Question about Kenmore Elite Oasis ST 7806 Dryer
Replacing Thermistor on Kenmore 11078062801 dryer
    President:
  • 1,554 Answers
Disconnect power then remove the screws securing the rear panel to the cabinet as shown.
Once the rear panel is off, you'll see the exhaust along with the thermal fuse on the blower housing as shown.
Simply unscrew the thermistor if it needs to be replaced and screw the new thermistor in place then transfer the wires from the old thermistor. If your dryer has the inlet thermistor that needs to be replaced, do the sreplacing Thermistor on Kenmore 11078062801 dryer - jahn27_6.jpgutlet thermistor above.
Posted on Nov 06, 2010
Kenmore Oasis Dryer 11078062801 Service Manual
Hello, this is Ava with Think Crucial.
You may find the User's Manual for your Kenmore model by clicking the link below.
https://www.searspartsdirect.com/partsdirect/user-manuals/11078062801-Kenmore-elite-Parts-RESIDENTIALDRYER-manual
You can purchase a wide variety of high quality appliances replacement parts direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/appliances
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Feb 23, 2013 | Dryers
Kenmore elite He4 the dryer (front load) runs and spins, stops and displays E2 trouble code
The E2 error message indicates the control has detected a shorted thermistor. A defective/faulty thermistor can cause your dryer not to run Most likely replacing the thermistor will fix this problem.
The thermistor is normally in the back of the dryer, remove the panel to locate.
Look on the air tube for wires connection to something that looks like this.
The thermistor is located beneath the red wire oval in shape.
Double left click on it to make it larger
You can go to the top of the page and click on any picture to see it larger
Please take time to rate me
http://www.bing.com/images/search?q=kenmore+dryer+&view=detail&id=2895F623DBE1DB5198CEF5E07D186CA21E98F54E&first=0&qpvt=kenmore+dryer+&FORM=IDFRIR
Sep 12, 2011 | Kenmore Dryers
The dryer shuts off, keep getting an E1 code, what needs to be done
It sounds like this is a Whirlpool Duet or a Kenmore Elite Dryer due to the error code E1 being available only on this models. The problem here is an open thermistor as what error code E1 means. It's either the thermistor is exhibits an extremely high resistance or the wire harness connecting it to the control board is broken or cut open. Click on the link below for the detailed procedure in accessing the thermistor.
Whirlpool Duet and Kenmore Elite Electric Dryers Not Starting
Measure the resistance of the thermistor and refer the table below. Normal thermistor resistance is around 10000 ohms (10K) at room temperature.
Replace the thermistor if the resistance is significantly higher (or lower) than what it is supposed to be based on the resistance table above. Check the wire harness connecting it to the control board, if the resistance turns out good, and make sure the connectors are good and the wires are intact. Replace the wire harness if necessary. Consider replacing the control board if both the thermistor and the wire harness turn out good. The link below might enlighten you further on the troubleshooting of the thermistor.
Thermistor Troubleshooting on Whirlpool Duet and Kenmore Elite Dryers
Aug 21, 2011 | Dryers
Kenmore Elite stops early and flashes e1. How do we corect this Thanks Todd
The electronic control detected the thermistor is open. The wire harness connecting the thermistor and electronic control is broken or the connection is loose or the thermistor is indeed open. Measure the resistance of the thermistor then refer to the temperature and resistance table for the normal thermistor resistance values. Click on the link below for the detailed troubleshooting and replacement procedure.
Troubleshooting Error Code E1 on Kenmore Elite and Whirlpool Duet Dryers
Feb 13, 2011 | Kenmore Dryers
My Kenmore Elite HE3 dryer keeps stopping indicating an E1 error. The model number is 110C82822100
Well the error E1 message indicates that the thermistor is defective and needs to be replaced.
Try unplugging the unit for a few minutes got rid of the error, but lately the temperature just hasn't been hot enough so the clothes don't dry. You must need to replace the thermistor for full working of your dryer. you may please follow the below steps to know how to change the thermistor -
1. Locate the thermistor on the top right hand side of your dryer. This will be a small platelet with a chip and wires coming out of it. Use your screwdriver to remove the two screws holding the thermistor on the unit.
2. Unplug the wires from the thermistor.
3. Plug the wires into your new thermistor. Replace the thermistor on the dryer and the screws holding it in place.
4. Replace the back panel of the dryer and plug your dryer back into the wall outlet.
5. Push your dryer back up against the wall and turn it on again.
Post comments for further help or information......
Good Luck!!
Thanks for using FixYa!!
Aug 28, 2010 | Kenmore Dryers
Kenmore electric dryer heat stays on when door open
Sounds like your thermistor/thermostats could be your problem.
They control the heat coming from the heating coil.
Unplug the dryer.
If you remove the back of the dryer, look for the air tube coming from the blower to the drum, normally inside the air tube you will find the heating coil and the thermistor/thermostats. Replace as needed.
Good luck,
Hope this helps
Oct 05, 2009 | Kenmore Dryers
I have a kenmore he4 no. 110.85871400. i have no heat replaced thermal fuse high limit thermostat anf thermal cutoff switch. still ni heat. elements are good. cleaned all lint. do i need to get a...
Check thermistor with ohm meter, make sure you unplug unit first, make sure wires are removed from thermistor or you will read ohms thru the wiring. If thermistor checks ok, the you have a relay board problem. replace power board.
Sep 29, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore dryer 61062 stops frequently
An E1 error message usually indicates that the thermistor (see the following link) is defective and needs to be replaced. Without that part working properly, the electronic control could do unexpected things.
- Kenmore 110.61086000 Thermistor
LINK > http://www.appliance411.com/data.php?rc=548392
Apr 08, 2009 | Kenmore Dryers
Kenmore dryer (electric )
NOT ELITE HE4..... Model 96595400. Replaced thermistor and Hi-Limit Stat. Probably the thermistor.
Jun 28, 2008 | Kenmore Elite HE4 Electric Dryer
Dryer
Error codes. are any of these lit? PF Power failure "PF" flashes to indicate that a power failure occurred while the dryer was running. Press HOLD TO START to continue the cycle, or press OFF/Pause to clear the display. E1 Thermistor open Replace thermistor if found defective E2 Thermistor shorted Replace thermistor if found defective
Sep 12, 2007 | Kenmore 82836 Gas Dryer
Kenmore Elite Oasis ST 7806 Dryer Logo
1,342 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
