Question about Jenn-Air JJW8230D Electric Double Oven
We cleaned the upper jenn air oven on our double jenn air and after it was cleaned a code came on P3 and the fan wouldnt ever go off so we did as it said to press cancel for a while and it didnt work so we shut off the fuse box to it. Sent for a sensor put it in and the oven seems to work but the fan comes on as soon as we turn the fuse box on and it doesnt go off. What should we do next-----
  • 1 more comment
  • donnadullum Nov 06, 2010
    Thank you, and Im sorry the code was F3 not P3----
    We did all of this and replaced the sensor----temp. now works and thecode went away but the fan stays on constantly even with oven off---so we had to turn the fuse box to the oven off in the garage. What can we do to get the fan to shut off
    Your last comment is what we did in the beginning our problem is the fan wont shut off unless we turn the main fuse box off to the oven------as I mentioned in the original problem we already replace the sensor-----
  • 4,323 Answers
Hi
If you have already replace the sensor and it is getting 1100 ohms then the electronic control is bad and should be replaced. This occurs when a component goes bad in the electronic control board. Please let me know if you need more help.
Daniel
Posted on Nov 07, 2010
    Genius:
  • 1,456 Answers
Hello
The problem is from the temperature sensor.
Open the oven and locate the temperature sensor in the upper left-hand corner of the back wall. The sensor is rod-shaped and approximately 6 inches long. Use a Phillips head screwdriver to remove the two screws securing the temperature sensor. Gently unplug the small plug wiring the temperature sensor to the oven.
Set a volt-ohm meter to the Rx10 ohm scale and put one probe on each of the two metal terminals that the temperature sensor plugs into. A normal sensor should produce a reading of approximately 1100 ohms. If yours does not, purchase a replacement temperature sensor.You might need to replace the appropriate fuse to restore power to your oven.
Be sure that the sensor is well fitted into the oven..
follow theses steps to remove and fix it back properly.
Unplug the oven. Turn the gas line that is connected to the oven (if it has one) to the off position and remove the gas line from the unit.
Locate the temperature sensor inside the unit. It is usually toward the back of the unit and in the corner.
Remove the back panel of the oven by removing the screws with a screwdriver.
Find the wire that comes from the temperature sensor in the location where the sensor sits. Follow the wire until you find its source, then pull the connector for the wire out of the connector using a pair of pliers.
Remove the screws that hold the temperature sensor to the back of the oven and pull the temperature sensor out.
inspect the sensor for any kind of visible damage or tear
Feed the temperature sensor back through the hole and connect the wire to its connector.
Replace the back panel of the oven and plug the oven back in.
Posted on Nov 06, 2010
    President:
  • 2,468 Answers
Have you checked the MAIN electronic relay box/board normally located toward the right upper side of the unit where all of the relays are located,then on a Jenn-Air oven there will be a schematic diagram of the relay board and which board controls which fan,element,door lock,etc,then you can remove the offending relay and test or replace the relay,sometimes the main contacts "WELD" themselves together and won't let unit be controlled by the control panel because of this condition, if the relays are not soldered to the board,remove them by pulling straight up on them and upon removal,give them a sharp tap on the plastic case above the connectors and plug them back in and re try,sometimes they will let go,then just replace the relay in question........if this helps you in this repair,please rate this...thank you .........daniel
Jenn-Air Maytag double wall oven makes loud buzzing noise
There is a cooling fan for upper and lower oven they run at the same time no matter which oven in use it is fed from the oven manager no way to trouble shoot without pulling oven out some models use same fan for both so you could have a blower on hand remove back panels to access fans take a lead off fan to determine which one noisey
Feb 03, 2015 | Jenn-Air Ovens
Error Code 4D21
Somewhere the control is not reading fan rotation could be encoders harness or control had this error once reset oven till I could return with control error never returned replaced control anyway
Feb 08, 2014 | Jenn-Air Electric Double Oven
Jenn-air oven error code 4d22
Hi. Erorr 4d22 indicates that the control board isn't seeing the fan speed signal from the fan on that oven. It's the lower oven, right?
Check the connection to the Fan and Control board, and if that's not it replace the fan.
HTH.
Jul 25, 2011 | Jenn-Air Electric Double Oven
After self cleaning process oven door would not unlock replaced display panel F3 error fan runs constantly lower unit still works upper unit still will not unlock
F3
or
F4
Shorted or open oven temperature sensor
(RTD) Check sensor harness and harness connection
between oven sensor and oven control. Replace oven temperature sensor (RTD) if
wiring is ok.
Dec 04, 2010 | Jenn-Air WW30430P Stainless Steel Electric...
I cleaned the top oven and after cleaning the fan wouldnt go off and we got a code f3----so we did what it said and pressed cancel for a few seconds and it didnt make a difference----so we sent for a new...
the f3 code is caused by a overheated condition . the fan may not go off also due to the over heating condition . you will need to replace the oven sensor to correct problem . looks like a small prob in the oven top left cornor . mm hope this helps .
Nov 05, 2010 | Jenn-Air JJW8230D Electric Double Oven
Fault code F1 on a Jenn Air WM2780. Upper oven
Usually this is a problem with the control board. The board can be repaired at www.fixyourboard.com.
May 21, 2010 | Jenn-Air JJW8230D Electric Double Oven
The upper oven has faulty code 4d22 every time i try to clean
I just tried the suggestion to cut the power to the oven from the box for 1 minutes, and it worked! I feel like I just earned a day's pay!
Dec 29, 2008 | Jenn-Air JJW8230D Electric Double Oven
Jenn-Air Wall Oven Model #WW30430P F5 Fault Code
I have the exact same problem with an F5 fault code. I also have a new clock assembly. RepairClinic.com said "Jenn Air fault code F5 = Hardware and watchdog circuits disagree / Replace clock assembly (also called the ERC)
Jenn Air Fault code for newer models F5 = Power to element relays disabled in cook mode
1. Intermittent oven temperature sensor or wire harness or,
2. Intermittent contact on power relay board"
This doesn't help since it is too technical. What should I do next?
Oct 19, 2008 | Jenn-Air WW30430P Stainless Steel Electric...
Selfcleaning Jenn-Air electric oven
How do I clean my jenn-air double oven when I lock oven door and turn oven to clean mode set time to start I don't get anything. Also when I lock the oven door the oven lock light does not come on.
Dec 05, 2007 | Jenn-Air JJW8230D Electric Double Oven
Jenn-Air JJW8230D Electric Double Oven Logo
65 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
