Question about Intermatic Inc. ST01C Digital In-Wall Timer
How do you set this to go on at a certain time and off at a certain time for the whole week.
The ST01C timer has 40 available programs.
You are going to use 1 program.
First, you set program1 ON time
And then set the days-of-the-week to ALL
Next, you set program1 OFF time
And set the days-of-the-week to ALL
The days for the ON and days for the OFF have to be the same.
The timer gives you choices of M-F -or- WDK weekdays -or- ALL for all 7 days
The steps are shown in section 6 of the manual
http://waterheatertimer.org/Intermatic-st01c.pdf
The following page has large easy-to-read ST01C instructions:
Set ON-OFF times is shown in step 4
http://waterheatertimer.org/ST01C-program.html
The important thing is that both the ON and OFF times have days set to ALL
add a comment if you need more help
Posted on Nov 06, 2010
S there a way to setup weekly specials for say 52 weeks without going thru the inventory maintence specials prices and adding the day each week? Like, I want bud light to be cheaper every Tuesday. Is there...
Hi Bryan,
It sounds like you are trying to use SALE PRICING under SPECIAL PRICING. Use the TIME BASE PRICING instead. This should retain price from week to week. You can set it up for a full day or just 4 to 6PM on a certain day. Once set, you don't need to keep adding it each week.
sysadmin@ccybernet.com
Feel free to email me with more details if need be.
Sep 10, 2014 | Pc America Restaurant Pro Express
Can a 20v lithium battery be used in place of an 18v nicad on my B&D lawn equipment?
aL THE PROBLEM WITH USING A MORE POWERFUL AND DIFFERENT BATTERY IS THEY ARE MADE TO TAKE A CERTAIN MAKE AND VOLTAGE. iT MAY WORK BUT ONLY FOR A FEW WEEKS OR MONTHS. AND I WOULDN'T BE SURPRISED IF THE WHOLE STRIMMER BREAKS DOWN
Mar 14, 2014 | Black & Decker Black and Decker & Grass...
Problem #1. On model #DT300 the instructions under Set Time of Day # 3 does not change the day. The only place I can get the day/s to change is under the programming. What is wrong with it. I have...
Thank you for very clear question, and timer identification.
1) I don't have repair for defective timer.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#DT300
http://waterheatertimer.org/pdf/DT300-series-manual.pdf
2) Choose DT300 format
#3 says to press-and-hold CLOCK button until display shows 24H or 12H
Then release CLOCK button.
Next press HOUR button to select either 12H or 24H
This lets you choose am-pm format -or- choose military-time format where 11pm is 23
3) Set current time
Press-and-hold CLOCK button throughout whole current time setting.
Do not release CLOCK button until current time settings are finished.
Next, press HOUR button, and then MINUTE button, and then DAYS button until current hour, minute and day display.
If this step does not work, then timer has gone bad.
Replace with locally available Utilitec 155671 from Lowes or Westek TE06WHB from Target
http://waterheatertimer.org/Woods-timers-and-manuals.html#59377
4) How to set DT300 timer program for full week of operation.
Each program requires you to set program 1 ON time and program 1 OFF time
Be careful to avoid program conflicts and overlaps so timer works as expected.
For program 1 ON time, you press PROGRAM button until 1 and ON display.
Release Program button.
Then select hour, minute and days. In this case you want all days of week, so you keep pressing DAYs button until whole week displays: Mo Tu We Th Fr Sa Su
Then you set program 1 OFF time, you press PROGRAM button again until 1 and OFF display.
If you set ON time for all days of week, and OFF time for Tu Tuesday, then timer will not work correctly.
5) Read manual and add a comment for additional help
Aug 18, 2011 | Hardware & Accessories
Maytag Neptune Dryer MDE55000AZW As the drum is turning. there is a scraping noise . Not all the time, just as a certain point in the drum hist a certain point in the rotation. Help???
Sounds to me like your bearing and belt would be going out on the dryer you have to take the whole drum out to change this bearing set and belt not the easiest job to do.
Jan 17, 2011 | Maytag Dryers
My dynex tv will not work with dtv while other tv's will. i have tried changeing inputs but still say the signal is week.
can't seem to get my son's 19" tv/dvd combo set to run a movie
it continues to go thru loading then pops up and says no disc. while the whole time it is in the player.
I have treid unplugging the set, I have tried pushing all these buttons and no luck.
Last week our electric service was out for a whole day, and it seems it was around that time this happened. any suggestions?
Jan 05, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Zenith model D52wlcd projection TV has been saying replace lamp for several weeks. Has had a small pink spot in middle of screen. Now full screen is pink. is this a lamp problem or just DOA?
The Lamp will no cause any color distortion. The "Replace Lamp" message comes up after a certain amount of hours after watching the TV because the lamp only last a certain number of hours before needing a replacement one.
It sounds like a light engine problem. There is no quick fix, you need to replace the whole light engine which is very costly (light engines usually run at least $500) and time consuming (need to take whole TV apart to replace part).
Oct 07, 2009 | Zenith D52WLCD 52" Rear Projection...
I just got an LG Vu, trouble w/ ring tones
Go to 'Options' down in the bottom right corner and select 'Set As'. There, another window should pop up and have the options 'Ringtone' and "Ringtone ID'. Ringtone ID should allow you to set it for a certain contact.
Mar 10, 2009 | LG Vu CU920 Cellular Phone
Question:how to set the weekday on a Fossil watch model BQ-9165.
You have to pull out the stem all the way and turn clockwise until you get to the correct day. Hopefully you won't have to wind thru the whole week.
Mar 03, 2009 | Fossil BQ9184 Wrist Watch
Blank screen
please go to www.ge.com request manual
Jan 27, 2009 | GE 74801 Clock Radio
Alarm set for certain days
Depress Alarm1 and hold while you then press the alarm mode button until it shows Mon throught Fri. You will then have both Alamrs set for the weekdays but you can set them to different times.
Nov 23, 2007 | Emerson Smartset Clock Radio
Intermatic Inc. ST01C Digital In-Wall Timer Logo
193 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Steve
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
