Question about Frigidaire Kitchen Ranges
OWER OVEN DOOR LOCKED WHEN WE TRIED TO USE THE SELF CLEANING OVEN AND THE CODE F93 ERROR APPEARED
  • Anonymous Mar 20, 2014
    F93 Error Code in oven monitor
    Genius:
  • 1,036 Answers
F93 is "Maximum oven door lock time exceeded."
Basically it's trying to lock the door, and doesn't know when to stop.
This could be a lock motor problem, or a faulty microswitch.
Turn off and wait 5 minutes. Turn on again, and pull and push the door continuously for 30 seconds or so. Turn off again.
You will need to test the switch and motor assembly. Replacing whichever is defective.
Hope this helps you.
If you get it sorted, please rate as Fixya.
If it was of any use - as helpful,
If no help- as thanks F T.
If no help at all - inappropriate.
(I think the descriptions are missleading.)
Thanks.
Posted on Jun 14, 2008
I tried power cycling the range by throwing the circuit breaker on the range. I waited 5 seconds and then set the breaker. I had to reset the clock but everything else then worked as in the instructions. This was a Frigidaire Gas Range.
Posted on Jan 11, 2010
Fridgidaire F93 error code and beeps as soon as we try to use oven. Beeping stops with cancel but stove doesn't work, last 2 days.
Computer operated and monitored devices don't like safety features being disconnected.
I did find this though.
Based off the information you have provided your Frigidaire oven is displaying the error code F93. An F93 error code means that you have reached maximum oven door unlock time exceeded. This could be a potential issue with your EOC (Electronic Oven Control), lock motor, or light switch. I would recommend resetting your range and you can do that by disconnecting power from your appliance for ten minutes. Once you reset power to your range, if you continue to experience an issue I would recommend consulting with a technician. They would need to check each component to assure that the proper amount of power is being provided to each part. I hope this information is helpful.
Also this information generally.
Fridgidaire F93 error code Google Search
Dec 08, 2016 | Kitchen Ranges
How i can stop the fan and open the (locked) door (error F93)model Frigidaire CGEB27Z7HB
Hello Yves Trottier, thank you for your post!
I understand that your Frigidaire range is displaying the error code "F93". Typically, "F93" stands for maximum over door unlock time exceeded. This could be a potential issue with EOC (Electronic Oven Control), motor door latch assembly, or fan motor. I would recommend performing a reset on your range which consists of you disconnecting power from the range for approximately ten minutes. If you continue to experience such issues I would suggest consulting with a professional technician for proper diagnosis and repair. Hope this information is helpful. -Matt
Dec 06, 2014 | Frigidaire Kitchen Ranges
Error F93 lock out of the oven how do i reset it
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 30, 2010 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
F93 error code
unplug the range.
wait 1 minute.
wait 2 minutes.
Apr 24, 2010 | Kenmore 95002 / 95004 Electric Kitchen...
F93 error. Oven door is stuck, won't open. Display is flashing door locked and continues beeping. This happened once before and a repairman had me press a few buttons and it reset and fixed the...
Hi
Thanks for using FixYa. F93 code means "Maximum oven door lock time exceeded." Actually it's trying to lock the door but is not aware of the time to stop. Please check the micro switch and lock’s motor. Replace whichever has gone bad. To reset it turn it off for more than 10 minutes and then turn it on.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 17, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Self-cleaning error message f90
unplug the range.
wait 1 minute.
wait 2 minutes.
Dec 30, 2008 | Kenmore 79383 Dual Fuel (Electric and Gas)...
F93 error
F93 error code means Maximum oven door lock time exceeded. Check oven door lock/door lock switchs.hope this helps
Dec 20, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
F93 fault code
unplug the range.
wait 1 minute.
wait 2 minutes.
Oct 04, 2008 | Frigidaire FGF326AS Gas Kitchen Range
Self Cleaning
unplug the range.
wait 1 minute.
wait 2 minutes.
Mar 03, 2008 | Kenmore 94220 / 94221 / 94222 / 94224 /...
Kitchen Ranges Logo
1,014 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
