Question about Sport & Outdoor - Others
Hi. No i haven't got any trees near the spa so i tryed to do what you said about taking the filter out. But then i turned it on at the power point and the spr worked with the jets working then it stopped and now nothing works so i pulled the cover off the electrical box and i have a voltage tester and there is power going to the unit from the power lead but not to the two plugs on top of the box which lead to the control buttons that operate the spar jets on the side of the spa [cream coloured buttons]. It looks like it may have a sort somewhere. I carn't find a reset button on the power box and we have circut breakers in the fuse box [house] and they are working ok [The box is making a cliking noise].Have you got any idea what maybe wrong with the box
    President:
  • 2,777 Answers
Have you attempted powering off at the circuit breaker level, leaving it flipped off for a good 5 - 10 minutes minimum and then flipping it back on? That may well reset the whole spa and get it working again.
Please give it a try and let me know, do you still not have power to the two plugs on top?
Thanks, please reply to me here and I can get right back with you..
Tim
Posted on Nov 06, 2010
Why can't my brand new Meade Polaris 127 telescope not even show me stuff in broad daylight or night. No matter the lens, eye piece, eye, object near or far. I only see eyelashes sometimes if I try.
I suspect that what you have is a combination of two problems:
1. you are very far out of focus,
and
2. you have too much magnification.
Here's what I would do.
Point your scopt at some distant trees. Use your lowest power eyepiece, and run the focus all the way from one end to the other. At some point, you should see the tree leaves....
Nov 15, 2015 | Meade Optics
Keeps turning on and off
Need more info...
Is it a heater that keeps turning on/off?
check your filter, it could be dirty.
clean the cartridges, or backwash: Sand or DE?
If DE, you may need to do a complete breakdown and cleanse?
There is a flow switch in the heater, that monitors correct/proper amount of water flow. If you are near that cutoff point, the heater will turn off.
Good Luck
Mar 14, 2015 | Pool & Spa
Caldera olympia highland spa keeps tripping breaker
with power off take heater wires off make sure to mark them so you know which is which if it doesnt blow fuse it is heater element if it still does hook back up then try to disconnect the recirculation pump just keep eliminating things
Mar 02, 2014 | Caldera Spas Highland Series Olympia Model...
Pump on sand point well keeps running
I take it its electric. if there is a leak in the supply line somewhere then it wont turn off. if you can cap the supply pipe near the pump and see if it turns off then. if it doesn't then the pressure switch needs adjusting or replacing. good luck
Dec 08, 2013 | Pool & Spa
We have an Jandy Ji8000. We have really enjoyed having it for years. Just lately, the filter goes on at the wrong time. If we try to turn it off at the panel in the house, it will not turn off. We have to...
Look up Zodiac Pool systems, on the web site you can find a list of service providers in your area. You may be looking at replacing your automation at this point.
Mar 24, 2017 | Jandy AQUALINK RS TELELINK KIT
Lay z spa pump has E02 code which is water flow problem,have changed filter.flushed through ,set reset button but fault code still appears.
If this is an outdoor spa near trees, its almost a guarantee that the impeller is blocked with debris (pine needles can cause this in a hurry)
If the impeller is clean of debris and this is still happening, replace you pressure/flow switch.
Apr 27, 2011 | Pool & Spa
My spa keeps on pulsating the same way it does when I refill it when I first start it up
Either your circulation pump is "air locked" or you need a new filter, or both.
to release the air-lock shut off power to the spa . remove the filter element(s). take a garden hose to the hole under the filter and try to get a good seal. turn it on and let it flow for a minute to try to "prime" the system. REMOVE garden hose and turn power on WITHOUT the filter. this should unlock it.
replace the filter and monitor. If it starts happening again with the filter in place, get a new filter.
This is assuming that you know that your pump is good.
Dec 07, 2010 | Qca Spas Paradise Hot Tub
Hi! I have a Hayward Pro pool/spa system with Jandy valves and I'm trying to figure out how to switch them from pool to spa. Either I empty the spa or I'm heating the whole pool. Help please!
This is tough cause I can't see the valve setup. I have to assume they are manual valves. Normal operation probably takes some water out of the pool and spa than puts it back into both. To heat the spa, set the intake valves(the ones in front of pump) to take water from only the spa. Set the jets(valve(s) on output side of filter) to send water back to only the spa. The pool will be out of the loop. Normal operation usually has water taken out of pool and spa than put back into both. Make sure to put more water back into spa than you take out, (Adjust valve)
Apr 23, 2010 | Hayward SAND FILTER, PRO SERIES
We have a spa quip 2.5 maxi flow spa pump,tried to turn the spa on and the pump was hot and just made a buzzing noise.There is power getting to the pump but it just wont filter.The spa controller seems to...
Hopefully you have not fried the motor. To free a stuck motor: try to reach past the strainer to the impeller and turn it. If you can't do that, remove the electric end cover and find a double flat for a wrench where the shaft goes into the motor. Or maybe you can remove the spring thing from the end of the motor and move the shaft with a pair of vise grips or pliers. Don't damage the place where the spring thing mounts. Don't try to move the motor with the plastic fan thing near the pump, you'll just break it, and then you really have problems.
To keep a motor from sticking, thru off season occasionaly spin the pump, just a few seconds will do, don't need water.
Apr 17, 2009 | Jacuzzi Pool & Spa
Sport & Outdoor - Others Logo
19 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
