Question about Welding Tools
Lincon mig 100 need wire feed wheeh for solid & flux core
  • 407 Answers
Solid wire drive rolls are not the same as flux core. Solid are U-grooved while flux cores are knurled. Any welding store can get it for you. Perhaps you can find one that has twin groove.
Posted on Jan 13, 2011
Can I use 0.030 Flux Core Wire in my Lincoln Electric SP170-T?
Use the .030 flux core wire with the amperage settings for .023 solid. If you cannot find .023 settings then just set low power first and play with it to see what works.
Aug 26, 2014 | Welding Tools
Very little power at wire
try to use bare .032 wire and co2 shielded gas, If the equipment does not have a gas solenoid you may have to wire a solenoid to the trigger mechanism to get the gas to flow while the wire is feeding. The bare wire usually copper coated burns much hotter than the flux core when there is a gas shield. Also a .032 bare wire with a gas shield burns a a lower amp range and will get better penetration.
You may have to experiment with the feed rate and gas flow to get the correct setting, but the bare wire has a lot less resistance to current flow than the flux core and will burn a lot hotter when you use a gas shield.
At 115 vac there is not a lot of amperage left to create an arc and run the feeder and the rest of the unit , and the flux core wire takes a lot of amperage to burn both the wire and the flux . .
Apr 03, 2014 | Campbell Hausfeld ® 115V MIG Flux Core...
Lincon mig stops feeding wire
Been welding for a while, open side, check for proper tension on the feed wheel inside side panel, hit the trigger, if feed motor continues to spin tensioner needs tightened or mig wire may be getting hung up inside main cable lead. If motor is off on off on then its probbably the switch on the trigger getting a bad good connection, hope this helps o and check welding tip on gun end, may need replaced if worn or melted, unscrews.
Mar 05, 2012 | Welding Tools
SMALL PUDDLES NO PENATRATION WELDER IS FARM HAND 115 VOLT MIG//FLUX CORE WIRE FEED PUT ON ANY SETTING NO DIF CANT FIND MODLE IT HAS CHPOWER.COM WEB ADDRESS
Hi:
If you are using flux core wire you need to switch the polarity of the machine. With flux core wire, your ground clamp becomes positive (lead) and your gun the ground. All you need to do is switch the cables above the feed rolls.
That will take care of the problem
If this was useful to you, please vote. Thanks.
Mar 20, 2011 | Campbell Hausfeld Welding Tools
When i weld with my wire feed it pulses what am i doing wrong
you need to ether turn up the wire speed or turn down the heat, also with a flux core you have to be very close to your work. don,t forget your mask!!
Jan 16, 2011 | Firepower Flux Core Wire Feed Welder 88...
I have power mig 100welder wire come out slow
Make sure that the wore feed wheels are tight and the is nothing in the way if the wire when flowing
Nov 19, 2010 | Firepower Flux Core Wire Feed Welder 88...
Can i use the spool roll of mig wire in a hobart 120 mig machine?
If it is a wire feed, yes. You just have to make sure what size and flux core or solid. Run flux core .035 4" spools. Or .030.
Oct 06, 2009 | Welding Tools
What is required to switch from steel to gas on light duty mig welders
if you mean from flux core wire to gas shielded wire you will need a tank and regulators,and feed hose from the welder to the tank
Sep 06, 2009 | Lincoln Electric LE 83180 Century...
Lincoln mig pac-100 low heat on highest setting.won't weld 20 ga.
if you are using flux core that might be why, flux core burns hotter, try using 75/25 or more argon than co2, as your gas, the gas will keep it a little cooler, keep your amps down and match the wire speed to the amps, which would be slower wire speed
Apr 15, 2009 | Lincoln Welding Tools
Welding Tools Logo
98 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
