Question about Black & Decker ASI300 Air Station Inflator
Black & Decker ASI300 Air Station stopped working. I think it is ac/dc switch related.
SOURCE: Black and decker air station not turning on
There's a small PCboard fuse (F1) inside. Remove the six phillps head screws from the bottom plate to expose the PC board. I'm not sure of the fuse size but I'd buy more than one. This seems to happen frequently with these units.
Hope this helps.
MM
Posted on Jun 02, 2009
rowdy45176
  • 2176 Answers
SOURCE: Air Station Inflator Model #:ASI300
Cant find any information on this tool at their website but did find that it has a 2 year warranty. I would try and take it back and get it repaired or replaced at no charge.
Posted on Aug 25, 2009
  • 4 Answers
SOURCE: Describe your Black & Decker Black
If it is not 2 years old, it is covered under warranty: http://www.blackanddecker.com/CustomerCenter/Warranty.aspx
Posted on Nov 17, 2009
SOURCE: black and decker air station will not turn on
  1. Take off the bottom(6 screws philips2_bing.gif)look for a small glass fuse Marked F1 that is soldered in place.
  2. Cut this fuse out(cut as close to the fuse as possible)
  3. Replace fuse(1.25amp 250Volt) You can find on e-bay search by 1.25 amp) there is a fuse with the wire already attached on it....solder new fuse in place.
  4. If you dont want to wait to order the fust just solder a wire into the fuse area(you will have no surge protection but it may worth the risk because the frequncy this fuse keeps blowing.
Side Note: It may look like the fuse is O.K. but trust me its blown.
There are 2 compessor bellows keep in mind they don't both run at the same time One is for AC the other for DC.
Posted on Mar 24, 2010
SOURCE: black and decker air station won 't work
My Air Station blew a fuse also. The fuse that came with the inflator may be a bit too small amperage wise so I stepped up to .25 Amps more which is just a very small increase.
It is really ill advise to solder a wire in the place of a fuse. You are just asking for it.
The way I did it is I went to my local Radio Shack and got a small fuse holder with red leads and 1.5 Amp fuses. I soldered the fuse holder in place with the new fuse. And now I don't have to deal with any more solder. Just twist the fuse holder, take out the burnt out fuse and replace it with a new one. And wahlah. I'm back in business again.
Posted on Dec 18, 2010
Air station inflator - catalog #AS1300 - THE owners manual tells of a fuse that may have blown.. if it won't start, where is the fuse, located?
Black & Decker asi300 part 3 - YouTube
? 21:26
www.youtube.com/watch?v=wU8KTnKVCG0
Jun 6, 2014 - Uploaded by Brian Flugga
I just put a new fuse holder in it with a 1.5 amp slow blow fuse. ...Black & Decker ASI300 Air Station 12-Volt or 120-Volt Inflator
Aug 19, 2015 | Cars & Trucks
Black decker instructions
Go here: http://servicenet.blackanddecker.com/Parts/Search?searchedNumber=Model%20#%20ASI300
You will need the Model #, there are instructions for locating this and it will connect you with the Instruction manual.
Aug 16, 2014 | Black & Decker ASI300 Air Station Inflator
How do I change the F1 fuse on the B&W Air Station?
  1. Take off the bottom(6 screws philips)look for a small glass fuse that is soldered in place.
  4. If you dont want to wait to order the fust just solder wire into the fuse area(you will have no surge protection but it may worth the risk because the frequncy if this fuse blowing.
  5. It may look like the fuse is O.K. but trust me its blown.
  6. There are 2 compessor bellows keep in mind they don't both run at the same time One isfor AC the other for DC.
Dec 12, 2009 | Black & Decker ASI300 Air Station Inflator
Black and decker air station will not turn on
Dec 06, 2009 | Black & Decker ASI300 Air Station Inflator
Aug 25, 2009 | Black & Decker ASI300 Air Station Inflator
Hope this helps.
MM
May 29, 2009 | Black & Decker ASI300 Air Station Inflator
Black and decker air station won 't work
Apr 04, 2009 | Black & Decker ASI300 Air Station Inflator
Black & Decker ASI300 Air Station Inflator Logo
164 people viewed this question
Top Black & Decker Tools & Hardware - Others Experts
Jim Goldsmith
Jim Goldsmith
Are you a Black & Decker Tool and Hardware - Other Expert? Answer questions, earn points and help others
