Question about Danby DKC645BLS Compact Beverage Cooler
Danby DKC645BLS Kegerator
I just put together my new kegerator and the tap has a steady leak. Without even turning the CO2 on it has a slow leak. Once I turn the CO2 on it is a steady stream. I've tried adjusting the tap by taking opff and re-attaching and it does not seem to have any affect. Solutions??
  • AKBeer Dec 02, 2008
    HELP! We just bought the same kegerator and have the same problem. Did you ever get it solved??
I had the same problem with mine. i fixed it by removing the guts from the faucet and reversing the seal on the closing part. the seal was on backwards, flipped it and no more leak.
Posted on Mar 20, 2010
I have a danby kegerator and the code LE keeps flashing
Sounds like a faulty temperature probe or faulty temperature control circuit. Some modify their unit with an external temperature controller. It does require knowledge of wiring to perform the modification. There are detailed notes, images, etc provided by psychodad at
Thread Danby Kegerator Improvements Part II
Aug 27, 2014 | Danby DKC645BLS Compact Beverage Cooler
Kegerator is flashing "EE" and
I bought a new kegerator and the same thing happened right out of the box.
The display was not pluged in.take Take screws off top and check to see if it pluged in.
Nov 18, 2010 | Danby DKC645BLS Compact Beverage Cooler
Bought a used danby DKC645BLS kegerator it is missing the co2 tank bracket that mounts on the back of the kegerator, where can I find one. Also the psi is set at 10 on the co2 tank and the beer comes out...
mark pasieka has an inventory of refridgeration, kegerator and bar related parts (as well as everything else)... he has this bracket in his warehouse right now... at least one... he also has tanks of CO2, oxygen acetalyne anything you may need...
Oct 06, 2010 | Danby DKC646BLS Full Size / Pony Beer Keg...
Where do I get replacement parts for a Danby Kegerator Model DKC645BLS ?
I have Danby keg cooler touch pads in stock, the touch pads are the most common failing part on the coolers, I also have access to many more parts as well as technical assistance, please ask for Erin (509) 928-7176
Feb 04, 2010 | Danby DKC645BLS Compact Beverage Cooler
Danby Kegerator is beeping and flashing EE and won't cool
I am having the same problem seeing if you found a fix??
Aug 26, 2009 | Danby DKC645BLS Compact Beverage Cooler
Temperature - Is fan supposed to constantly run or is it controlled by thermostat
You said ,Top half of Danby DKC645BLS refrigerator 10 degrees warmer than bottom half. Bottom half cooling to approx. 34 degrees.
Is it running all the time without cycling off and on as it should be doing?
Sorry to have to tell you this news.
But this would mean a bad thermostat or insufficient freon in the cooling system.
The same issue with the fact that one compartment is warm and the other is cool!
Let me know that service tells you!
Thank You
Please remember toleave a rating
Oct 19, 2008 | Danby DKC645BLS Compact Beverage Cooler
Touch pad
I have them in stock if your md# is DKC645BLS or DKC644BLS would be $22.75 after tax and get too you in 3 -5 days my number is 509-928-7176 can do visa or master over the phone.
Aug 20, 2008 | Danby DKC645BLS Compact Beverage Cooler
Danby DKC645BLS Kegerator not keeping beer cold
insulate the tower with pipe insulation, there is a hole in the bottom of the tower. don't over insulate or it will freeze.
Aug 12, 2008 | Refrigerators
Danby DKC645BLS Compact Beverage Cooler Logo
645 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
