Question about Radio Shack Pro-96 Scanner
Scanner is only showing 1.2.4.5.9. trunking channels
  • 57 Answers
Burnt diode.
Posted on Nov 06, 2010
Looking remove all stored channels from scanner and start over.
Initializing the scanner will erase all programmed information and return your scanner to its original factory settings. To initialize your scanner:
- Power the scanner OFF.
- Power the scanner ON. "Multi-system Trunking Scanner" appears on the display.
- Press 0 (zero) while the above message is displayed.
- Press 1.
- Press ENT. "Initializing please stand by" appears on the display.
DO NOT power the scanner OFF until the initializing process is complete and the display shows "M000 Bank0 Ch00"
Bill B.
Listening in professionally since the 60's
Mar 22, 2011 | Radio Shack Pro-2055 Base Scanner
800 MHz frequency Mode problem
You have to program it TRUNKING mode when you enter the control channel frequencies. It is decoding okay as the MO shows motorola control channel and +DG means digital decoded and an OPEN group. You need to press the 'trunk' button everytime a talkgroup comes up that you want it to remember for future 'closed' group (-DG) talk groups. I suggest you go to 'RadioReference DOT com" and there are many forums there for your radio, as well as one or two YAHOO GROUPS specifically for your scanner. 73's
Jul 03, 2010 | Radio Shack Pro-2096 Base Scanner
LOCK ALL CHANNEL
If all channels are showing the lockout icon, and all are displaying the frequency 000.0000, you just need to program the scanner. Entering a frequency will remove the lockout.
If all are showing lockout and programmed frequencies, and the scanner will not function, you need to initialize it. This procedure will erase all data that you have programmed into the scanner and restore it to original factory settings.
- Turn the scanner OFF, then power it ON again. "Multi-system Trunking Scanner" shows on the display.
- Press 0
- Press 1
- Press ENT
"Initializing please stand by" shows on the display for about 5 seconds.
Do not turn the scanner OFF until initializing is complete and the display shows "M000" on the top line and "Bank 0 Ch 0" on the third line.
Need more information on your scanner? You can download/print the operating manual here:
http://scancat.com/OnLineHelp/OEM_Radio_Owners_Manuals/PRO-97_OwnersManual_ome20-527.pdf
For a comprehensive database of active frequencies and systems in your area, visit:
www.RadioReference.com
Bill B
Apr 21, 2010 | Radio Shack Pro-97 Handheld Scanner
Problem with PRO-2066 scanner not receiving local 800mhz Motorola trunk system II. It does trunk with the current data channels used (showing the ---- line) but I only hear transmissions on freqs ending...
It is difficult to explain in simple terms but I will try.
Google rebanding.
Some radios can have their firmware updated but I don't think your PRO 2066 can.
Channel numbers and frequencies preprogrammed into your scanner have changed over the past few years.
When a data signal says go to channel X that channel is now Y, but your scanner is still looking for X
Hope this helps
Aug 21, 2017 | Radio Shack Pro-97 Handheld Scanner
Need user manual for Uniden radio/scanner BC60xlt-1.
Follow the link below to download/print the manual for your scanner. You may or may not be able to hear the services you mentioned using this scanner due to its limited frequency coverage. Many public service agencies now transmit in the 800MHz range, and many have upgraded to trunked and even digital radio systems. I cannot find any reference to PCH LOCK, but an educated guess would be that it means all programmed channels are locked out. If none of the 10 channels contain programmed frequencies, displays will show 000.0000MHz, and all channels will be locked out. Programming a frequency into any channel should override the lockout. On the other hand, the message could indicate that this old scanner is tired and in need of replacement. Here's the link to your manual:
http://www.uniden.com/pdf/BC60XLTom.pdf
For a comprehensive database of active frequencies in your area, visit:
Jan 03, 2010 | Uniden BC60XLT-1 Handheld Scanner
I am trying to program my Uniden BCT8 to track LTR systems but having problems.
LTR systems must be entered in a specific order so that channel 1 is 1st, channel 2 is 2nd etc...
Are you sure that the BCT8 tracks LTR systems? A Radio Shack PRO 92 tracks all 3 trunking systems (analog) including Motorola and LTR, while some Uniden only track 1, and some don't do trunking systems at all.
Dec 27, 2009 | Uniden BCT8 Base Scanner
What channels for scanner
You will have to find out if your local safety systems are analog, digital, analog trunking or digital trunking, then buy the appropriate scanner. Radio Shack can at least let you know that much before you buy a unit. If they have digital trunking, only 1 or 2 models will work, and reception is quite limited.
You can also go to www. RadioReference dot Com and select Florida and your county and find out the info there. okay?
Nov 06, 2009 | Uniden BC72XLT Handheld Scanner
Pro95 shows trunked freqs are being received, but no audio...
be foe you can recieve them in a closed mode you must input their talkgroup id if not you will not recieve anythang also remember to set your mode to Mot for motorola, fm is foe conventional, am is for aircraft...ect. in the oppen mode you will pick up everthing and their neighbor that uses the frequency set. hope this helps
Jun 01, 2009 | Radio Shack Pro-95 Handheld Scanner
All channels locked out pro-2055
I hope this will help. It shows locking and unlocking ids while scanning and while in a bank.
Locking/Unlocking IDs Contents You can lock out IDs you don't want to hear such as telemetry, MDT's, dog catcher, etc. To Lock out an ID while scanning, quickly press L/OUT while the ID is displayed. To Lock or Unlock an ID manually: 1. In Manual mode select any channel of the bank you want to lock or unlock an ID in by entering the bank number and channel number (Ex: 001) then press MAN to advance to the channel. 2. Press PGM then TRUNK to put the scanner in program and trunk modes. You will see the bank number (0-9), list number (0-4), and the list status (ON or OFF) on the 1st line, the ID# in the list (0-29) on the 2nd line, the ID on the 3rd line, and bank tag on the 4th line (if programmed). 3. Press TRUNK (each time) to select the ID list (0-4). 4. Select the ID# (0-29) by pressing up.jpg or dn.jpg (or press and hold; faster) then press L/OUT to lock or unlock the ID. An L will appear to the right of the ID# if the ID is locked out. 5. Press MAN to exit programming. To Unlock IDs in a bank: 1. In Manual mode select any channel of the bank you want to view the locked out IDs in by entering the bank number and channel number (Ex: 001) then press MAN to advance to the channel. 2. Press PGM then TRUNK to put the scanner in program and trunk modes. You will see the ID list. 3. Press FUNC then L/OUT (each time) to view the locked IDs. Press L/OUT to unlock the ID. The next locked out ID will appear. 4. Press MAN to exit programming. Note: You cannot unlock all IDs at one time.
Nov 18, 2007 | Radio Shack Pro-2055 Base Scanner
Radio Shack Pro-96 Scanner Logo
Top Radio Shack Radio Communications Experts
Jason
john milligan
Steve
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
