Question about Microsoft Xbox Console
Power cord or console problem?
The xbox we were given, crackles when the power cord is attached. Which has the problem - the cord or the unit itself? Unit doesn't turn on at all - no red or green light showing either. I am now thinking the power supply might be the problem? A friend brought over their power cord with the same results ours got.
  • M_Tamer_koky Oct 20, 2008
    my power supply is burned and i dont know haw to remove the xbox cover to changee it
    Problem Solver:
  • 11 Answers
This Could Be The Wrong Power Cord Maybe Overload or Under
load Via The Power Cord.
Posted on Jun 30, 2008
The light is flashing orange on adapter and no power to system when turned on
It is possible that there is some foreign particles inside one of the connectors. Since the power supply does come apart and also disconnects from the unit, you can try to clean it to see if it will sort out your problem. Here's what to try:
1. Disconnect the AC adapter from the wall and the console. Let it rest for a few hours so that you do not electrocute yourself.
2. Disconnect the wall power cord from the AC adapter brick. Check the connections on both ends to see if it needs to be cleaned.
3. Clean any ends of the adapter with alcohol solution (isopropyl, or "rubbing" alcohol). Make sure the connection to the console is clean as well. Allow to dry.
4. Reconnect all necessary parts and try your console again.
If that does not work, there could be another problem with power flow to the AC adapter or a problem with the adapter itself.
Feb 28, 2011 | Microsoft Xbox 360 Console
My xbox has a three light red ring
Let's unplug and reconnect your power supply
  1. Disconnect the power cord from the back of your console. Unplug the power cord from the wall outlet and the power supply unit.
    Reconnect the power cord to the console. Then plug the power cord back into the wall outlet and the power supply unit.
  2. Make sure that all three connections are firmly secured.
  3. Turn your console back on.
    Check the light on the power supply. If this solution worked, your power supply light will be green and the power button will look like this:
Dec 29, 2010 | Microsoft Xbox 360 Console
Orange light flashing in powercell pack.console not turning on. tried different powercell pack still not working .used power surge adapter
Hi,To troubleshoot this problem, try the following steps:
Examine the power indicator light that is located in the center of the Ring Of Light on your Xbox 360 console. If there is no power to your console, the indicator light is off and the fans are off.
* Press the power button. The power button and the power indicator light are located in the center of the Ring of Light on the front of your Xbox 360 console. If your Xbox is functioning correctly, the power will turn on.
* Press the eject button on your console disc drive. If your console turns on when you do this but does not start when you use the power button, there may be a problem with the power button or the console faceplate may not be attached correctly. Contact Xbox Customer Support for more help.
If the above step does not resolve the problem, examine the power cord where it connects to your console and to the power outlet. Disconnect and then reconnect the power cord at each end to make sure that you firmly connect the cord.
If this does not resolve the problem, see whether the power cord is plugged in to any device other than a typical power outlet. For example, the power cord may be attached to an extension cord. If this is the case, remove this device and then plug the power supply directly into a power outlet.
If the problem is not a connection problem, examine the light on the Xbox 360 Power Supply.
* A green light indicates that the power supply is functioning correctly. If the light is not green, contact Xbox Customer Support for more help.If these steps do not resolve the problem, your console needs service.
Thank you!
May 11, 2010 | Microsoft Xbox 360 Console
Xbox flashing red screen jumbled up and saying system error
Power off xbox, unplug av cable from back of xbox.. power up unit without av cord.. unit will shutdown within 5-10 minutes by itself.. plug the av cord back in and power up.. good Luck
Jun 30, 2008 | Video Game Consoles & Games
Xbox flashing red around the on button. screen is in chinesse says contact support. not loading. number E74 on the bottom of screen.
Hi, power off xbox remove av cord from back power up unit.. After a couple minutes the xbox will shut down by itself once it does Put the av cord back in and power up.. Good Luck
I have an xbox 360 which is defaulted wen i turn on instead og green light there is a red light too.
turn off xbox, unplug the av cord from back of xbox.. power up unit without av cord.. wait til unit shuts off by itself.. reattach the av cord and turn it on..
Automatically goes to error E 74
My xbox360 has 3 flashing red and will not respond to anything except turning the unit on off and opening and shutting
My xbox 360 has one flashing red light, and it keeps showing me the code E 74
Jun 29, 2008 | Video Game Consoles & Games
The console will not come on
Jun 29, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox Console Logo
111 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Troy Gorman
Troy Gorman
marley mcelhinney
Pablo Gonzalez
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
