Question about Lasko 3440 Wind Tunnel Floor / Box Fan
Fan seems to go and stop and then go again is this normal o
I have one of these. It sounds like you have it on breeze (the 3 wavy lines on the remote) Push that button, then push the run button(first button on the right bottom) for it to run normally. The circle with the blades in the middle(left button on bottom row) will turn the fan from low (1) to (3) high. The icons are the same on the remote and the fan itself. Hope this helps.
Posted on Jun 02, 2009
  • kcapadagli10 Jun 02, 2009
    Sorry! The run button is on the left bottom and the speed control is on the right side. OOPs!
HP LaserJet P2014 imprimindo tudo preto
Voce provavelmente tem um tambor com defeito. Tente colocar em um novo cartucho de impressao Q7553X.
Se o problema persistir apos a substituicao do cartucho de 53X, entao provavelmente voce precisa falar com alguem da HP sobre a substituicao de sua placa de circuito de alta tensao.
Se voce precisar deste em outro idioma, tente copiar o texto para:
translate.google.com
Desculpe se o meu Portugues e ruim, eu traduzi isso do Ingles pelo Google Translate.
Mar 15, 2013 | HP LaserJet P2014 Printer
My 06 charger is running hot changed everything to do with the cooling system,except for the fans witch never kicks on when it starts to get hot what to do
yep you need fans to run that's your problem
there should be a switch located in coolant line that turns em on/off
Jun 27, 2012 | 2006 Dodge Charger
Asus p6t se
harry up change cpu fan or" pemanent damage your cpu if fan is off.
May 30, 2012 | ASUS P6T SE - Motherboard - ATX - iX58 -...
No sound
same here..... like..... iwas using them for while by connectin em 2 my projector.. i gues.. i jus kept em aside for a few days.. whn i tried 2 use em again... it jus BLANK.... sum1 plz... totally in need of help
Jun 22, 2009 | Bose TriPort Consumer Headphones
Heat fluctuation on temp gauge
change the sending unit to the fan, if that doesnt work check for power too the fan or even a bad fan
Mar 22, 2009 | 1995 Pontiac Grand Prix
Win XP re-starts after Turn Off computer.
hi im josh! may i help you? i had the same problem of yours before but it was already resolved.i found out that the power led connection was mislocated. you can found this inside the pc.on the motherboard connection to power button.two small wires there try to check. hope i helped you.good luck.
Feb 19, 2009 | Computers & Internet
Sanyo EM S667W 1000W 240V Microwave.
Please do not operate the microwave (other than short bursts when testing) until the cooling fan is working again.
Otherwise, the magnetron will be destroyed, and that's expensive.
When the magnetron overheats (since the cooling fan is not working) the magnetron thermostat opens up to kill power and protect the magnetron until it cools back down again.
Chances are you have a bad connection, bad relay, or bad component driving the relay on the control circuit board.
If you will scan (at 300dpi if possible) the schematic, and e-mail it to me, along with clear digital photos of both sides of the board, I can probably help you get this fixed.
Feel free to contact me directly (and please remind me of your full model number).
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Dec 12, 2008 | Sanyo EM-W3000W 1000 Watts Microwave Oven
NISSAN TITAN A/C BLOWS HOT THEN COLD THEN HOT AGAIN, MORE COOL WHEN MOVING THEN AT A STOP.
check that your radiator fans are working. what is happening is that when you are stopped, your pump is having a pressure build up since the freon isn't being cooled and possibly the pump will stop spinning and start to screech because of the pressure. When you are moving the fans don't need to run and the freon is being cooled and so everything is working normally. Your fans should turn on while sitting still for a few minutes. If your engine temp is over half, they should be on. Let me know if you have any other questions with this
Sep 04, 2008 | 2005 Nissan Titan
Lasko 3440 Wind Tunnel Floor / Box Fan Logo
258 people viewed this question
Top Lasko Dryers Experts
Shehu Pro
Shehu Pro
Jay Finke
Jay Finke
Are you a Lasko Dryer Expert? Answer questions, earn points and help others
