Question about Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum
More steam coming out of the top of the unit than below. Whats happening?
  • 57 Answers
Bad steam seal in unit. Return for a replacement. :-)
Posted on Nov 06, 2010
Sc20 trigger does not release steam
Clean jet(s) where steam comes out from . They may be clogged.
May 19, 2015 | Top Vacuums
Euroflex ez2 stop working
Minerals in the water clog up the steam outlet tube on these units. You have to open the unit and look for the outlet from the steam generator and try to unclog with a wire.
...Ummm is there water in the unit (just asking) :)
Nov 21, 2013 | Euroflex Monster Ez2 Steam Cleaner
No steam coming from shark euro mop, whats wrong with it
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Sep 26, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Steam leaking from screw cap. can i get a new one?
you dont need a new steam cap if steam is coming out of the top, that is supposed to happen when the hose is clogged, it would be very dangerous if that didnt happen, the amount of pressure that thing holds is unreal if you think your cap is leakin steam take a second look. if the cap is not physically damaged then it should be working fine, 9 times out of 10 your hose is clogged
Oct 27, 2009 | Tristar SB Steam Buggy Vacuum
Shark Euro pro mop the ligt wont turn on anymore.
my husband fixed my shark steamer by taking it apart and testing it wire by wire .the problem ?a fuse hidden inside the unit..unscrew the screws and get inside the steamer .at the bottom of the steamer there is a gold orange foil looking piece .under that is a small fuse .unless you can find another fuse just cut that one off and rewire the wires together .shark now comes on
Sep 27, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark steam mop
heatman101
ab
May 29, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark Steam mop won't steam
heatman101
zsd
Nov 16, 2008 | Euro-Pro Shark Steam Mop - Gray/ Purple...
McCulloch Steam Cleaner Problem
does your motor run if not there is a service switch to the motor inside the unit that has to be adjusted
May 16, 2008 | McCulloch MC1275 Steam Vacuum
Steam shark model sc 505 uk
THE FILL CAP ON MY SC505 IS JAMMED. CAN NOT REMOVE THE CAP. WHAT ARE MY OPTIONS.
Aug 14, 2007 | Euro-Pro Shark SC-505 Handheld Steam...
No steam release
I solved the problem, the metal (hot!) release rod gets stuck & needs a little push.
Unfasten the top by prying off the rubber gasket after removing the top. Remove the 2 small phillips screws, then remove the front that holds the nozzle, & remove those 2 phillips screws.
Carefully pry up the top with a putty knife, inside you will see the tip of a metal piston that the plastic release knob is supposed to contact. Set it on its front, & soak the piston with a light household or sewing oil, giving it a few taps with a blunt object occassionaly to loosen, heat up & test before reassembling, but remember, the piston is very hot. When you push on the piston with a screwdriver, it should release the steam, but also stop when you let go. Work with it a little & it will come back to life.
Dec 12, 2006 | Euro-Pro Super SC710Z Steam Vacuum
Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum Logo
37 people viewed this question
Top Euro-Pro Vacuums Experts
 Tony C
Tony C
Level 1 Expert
Marvin
Marvin
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
