Question about LG 42PX5D 42 in. Plasma HDTV
Hdtv I have a flat screen hdtv- i live in the country and im always getting a weak signal - i guess they havent finish in pproving the system- so how do i fix the problem thanks
    Scholar:
  • 43 Answers
If you reside in the USA, go to this website http://antennaweb.org and type your address. The site will give you recommendation on the best antenna and placement location based on your address. Works like a charm believe me.
If you live in another country, HDTV over the air programming may not be available in your country. Your best bet to get a good signal (may still not be in HD) is cable or satellite dish. Best Regards
Posted on Jul 11, 2008
32''lg flat screen tv not switching on
First guess would be the power supply, if that does not work then your signal board.
You can get get parts for this tv at www.interliquidparts.com
Nov 25, 2011 | LG 42LC2D 42 in. LCD HDTV
I don^t have colors my picture on the tv only black and white.Please tell me what is this.I have this tv from USA in Poland.Tell me Im needed Pal Ntsc converter tv where im can buy this converter and witch...
U in Europe,Asia or Middle East they all use Pal signal frequencies.The US,Canada or Mexico use NTSC signal frequencies.Go to an electronic stores in the country u live they'll give u advice.
Sep 09, 2010 | Samsung LN40A550 LCD TV
Can not tune the tv
My dear friend. A TV is a TV and TV's are many and varied. If you stated the model and what it exactly does, maybe I or other people could help you instantly. But since you have said little in relation to TV tuning, then expect a few guys to help you. But allow me to give you a hint that applies to almost all flat panel TV's, ok? Right. On every TV there is a MENU that gives you many options. First you need to press a button on the remote that displays component connection channels and TVincoming signal type. Since I don't know what brand of flat panel TV you have, I can only ask you to find and press the button on the remote that displays on TV screen the following component channels, that is DVT, AVT, Component 1, Component 2, HDTV1, HDTV 2, HDTV 3 and so on. Apart from DTV and ATV, from Component 1 to HDTV 3, these additional channels are for DVD players that also have HDTV outputs and BlueRay players and or Audio devices. If yout TV hasn't got as many channel input, then ignore this part. To tune your TV you have to first press the butoon on the remote to activate the onscreen channel as above, then scroll on DTV or ATV and, depending on whether you have Digital TV in your country or the standard high resolution Analog TV. Lets say you have Digital NTSC format TV system, select it and then press ENTER on your remote. In the menu you find and click SCAN. Depending on where you are, the TV will begin scanning all frequencies in your territory and possible interstates if the modulator is powerful enough to pick up weak signals. Most TV's have an inbuilt set-top box that boost the signal to give you a crystal clear pic. Now, after pressing SCAN, the TV reaches a signal with a clear pic, all you have to do is recognise the channel that comes in view. The instructions on how to save that channel are on screen and then you can configure it as, say channel 4, if the channel that appeared is channel 4, if not, try and recognise what channel had appeared and then configure it with a number, so when you press that number on the remote it will be the same channel you had stored in the TV memory. After you have done this, press scan again and it will scan to the next channel. Once the scanning recognises another clear signal and it is as clear as a baby's face, you have recognised the new channel. Try, find out what channel it is by looking at the screen, there is usually a visible TV station name or number embossed on the lower corner of the screen, once you know what station that is or what channel number it is, configure that number and press ENTER (save) button. Do the same with the remaining channels. Later I will tell you how to skip unwanted blank channels that usually have no signals but snow and lines, or have faint signals that can only be boosted with a TV booster available from reputable TV retailers, or install a bigger more powerful antenna.
Reagards.
Mike
Oct 06, 2009 | Televison & Video
Missing or weak signal
try a outdoor antenna on the roof for digital signal use.also the main digital PCB is defective which has the tuner on it if the antenna does not work.you may try taking the
tv to a friends house and see if the tv works better.
Sep 04, 2009 | JVC LT37X787 37 in. HDTV LCD Television
'No Signal' on my LG LCD HD TV!
sounds like a weak signal or some electrical item interfering with the digital signal .check the aerial conections .farr64
Apr 30, 2009 | LG 42LC2D 42 in. LCD HDTV
Losing signal intermittently every 1-5 minutes
This problem is probably due to weak signal strength from the cable to the television. Buy a signal amplifier for you cable line in and use another cable out of the amplifier output to your Television input signal source, This should bring up the signal strength for you.You could also have your cable company check the input signal strength to you house or apartment and see if the cable itself needs repairing or replacing.If this does not help with your problem , then you need to have your television tuners signal input circuit tested it may have weakened from age. This may be adjustable in the tuner box, but this is something for a service technician to determine. customer service number for Insignia is 1-877467-4289. Hope this helps you with your problem
Apr 20, 2009 | Insignia 37" LCD Flat-Panel HDTV
Image gets pixelated and a black screen flashes
yes its a cable box problem, find the channel you are having more problems with,press guide in the cable box remote and you will see how the box where the video is will still have the problem and the guide with channels info its going to be clean,
100% weak signal
hdtvman
Jun 22, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
How do I get HD broadcasts on a Phillips 60PP9352 TV that's 'HD ready'?
Hi.
Im guessing your in the UK.
Asking about HD as you havent stated what country you are in.
Ok You will need the following to be able to watch HD pictures on your tv set.
Either Sky HD which involves having a dish fitted. Or Virgin cable system which is not available all over the country.
If you go to either of these systems you will need to pay a subscription to view the HD channels.
http://dysonmanuals.llc.nu/
Chris..
Jan 01, 2008 | Televison & Video
Weak or no signal message
Is this a joke? How am i suppose to get help?
Dec 17, 2007 | Samsung LN-S4092D 40 in. LCD HDTV
LG 42PX5D 42 in. Plasma HDTV Logo
79 people viewed this question
Computer Repairing
Computer Repairing
