Frigidaire washer not spinning clothes enough
I have a front loading Frigidaire Model#CRTF1240ASO that we purchased in 2003. For the past year, we've sporadically been getting small spots/stains on our towels and clothes. Now, the other day it started clicking while spinning and yesterday it was squeaking. Today, it stopped spinning the clothes sufficiently during the final spin. Of course, the warranty ran out 6 weeks ago. The service call is going to cost $75 and they won't be here until Friday. I'd like an idea of how much this might cost to fix. If the cost to repair the machine and pay for laundry service for a week on top of the service call is going to add up too a great deal, I might as well buy a new machine.
Thanks for your help!
SOURCE: Frigidaire front load washer will not spin
i was told when it won't spin, then the drain is plugged.  i opened mine up and found a sock stuck in the drain hose.  removed it and seems to be working well.
Posted on Sep 07, 2008
  • 77 Answers
SOURCE: model 110 washer will not go into a final high speed spin.
hi, i would suggest the timer/programmer is faultyas it is ok on the other cycles, the noises you have described may have caused some damage,
Posted on Feb 10, 2009
SOURCE: Loud banging noise during final high speed spin
I have the HE3T which is 6 yo. Last week it started making a loud banging noise in the spin cycle. I had a repairman come out. He said it is the drum bearings. He said that it is a problem with these machines and to call Sears. He said that the drum and bearing is one assembly and that Sears should cover it.
I called today and Sears todl me that I have to pay for a Sears technician to come out a determine if it is indeed the problem. If so, it will be covered under the lifetime warranty on the drum. I have to pay for the service call $75.00 and if it is the problem, I will be reimbursed. Cross my fingers!
Posted on May 21, 2009
  • 14 Answers
SOURCE: Washer won't spin
Check to see if the strainer before the pump is partially clogged.
Posted on Sep 11, 2009
baugh55grfmj
  • 225 Answers
SOURCE: My frigidaire stopped working
The bearings are bad. My sears kenmore did the same thing. Do you have hard water, that would be one cause. Or maybe it's still under warrenty because it is not a cheap fix.
Posted on Dec 31, 2009
Hi i have an Frigidaire FAFS4474LW front load washer and it always stuck in the final spin last 6 minutes and it was keep spinning on the last 6 mins and never ended. It takes over 2 hours to finish a...
Thank you for your post, Tom Lau!
I see that you are having a difficult time with your Frigidaire washer, FAFS4474LW, taking long a time to complete a cycle and not rinsing the clothes out enough. This could be a possible problem with your sensor or control panel on your washer. You may want to perform a reset on your washer to help clear out any miscommunication within the washer. In order to perform a reset you would need to flip the household circuit breaker off for roughly ten minutes. If you continue to have issues with your washer after the reset I would recommend seeking assistance from a professional. This will help you to avoid any unnecessary part purchases. Best of luck! -Matt
Feb 17, 2015 | Frigidaire FAFS4474LW Laundry : Front Load...
Frigidaire front loading washing machine works fine in regular wash but won't spin out enough in perma press cycle.
I appreciate your post, Kathy Saalfeld!
From my understanding on permanent press your Frigidaire washer will not spin out enough water. This could be a possible issue with your control panel or sensor within the inside of your washer. You may want to review your drain tube to assure that it is not restricted or kinked. This could be a possible problem with your drain pump or timer. You may need to consult with a professional technician for a proper diagnosis and repair to be performed on your washer. Good luck. -Matt
Feb 16, 2015 | Frigidaire Washing Machines
My front load washer will not spin on the final spin cycle. Washer spins in wash and rinse cycle spin. Cloths are still soaking wet.
I appreciate your post, Rachel Kovach!
From my understanding your Frigidaire frontload washer is not spinning the final spinning and the clothes are still wet. If you washer is overloaded it will not spin properly to release the water out of the clothes. Also, a small load will cause your washer to not spin properly. You should additionally check the drain hose to make sure it not kinked or twisted that could cause your improper draining. If all that checks properly it could be an issue with your drain pump, motor, and control panel. I would suggest consulting with a technician for proper diagnosis and repair. This will help avoid unnecessary part purchases. -Matt
Nov 19, 2014 | Frigidaire Washing Machines
My Washing Machine is not spinning all the water out of my clothes.
Front loading washers are notorious for not spinning the water out of a small load of clothes. This is because there is not enough clothes in the washer to balance the tub during the spin cycle.
Try washing a slightly larger load with a minimum of six items or more. This is one of the downsides to front load models and no specific brand is immune to the problem.
Mar 17, 2013 | Frigidaire FAFW3517KN Affinity Series...
Frigidaire gallery top load washer
After 13 appliance years, your washer is a candidate for replacement.
Aug 08, 2017 | Frigidaire CWS3600AS Top Load Washer
My Frigidaire front load washer doesn't spin, it turns during the wash cycle, doesn't show an error code, but doesn't spin the load at all, it is model CLTF2940ES0. Is it something simplet to fix?
Welcome to FixYa.
Based on what you've described,...you likely need a door lock/switch assembly. The closest I found to your model is actually CLTF2940ES0.
The door latch is likely the single most common fault (which prevent's any spin, and consequently drenching wet clothing at the end of the cycle) with the frigidaire/electrolux built washer's, aside from pump's being obstructed.
I think it fool's many people because the lock indicates it is energized on the panel, however the built in "monitor" switch inside the assembly fail's. I do see a lot of these particular machine's...unfortunately.
You should be able to purchase one at most local brick
Sep 05, 2010 | Frigidaire GLTF2940ES Front Load Washer
Washer fills with water but will not agitate to wash the clothes.
REPL/ PUMP GRINDING NOISE IS BROKEN IMPEELER INSIDE PUMP SHOULD FIX PROBLEM
Nov 30, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Front load Frigidaire Gallery washer
You are having a door switch problem change it out and you will have a new washing machine.
Dec 14, 2007 | Frigidaire GLTR1670A Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
