Question about SVA-USA VR-3200W 32 in. LCD Television
My sva lcd (vr-2600w) recently will not power on. The red light in the corner is still lit up red, but when I push the power button it doesn't turn on. I've already replaced the power board almost a year ago and haven't had any problems until now.
  • 11,361 Answers
Right now you only have 5vdc standby power supply working. It can be the main board, power supply module (bad DC filter caps). You need to open it up and do in-depth troubleshooting.
Basic LCD monitor and LCD TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV, Monitors, Caps : http://s807.photobucket.com/home/budm/allalbums
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitor kits: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Posted on Nov 06, 2010
  • chris_par796 Nov 06, 2010
    I did some tracing and testing and found some bad caps, you are the man!!! Thank you for the much appreciated input!!
  • Bud Martin
    Bud Martin Nov 06, 2010
    Make sure to use good caps, the old power supply probably had bad caps, so what ever they use, they only last a couple of years. You can get a set of caps from the link I put up above or get them from WWW.DIGIKEY.COM, get PANASONIC FM or FC series, they are LOW ESR made for switching power supply, 105c rating, high ripple current rating. I use them in my all repair works.
My monitor has power but the screen does not have a display no matter what control buttons I push
When i plugged in my sva lcd monitor it was all black but the green light was on,so i reached around the back and tightened up my cords and it came on :)
Jan 14, 2012 | SVA-USA VR 17S 17" Flat Panel LCD Monitor
Red light flashing when power button pushed
how many red lights are flashing is their 4 lights all corners lit up or is it 3 red lights with 1 corner not lit up, let me know then i can assist you further
Dec 07, 2010 | Microsoft Xbox 360 Console
Tv does not turn on.... red light on screen does not change to green. Remote control does not work. Checked power supply and green light is lit up
Check the power supply board,for dying capacitors.These capacitors alway bulges up on it tops or puffing up on it tops.These capacitors are dying and not giving the right voltages to the tv anymore.U have tools like a soldering iron,desoldering pump or desoldering braid and solders?U know,how to do basic soldering?Check and replacement of these bulges up or puffing up on it tops dying capacitors.The tv,will work again.
Oct 14, 2010 | SVA-USA VR-30W 30 in. LCD Television
I have a SVA VR 30 LCD TV that for some reason stopped working. It was work last night-the little on/off light was lit when I turned it off. This morning it wasn't and my husband changed the power strip,...
The power supply may have failed due to bad DC filter caps which you can easily look at them for sign of elaking/bulging top first.
Post back what you see inside so we can guide you further.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make a kit for you.
Aug 13, 2010 | SVA-USA VR30 30 in. HD-Ready LCD...
Display or power issues with my 17'' LCD screen (SVA LCD #7500L )
Check the high voltage ballast transistor.. see if one of them is burnt... If none.. it could be overheating when supply with current. The ballast transformer supply high voltage for the backlight inverter..If these were overheating then the supply voltage for your monitor will be unstable.
Check also the backlight inverter (cold cathode light) if it is busted.. the function of this backlight inverter is to give display image on the screen.. If these were busted then what you will be seeing is black on your screen. You can also replace this.
Please rate this solution if this help you. thanks..
May 27, 2010 | SVA-USA VR 17S 17" Flat Panel LCD Monitor
I CANT GET MY MONITOR TO TURN ON
It could be the Monitor, the VGA adapter, or the PC itself. If you power on the monitor without anything connected to it, do you ever see anything on the display?
If not, it is probably the Monitor. If yes, it is likely the vga adapter and/or PC.
Mar 18, 2009 | SVA-USA VR 17S 17" Flat Panel LCD Monitor
I have a sva vr-30 that wont turn on no red or green lights
If you don't have a standby light and if the unit does not even make any clicking sounds or try to come on at all then you have a bad power supply that will need replaced.
Jan 03, 2009 | SVA-USA VR30 30 in. HD-Ready LCD...
Va 3222w sva 32" television
It is still under warranty. Unless you have a in-house warranty, you will have to send it in for repair.
Nov 14, 2008 | SVA-USA VR-20 20 in. HD-Ready LCD...
SVA TV
Was it working befor you got it off your friend???
Apr 20, 2008 | SVA-USA HD4208TIII-VR 42 in. Plasma...
Sva-usa vr30
I've experienced the same problem with my VR-30 and what worked for me was I actually unplugged the power from the TV, waited about twenty seconds and then reconnected and when I turned it back on it worked fine. I've had my tv for about 2 1/2 years and I've had to do this probably a half dozen times so I've gotten used to it. Hope it works for you too.
Apr 02, 2007 | SVA-USA VR30 30 in. HD-Ready LCD...
SVA-USA VR-3200W 32 in. LCD Television Logo
184 people viewed this question
Top SVA-USA Televison & Video Experts
Henry  Thomas
Henry Thomas
Tony
Michael Galve
Michael Galve
Are you a SVA-USA Televison and Video Expert? Answer questions, earn points and help others
