Question about Philips CCB130AT 13 in. Combo
How do i unhook the vcr? the tv goes to blue screen because the vcr thinks that there is vhs tape in the player when there isn't.
  • 308 Answers
SOURCE: EWC1304 VHS tape shuts off entire system
You probably have a bad or dirty mode select switch. Another possibility would be a gear out of time if a tape was forced in too quickly.
Posted on Mar 12, 2007
  • 28 Answers
SOURCE: VCR TAPE IS STICK IN VCR PLAYER.
if you can't get the tape out enough to pull it very carefully out by hand, you'll have to bring it to a repair shop. the tape is probably twisted up inside and jammed.
Posted on Nov 09, 2007
IB4G2008
  • 3587 Answers
SOURCE: Tape stuck in VCR
could be that you're looking at a blown cartridge for that vcr tape. You may need to cut the tape, to extract that from the unit.
The play head would usually retract when the cartridge is removed, BUT could be compromised by some tape getting into the play head mechanism, and jamming.
be particularly careful with anything pointy or sharp, as the tape head does NOT like those objects near the read surface.
Posted on Mar 02, 2008
SOURCE: Stays on for 5 seconds, thinks it has a DVD or VHS tape in
replace the ir diode (D1224) under the vcr section. its a clear looking led (bulb like) this solved my problem ... as it was previously suggested as one of the solutions. vcr know function as well as the rest of the tv---- you need to have some background in this work or it will be tough to do .......
But thanks for the help it took care of my problem
Posted on Sep 24, 2008
  • 3 Answers
SOURCE: Magnavox mwd 2206 dvd vcr player....shuts off with eject word across screen.
On a unit I checked with this same symptom, removing the top cover allows the unit to stay on and operate normally. There is some sort of sensor at the left middle of the chassis, which, when unblocked by any opaque object, allows the unit to remain on. A temporary fix (not advisable) would be to replace the top cover with a piece of clear plastic or taut saran wrap (no vent holes needed). It's unclear exactly where/what that sensor is from a cursory test. This is a work in progress on someone else's machine that I lack full access to.
Posted on Jul 07, 2009
My tv screen goes blank for several seconds while I am playing tapes
Mine does that too when playing VHS. But play any dvd and switch back to vhs and the black screen goes away
Nov 15, 2010 | Toshiba DVR3 DVD Recorder/VCR
The VHS tapes will not playback on the Samsung TV (flat screen)..the Samsung TV is a Syncmaster 2333 HD...the Samsung dvd/vhs unit is a DVD-V9800 The DVD discs will play just fine. How should I be...
On these combo units, the VCR will not play using component cables but the dvd's will play just fine.
What you need to do is run a pair of composite (Yellow, red and white) cables and use that for VCR and component (Green, blue, red, white and red) for the dvd player.
Make sure you switch the tv to the corresponding input.
Dec 30, 2009 | Samsung DVD-V9800 DVD Player/VCR
Stuck VHS Tape/Power Issue
It sounds like the vcr is not completely loading the tape, and is overloading or getting confused. If you feel up to it, you can take the cover off the tv, find the tape loading mechanism, and 'help' the loading rollers along yourself... once the tape loads, eject it immediately, and you should be off and running again. Just be careful not to touch any electrical connections. If you're not comfortable with that, you're right, it's probably cheaper to get a newer tv - check with a local independent shop first, though, it should be a really quick fix.
Mar 14, 2009 | Samsung Televison & Video
JVC HR-S7600U VCR. Playback issues with VHS & SVHS tapes.
super vhs tapes has an extra hole on the side where you lift the flap to see the tape the pin inside the machine must be stuck.I have had no problems with this as i have jvc super vcr s as they are great machines also take the lid off and clean the heads around the drum see how you go.
Jan 25, 2009 | Pioneer VSX-D710S Receiver
No video output when played on vhs
try cleaning the cylender head of your vcr you can do that by opening the unit or buying vhs vcr casset cleaner....
ps : check if you have to switch between tv and vcr via remote , and when you insert the vhs tape you are able to rew and frw and press play normally...if these are ok usually its a little dirt onthe cylender head....hope this helps...
Jan 01, 2009 | Panasonic DMR-E75V DVD Player/VCR
Tv/digital converter box & vcr-dvd hook-up
ok cable sat wire goes into input of dvd-vcr input then coming out from the dvd vcr and into the moulator then a wire out to the tv now make sure your vcr is set to the right setting ...now you can record 1 cable..2.vcr dvd..3 modulator...4...tv make sure vcr is set to monitor
Dec 04, 2008 | Philips Magnavox DVD/VCR Dual Player
Panasonic PV-7451 VHS
I don't recognize your first problem.  The "light to dark" issue I believe is intentionally engineered (mine does it too); it prevents recording DVDs on to tape.  Try running the DVD player directly to the TV.  Radio Shack used to have a box that would correct this issue too, you might check there.
T. R.
May 18, 2008 | Panasonic PV-7451 VHS VCR
Picture goes in and out
Yes it sounds very much like it is simply in need of a tuning. Also if you do not feel comfortable repairing yourself, this is a very simple fix that can be done at most any electrical repair shop and usually doesn't cost too much.
Jan 19, 2008 | Sony SLV-D570H DVD Player / VCR Combo
Vhs playback problem
either extremely dirty heads or there is a tv/vcr button that needs to be toggled. Most have auto tracking, old ones have a knob or 2 buttons under a panel somewhere for tracking.
Dec 02, 2007 | Panasonic DMR-ES30VS DVD Recorder/VCR
Mar 12, 2007 | Emerson EWC1304 13 in. TV/VCR Combo
Philips CCB130AT 13 in. Combo Logo
27 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
