Question about Kenmore Dishwashers
No drain, opened to c if there is a blockage but in vain
  • Kenmore Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will not drain out
heatman101
Posted on Nov 06, 2010
My washing machine will not drain out its load and the door will not open
drag machine to an open door lay drain hose out the door,......this will allow water to drain...............then ..when machine is enpty...............check the pump for blockage,.....
cheers
Aug 03, 2017 | Washing Machines
Zanussi wfd1257w giving E11 error on dry cycle. Is there a way to further diagnose the fault?
Hey Rich,
Error Code E11 means that your Washing machine has detected an overfill of water - over filling with water
  • Check drain pump for blockage or obstruction
  • Check drain hose for blockage or obstruction
  • Check drain pump
  • Check fill valve is not jammed open or leaking
  • Check electronic control module
Good Luck
JP
Jun 04, 2015 | Zanussi Washing Machines
My ge gts201cncww fridge has ice freeze up in the bottom of the freezer and water drips into the fridge and freezes the fresh food
the drain tube behind the inside rear freezer wall below the drain pan there is plugged,remove rear inner freezer panel you will see the drain tube take a piece of hose and insert it down this drain hole and seal the drain opening as best as possible the blow into the hose to remove blockage,a piece of wire will work too,but the drain is not a straight run and getting a wire down there to remove blockage is difficult,then also put very hot water into the drain hole to help melt ice if this is the blockage problem
Feb 12, 2013 | Refrigerators
I cannot get my water heater to drain, opened valves did everthing I'm suppose to Help?
the bottom is plugged with calcium deposits and is blocking the drain valve at the bottom,try using a small wire to dislodge the blockage from there or try hooking up a water supply and forcing the blockage backward,if your just removing the whole unit,then you can lay it on its side and let it drain from the top fill ports
Jan 06, 2011 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
My hoover 540 washing machine started making funny noises a couple of loads ago (loud banging noise during spin cycle). Now it goes through whole cycle but when it gets to 'drain' part of the cycle,...
Sounds like a blockage in the outlet pipes or filter. It may be possible to drain it if you can get the outlet pipe (one from back of machine) outside, lay it flat on the ground as this will take it below the water level in the machine and may slowly drain. Once it drains out enough the machine should disengage the door lock to allow you to open it. Then check your filter and pipes for blockage. If no blockage is found then suspect faulty pump.
Jan 25, 2010 | Washing Machines
The washer goes into spin cycle but the water will not pump out. I've checked the fuse and it is good.
hi there......if the water will not pump out its a fair bet you got a problem with the drain pump.....first open and clean out the filter unit...then try drain cycle on machine...ok....if not ok...remove and check drain pump for blockage....remove bottom hose to drain pump from machine and check for blockage in the hose and also for blockage in drum...sock etc...reassemble and all should be well again
regards Sir Galahad
Sep 03, 2009 | Washing Machines
Same problem
Below is the service manual. Use the FU (fill water) function in the diagnostics and then use P2 to drain the water. Open the drawer and watch will testing.
Good Luck
http://www.scribd.com/doc/6462163/DD601V2-Manual
Jul 11, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
WATER WILL NOT DRAIN OUT
Sounds like either you have a blockage in the drain pump or the drain hose is blocked.
The washing machine will run the drain pump for about 2 to 3 minutes to empty water from the drum then stop automatically.
If the pump is blocked or the drain hose blocked or kinked then water will be left in the drum.
Blockages are usually caused by buttons, bra wires or metal objects from pockets eg coins.
The pump can be popped open using simple tools ie screwdriver and any obstruction removed easily. The drain hose can be detached and a metal object eg knife dropped through to test for a blockage.hope this helps
Jun 01, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
Water not draining after the wash cycle
Apr 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machine won't go through spin cycle
To get the water out, lay the emptying hose down at floor level into a bowl, tip the water down the sink a bit at a time, then check for a blockage in the outlet filter, or the pump
Oct 24, 2007 | Washing Machines
Dishwashers Logo
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
