Question about Microsoft Xbox 360 Console
Xbox 360 one red light bottom right - Microsoft Xbox 360 Console
  • 67 Answers
If you get the Xbox 360 1 red light message, it means that the problem is either with the DVD drive, or with the hard drive.
Fortunately, the Xbox 360 1 red light message is not something that you should worry about. In order to identify which of the two drives the Xbox 360 1 red light messages is referring to, just look the code number that the screen displays. DVD drive errors are identified with the codes E64, E65 and E66, whereas hard drive errors are identified with codes E67, E69 and E79.
Once you identify which error the Xbox 360 1 red light message is pointing to, fixing it is really easy. The guide available at Fix-xbox360.info will tell you what to do in each case, as well as what to do in case you get any of the other Xbox 360 lights messages. Check it out.
Posted on Feb 01, 2011
  • 34 Answers
SOURCE: 360 Xbox problem Three red rings
Unfortunately there is nothing that you can directly do to fix this problem.
You have a hardware failure. Microsoft will repair your unit for you under warranty / recall.
http://support.microsoft.com/kb/907534
Sorry to be the bearer of bad news.
If my solution was helpful, please vote for me!
Posted on Nov 16, 2007
  • 85 Answers
SOURCE: xbox 360 1 red light
E64: DVD Drive Error.... DVD Timeout, Wrong firmware, dvd is without f/w chip, etc.
If your system is underwarranty i would take it back to get a new one if not you will have to call MS and see what it will cost you to get it fixed.
Posted on Dec 17, 2007
  • 10 Answers
SOURCE: As playing Xbox 360 system shuts off two red lights occurs.
Two red lights mean your 360 is over exceeding the inside temperature. Your fan must not be working at all and your 360 is overheating tremendously. That is what I know about the 2 red lights. Im not sure what to tell you to fix this but to just call 18004myxbox.
Posted on Mar 15, 2008
Puterwiz82
  • 60 Answers
SOURCE: MY XBOX 360 HAS 1 RED LIGHT FLASHING, WHEN STOOD
one red light flashing on the ROL of your Xbox 360 console that's an indicator of a hardware problem with the console connection to one of the parts connected to it as the hard drive or cables. first disconnect all power and AV cables from the back of your Xbox 360 console and also unplug the power cord from the wall socket, wait for a minute then reconnect them all back and try to turn on your Xbox 360 console once more. If that doesn't work, it seems then to be a fault with your Xbox 360 hard drive so turn off the console again and remove the hard drive then turn on your Xbox 360 console without the hard drive, supposed then to work fine, it might be an intermittent issue and when you reconnect the hard drive your Xbox 360 will work fine all after, or it will just work fine without the hard drive so it will be then definitely a fault with your Xbox 360 hard drive so call Xbox 360 customer support to exchange the hard drive for you. The Xbox 360 console might even keep giving you the same error code even after you remove the hard drive so it will then appear to be a fault with your Xbox 360 console not the hard drive & also in a case like this we need to contact Xbox 360 customer support to exchange the console.
Posted on Jun 06, 2009
  • 24 Answers
SOURCE: i have a red flashing light on my start button in
what you need to do is disconnect the xbox from your tv and wrap it in 2 towels turn it on and leave it for 30 to 45 min it should be very hot after you can feel the heat through the towels turn it off. DONT take off the towels let it sit and cool for an hour reconnect it and play. this may not work but it most likely will if it does not work you need to buy a new xbox
Posted on Nov 20, 2009
I started my xbox360 and my controller won't connect and then a red light came on in the right bottom of the circle .what do i do ? Or what is going on?
Dec 26, 2010 | Microsoft Xbox 360 Console
One red light on the bottom right on the power button
XBOX 360 Red Light error, or Red ring of Death RORD is a very common issue, and can happen anytime. There are different Error numbers related to RoRD, and appears on screen starting with "E".
Red light problem can be fixed! there is a XBOX 360 repair guide available that covers this problem and also all other common XBOX problems. You can get your copy XBOX 360 Repair Guide, you can download it and get help to fix your console.
click here to download repair guide......
Oct 07, 2010 | Microsoft Xbox 360 Console
Wont load,blinking red light on the power button
if it is the top left, bottom left and bottom right lights blinking red, this means that there is a hardware failure in your xbox 360 and there is no current way to fix this. i recommend that you send it in to xbox to see if they can do anything, and if not, they will possibly send you a new xbox 360.
Sep 27, 2009 | Microsoft Xbox 360 Console
My bottom right light on my xbox 360 is flashing red!!!
take a look at this website, see if it helps.
It makes all the errors clarified. i found out that my disc drive crapped out and that its overheating because of it, I have two red lights on my left.
www.xbox-scene.com
Sep 06, 2009 | Microsoft Xbox 360 Console
Switch on xbox withing 5 seconds a red ligh appears bottom right but if you turn the xbox on ots side the red light slips to the bottom right no sinal to television
This is the video chipset failing, couse: heat problem, the main board expands by the generated heat then cousing the solderings of the video schipset to brea, get the xbox to a repairs man.
Aug 28, 2009 | Microsoft Xbox 360 Console
Xbox 360 e74 error
Having the e-74 code is when the video chip on the 360 over heats and becomes un soldered your best bet is to turn the 360 on with a towel over it and wait for 3 red lights the call microsoft and tell them the 3 lights issue dont mention the 1 light or it will cost you dearly around 150$
Mar 17, 2009 | Microsoft Xbox 360 Console
Exbox 360
You can check out the informative blog post at http://www.fix-xbox360.info/2008/09/11/xbox-360-disc-read-error-e74-error-no-video-problem/
This post describes the E74 error with one red light problem.
hope it helps...
Jan 05, 2009 | Microsoft Xbox 360 Console
One red light bottom right hand corner
hope it helps...
Jul 22, 2008 | Microsoft Xbox 360 Console
X box 360
red lights means there is an error usally can be fixed make sure all cables are CORRECTLY plug in. Second make sure it is a proper xbox or xbox 360 game.
Nov 02, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
507 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
