Question about InFocus Proxima DP6155 Multimedia Projector
Power button is flashing green, no image displayed
I had the power on and off cycling issue described in another post and when I reassembled the projector I forgot to plug the two wire plug back into the power board. The power light flashed. I removed the top cover and plugged it in and the projector is now working perfectly.
Posted on Dec 29, 2010
No power output or display.green standby light flashes.
Sounds like either a blown mainpower fuse or the thermal fuse for the power transformer. If the protect circuit was kicking in, the display would light up, but then turn off with a red blinking light. the green light with no display means the transformer is not getting power.
Dec 31, 2013 | Denon Avr-1610: 5.1 Ch A/V Home Theater...
Samsung camera problems
when trying to power off the camera a green light which is on the right corner blinked and the images are displayed continuously. What could be the problem?
Apr 25, 2013 | Samsung ST30 Digital Camera Pink
Power on green light flashing no display on da monitor
The flashing green light and no display usually means that the backlight circuit has failed. You can verify this by shining a flashlight on the dark screen and see if there is an image. If there is an image, then the problem is the backlight circuit. Often the problem with the circuit is that the transistors burn out. There are sellers on ebay that sell repair parts kits to fix these monitors if you are handy or you can bring to to an electronic repair service to have it fixed.
Apr 19, 2011 | Dell Computers & Internet
Monitor problem
The power light is flashing green can indicate start/restart of the power supply due to shorts circuits or failing power supply due to bad caps, look for bad caps with bulging top first, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Post back what you see insdie so we can guide you furhter.
Feb 20, 2010 | Acer 17" AL1706B LCD Monitor
Screen suddenly does not display image just
There are two places to look for the problems, the backlight inverter board and the power supply, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Nov 19, 2009 | ViewSonic VA912BWB 19" LCD monitor
Error 22
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Jan 28, 2009 | Canon PIXMA MP150 All-In-One InkJet...
The screen doesn't display anything and the power button is flashing green
Ok I got the same problem. And this is the way how to examine where the problem is. You have to check that you can see the image on screen by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons (Power on both cpu and monitor), there will be a minor problem. Like me, I can see window image using flashlight and check lamps inside. Some of them were broken. If you cannot see any icon on the screen. I would say that there are some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or dark spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so.
Nov 30, 2007 | Dell E173FPb 17" TFT LCD Monitor
Redeye
Red-eye is actually caused by the light from the flash bouncing off the back of the retina and picking up the color red from the blood vessels. To correct this effect, follow these steps: Turn the mode dial to PlayBack Mode (green arrow) and display the image with redeye. Press OK\Menu button. Using the arrow pad, navigate to MODE MENU>EDIT>REDEYE FIX. Press the right arrow key, START will display. Press OK\Menu After {BUSY} bar displays, a screen will display with an option to cancel or save the image. ? If the option [Go] is displayed, press the OK\Menu button. This saves a corrected version of the image. ? If the option CANCEL is displayed, than the camera was unable to correct the image. Press the left arrow key to exit. This correction may not work on all pictures. If you import the original image into Olympus Master software you can also apply the Red-Eye fix located in the Edit menu. This lets you precisely pinpoint the eye area and remove the red. It even lets you remove green or blue, which can occur with animals.
Sep 04, 2005 | Olympus C-7000 Zoom Digital Camera
Redeye
Sep 04, 2005 | Olympus Camedia C-5500/C-55 Sports Zoom...
InFocus Proxima DP6155 Multimedia Projector Logo
168 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
