Question about Whirlpool WMH1162XV Microwave Oven
WMH 1162X VS -1 (watts unknown) Builder purchased
WMH 1162X VS -1 (watts unknown) Builder purchased Feb 09; I bought with house 8/09. Have only used appliance 5 months. Turntable turns, but there is no heat to warm or cook food. "Replace filter" notice appeared few weeks back. Given no real age of microwave, questioned need and did not do this. Two metal filters under the microwave have no grease or other visible soil. Are we talking about removing screws, and replacing the carbon filter at the top of the microwave? Surely not. After 5 months' gentle use? Perhaps these two issues are not even related; i.e. filter ... no heat. Turned microwave breaker switch off at fuse box, and on after 30 seconds. Tried the PROGRAM button on the appliance. .... "reset" the non-replaced filter. Saw nothing about temperature within the Program menus. ANYWAY ... TURNTABLE TURNS, BUT THERE IS NO HEAT. What do you suggest? Thanks.
  • Whirlpool Master
  • 9,098 Answers
If the oven is set up to vent outside, then the metal mesh grease filters are used, and they should be cleaned in warm soapy water whenever they look greasy or dirty.
If the oven is set up to recirculate, then the charcoal filter is used, and it must be replaced (not cleaned) every 6-12 months, depending on use.
This model does not have a separate cooling fan like most other models. It replies on the vent fan for magnetron cooling, so if the filter(s) gets too dirty, it can reduce the cooling air flow, which can allow the magnetron to overheat and be destroyed.
I would need to know a little more to help narrow down the "no heat" problem.
If the cooling fan, turntable, and inside light all come on when you press "Start" to cook, then I would ask if you here a "thump" when you press "Start."
If so, then the high voltage section is getting energized. If not, then it may be the cook relay on the control board, which I can affordably repair.
The support page for your oven is here, and it has manuals and part lists you can download.
For more free DIY and other help & advice, feel free to contact me with your full model number and FCC ID number from the tag on your oven.
William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Posted on Mar 16, 2017
SOURCE: Microwave does not heat
Just had the same experience with the identical model. Removed the cover (a challenge because of the security screws), revealing valuable troubleshooting directions intended for an experienced technician. However, I think the info is well within the reach of a typical DIY person, does not require any dangerous power-on conditions. However, make sure that you discharge the HV capacitor before trouble shooting. In my case, it appears that the HV diode is open, have ordered a replacement on the internet for $3.18, easy to replace. Hope it works. Good luck.
Posted on Jul 14, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: GH7145XFB-1 not heating properly
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose conneciton on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Posted on Nov 17, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: MIcrowave light and turntable are working, but food comes out cold
I suspect the magnetron or high voltage transformer, and either part's cost or labor would probably be about the same as the cost of a new comparable unit.
Posted on Aug 18, 2008
biigg53566
  • 88 Answers
SOURCE: everything works except the cooking part/no heating/turntable not turning, help!
you may have gotten a power surge and that can cause some funny things to happen, 1st is there power to the oven, 2nd if so there may be an internal fuse protector built in to the oven, check with the manual for anything of that sort listed. if not you may have to take it in and have it repaired by a pro. there is a lot of voltage in these ovens and unless you know what you are doing a person could get hurt
Posted on Jan 03, 2009
ginko
  • 19396 Answers
SOURCE: Whirlpool MH1140XM: has power, but no heat, turntable not spin.
Test the high voltage capacitor, the rectifier diode.or the magnetron.
The diode and capacitors can br tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, even if power is off. Capacitors can get discharged by shorting their two contacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
Posted on May 21, 2009
The Time and Memory Buttons stop working and function again a day or 2 latter why is this happening and can it be fixed?
1200 watt input and 700 output makes it 700 watt machine.
sounds like tThe touch pad is finicky . Yes , you are stuck with it unless you wish to replace the touckh pad.
They claim to have parts for Mezzo:
spares.bigwarehouse.com.au
Aug 03, 2014 | Microwave Ovens
AccuWave Magnetron - "Continuous Power Levels" WhirlPool MicroWave Oven
It certainly sounds like something is wrong. My first GE microwave was like this and it wasn't advertised as anything special. After a long life I replaced it with a Sharp (makes most all microwaves) and was disappointed at the cycling on and off. Now Panasonic makes what they call Inverter microwaves with continuous power. I recently bought a GE (probably made by Panasonic) with this Inverter technology and am very pleased with it. Make sure the microwave you have says AccuWave on it, if it does, it sounds like the magnetron may have been replaced with a non-continuous type of magnetron. Was it bought refurbished/returned/clearanced? I think when I was researching this that it MAY have something to do with the type of power supply to the magnetron and not so much the magnetron itself.
Mar 23, 2017 | Whirlpool Accuwave Microwave Oven
My country use the 220 volts system do have to use a step down transformer of plug it in direct.it has been a year i have not used the appliance having no information on wattage
If your microwave is wired for 220 volts AC and your country standard house current is 220, and the plug is of the proper configuration, plug it in.
Standard microwave size is around 1100 watts at 110 volts Normally, two times the voltage is 1/2 the wattage. Ohms law, Voltares Law and Watts Law apply.
If your microwave is 1100 watts at 110 volts --- yes you will need a step- down transformer of some type.
Jul 12, 2011 | Emerson MW8102SS 1100 Watts Microwave Oven
Does the Welbilt MR95TW exceed 800 watts?
It's 850 Watts, 0.9 cu ft.
Aug 27, 2009 | Welbilt MR95TW Microwave Oven
No vent for over the range microwave.
Have you selected a microwave yet?
many over the range types can be vented inside if a charcoal filter is used, which you must replace about every six months.
Otherwise, you will need to install a vent system in the kirtchen.
Aug 20, 2009 | Microwave Ovens
Surface and night light bulbs
If the model number you have this listed under is correct, the bulb you need is part #AP2029997, made by GE. You can also purchase these bulbs at any hardware store. They are the half sized small base, 40 watt bulbs. If you can't find 40 watt, make sure you use a lower wattage rating. If you have questions, or if the model number is incorrect, please let me know. I hope this helps you.
May 04, 2009 | GE JVM1650 1000 Watts Microwave Oven
Touchpad no response at all
CHECK CONTROL CIRCUIT AND RELACE TOUCH PAD..
Nov 06, 2008 | GE JVM1650 1000 Watts Microwave Oven
Purchased ge counter top microwave feb.2 from best buy it has quit heating, why?
Your oven should come with a 1yr. warranty. Try calling the G.E.repair toll-free number below. They should help resolve your service issue. Have your model, serial no., and proof of purchase handy when you call.
1-866-512-6333
May 23, 2008 | GE Microwave Ovens
Sharp r-1491
Yes call shart help line, you can find it on 411.com or googles, with you model and them the part # for the bracket and ask them were you can purchase it.
You can also try sears with your model, there or a very excelent sourse for question's on parts, if they have this model they will have all info.
Regards
Bob the builder
Feb 07, 2008 | Sharp R-1491 Microwave Oven
Whirlpool WMH1162XV Microwave Oven Logo
69 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
