Question about Toshiba 32AV500U 32 in. LCD HDTV
Can't get to full screen. I need to be at 1080i
  • 11,361 Answers
The 'ASPECT', 'PICTURE MODE', 'ZOOM' button on the remote will let you adjust the aspect ratio of the display.
The 1080i/p, 720i/P resolution is not done at the TV, its the video source that determine what resolution the TV will display, same way as your PC monitor works, it is control by the PC Video resolution setting.
Basic LCD monitor and LCD TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV, Monitors, Caps : http://s807.photobucket.com/home/budm/allalbums
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Nov 06, 2010
I have hooked up my br to an onkyo home theater through hdmi. i now get an unusable signal on my flat screen. This also happens when I hook it up directly to the tv. What can I do to get this to work
hi,
The Blu-ray player outputs full HD VIDEO (1080p) through HDMI, if your tv is not a full HD one then you can't see the video. Do one thing connect the Blu-ray player to any full HD tv and go to it video setting. Down scale the video to 1080i. All HD ready tvs supports only resolution up to 1080i. only full HD tvs supports 1080p. Down scale the video to 1080i surely you will get video. Also check the version of HDMI cable you have used. It should be 1.2 or above.
ok
Feb 15, 2011 | Sony BDPS570 Bluray 3D Player
Just hooked my Samsung SP-S4243 up do hdmi cable but it won't display full screen.
Sounds like the cable box is outputting in 4:3 rather than 16:9, it should also output in either 720p or 1080i/1080p. Check the settings on your cable box and set them to 16:9 and 1080i/180p. If that does not rectify the problem then you need to look at the settings on your Samsung
Jan 03, 2011 | Samsung SP-S4243 Television
WHAT IS THE DIFFERENCE BETWEEN 1080I AND 1080P AND WHICH ONE IS BETTER?
1080i vs 1080p - Similarities and Differences Between 1080i and 1080p
How 1080i and 1080p Are Both The Same and Different
1080i and 1080p are both High Definition display formats for HDTVs. 1080i and 1080p signals actually contain the same information. Both 1080i and 1080p represent a 1920x1080 pixel resolution (1,920 pixels across the screen by 1,080 pixels down the screen). The difference between 1080i and 1080p is in the way the signal is sent from a source component or displayed on an HDTV screen. In 1080i each frame of video is sent or displayed in alternative fields. The fields in 1080i are composed of 540 rows of pixels or lines of pixels running from the top to the bottom of the screen, with the odd fields displayed first and the even fields displayed second. Together, both fields create a full frame, made up of all 1,080 pixel rows or lines, every 30th of a second.
In 1080p, each frame of video is sent or displayed progressively. This means that both the odd and even fields (all 1,080 pixel rows or pixel lines) that make up the full frame are displayed together. This results in a smoother looking image, with less motion artifacts and jagged edges.
Differences Within 1080p 1080p can also be displayed (Depending on the video processing used) as a 1080p/60 (Most common), 1080p/30, or in 1080p/24 formats. 1080p/60 is essentially the same frame repeated twice every 30th of a second. (Enhanced video frame rate.) 1080p/30 is the same frame displayed once every 30th of a second. (Standard live or recorded video frame rate.) 1080p/24 is the same frame displayed every 24th of a second (Standard motion picture film frame rate.)
For more detalis visit http://hometheater.about.com/od/televisionbasics/qt/1080ivs1080p.htm
Oct 09, 2010 | Vizio VP322 32 in. Plasma TV
Flickering in the main PS3 screen with 1080p resolution
1080 i is what you run going to higher resulution causes that your provider is 1080i or 1080p
May 02, 2010 | Sony Playstation 3 (PS3) Console
How to make a flt screen in to full screen picture
On your remote there should be a ZOOM button that will strech the screen to full screen it may not be a desirable look but most formats today for HD tv is widescreen format also in your menu system you can change this as well. thanks for using fixya please click the accept button.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 18, 2009 | Insignia IS-LCDTV32 32 in. Television
1080i
According to specs, the PLTV-32 supports up to 720p.
That's essentially the same as 1080i, and should work with a 1080i signal.
Mar 19, 2009 | Spectroniq Protron PLTV-32 32 in. Plasma...
Olevia 1080i
how do you you enlarge the picture to show on a full screen, and not black on the sides?
Dec 10, 2008 | Olevia LT42HVi 42 in. LCD Television
Mitsubishi WS-65711 HDTV
The Verizon installer did not set the reciever to 1080i, had to set reciever to 1080i and then push 3 buttons in order on the reciever to take me to the nonstandard menu to check a box so that all channels without 1080 would automatically fill the screen.
Jun 28, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Sharp Aquos LC-32D43U
To adjust screen size, choose the View Mode feature on the top right of the remote control. Zoom size is full screen for watching DVD movies, but sometimes there is still a thin black band due to the formatting of the dvd (unless you buy full screen versions) S. Stretch view mode is best for TV Movies.(usually fills whole screen) Occasionally there are TV movies which just don't respond to being stretched to fill the screen, it's just the way the signal is coming through . 1080i/p detects the resolution of the signal and displays the same number of pixels on the screen, but a 720p signal input will be viewed in full screen.
Jan 25, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Picture size option excludes FULL at either 1080i or 540
All these Toshiba's are defective and we got scammed. Mine and others do this same exact thing. Call Toshiba support and complain to the supervisor to recall these TV's and do right by their customers.
Toshiba Customer Service Group: 800-631-3811 for more assistance.
Jul 22, 2007 | Toshiba 65H82 65" Rear Projection...
Toshiba 32AV500U 32 in. LCD HDTV Logo
166 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
