts site.
The best place to order Sharp parts is Tritronics.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Aug 19, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Sharp R-530ES microwave oven stopped working
You have a bad secondary interlock (lower door switch) or its mount is damaged or out of alignment.
We have the service manual for this model and have uploaded it to our site here to help you.
You will need the
free Acrobat Reader to view or print it in case you don't have it.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you only need a switch, you can order a universal type here for $5 postpaid.
Posted on Dec 28, 2008
Have a Sharp Carousel R-309YW but seems like there is a random delay time period BEFORE the sound, platter turns, and microwave works. The light comes on, and timer counts down however. Thank you!
Bottom door switch trouble or its mount is loose, misaligned, or broken.
See my help file: http://www.microwavecontrol.com/doorsw.htm
- William E. Miller, AS-EET
pupista@gmail.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Jan 01, 2017 | Sharp Microwave Ovens
My microwave stopped working you can input time but when you push start nothing happens it has power and everything just will not start its like the start button does not work
Possibly a bad door switch behind the holes where the latch hooks go into. Usually with the bad switch the timer counts down but nothing runs. It all depends on which switch is bad. Usually 3 switches inside.
Apr 13, 2015 | Sharp R530EWT Countertop Microwave Oven...
Sharp Carousel R530BK microwave won't cook unless light pressure is kept on the door button.
There are door switches and one of them is evidently out of adjustment or the little actuator arm on it is.
Nov 27, 2013 | Sharp R530EWT Countertop Microwave Oven...
The microwave will not come on ,however the timer starts running . If you hold the latch in slightly it will run correctly but you have to keep it pressed in. I have the sharp carousel model 1200watt
Your door is misaligned dont use it by holding it Ionce you tighten the door correctly then adjust the door switch where the door latches and make click sound Thanks Please rate me
Aug 27, 2011 | Sharp R-510HW Microwave Oven
Start microwave clockon sharp carousel oven
Not sure what the question is.. But if it is how to start the clock in a COUNT DOWN mode, then:
1, Touch TIMER BUTTON
2. Program in the length of time you want to use, before alarm comes on
3. Hit start button.
Unit will beep at the end the count down.
Kindly,
Jim
Dec 10, 2009 | Panasonic Microwave Ovens
May 11, 2008 | Microwave Ovens
No heating, no clock, no timer, otherwise fine!
One of your door interlock switches is defective . I would suggest having it repaired by a qualified repair tech in your area.
Oct 04, 2007 | Sharp R-1500 Microwave Oven
Microwave Ovens Logo
160 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Ed Mac
Jim Thurston
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
