Question about Toro 42'' Zero Turn Lawn Mower 22hp Kawa Consumer
I have a Toro Zero Turn mower that won't start. I have replaced the battery and have tried jumping it with a Auto but no favorable results. The engine will turn over untill the starter meets resistance from the engines compression and then the starter just clicks. If by chance it does start then it will start again the same day easy but if I leave it for a day or two it will not start. I replaced the starter mid summer.
  • Jim Long Oct 04, 2012
    I have the exact same problem.
    Still looking for a solution.
    Problem Solver:
  • 13 Answers
Two things possible you have a sticking float or if its old enogh the electrical ign system is going to have to be replace cheap and easy if the model is old enough this electrical ign takes the place of points and works the same
Posted on Nov 06, 2010
Make sure "motion control levers" are completely out so brake is engaged. Is blade engage button depressed? Choke up?
The "motion control lever"s not being all the way out got me the first few times.
Posted on Jan 21, 2011
  • CJohns35 Jan 21, 2011
    One other thing. The "bypass levers" for manual pushing MUST be put back in the motor drive position before starting. It's a safety thing.
Just purchased a toro zero turn mower at garage sale. Ran very well first couple weeks. I was running it the other day, shut it down, jumped back on 10 mins later, mower does not start.
You'll need to check all the safety switches. Probably one in the seat, one for the mower engaged, one for clutch/parking brake engaged, possibly one for reverse gear selected, and possibly for position of the steering arms.
Nov 15, 2016 | Cars & Trucks
Can you jump start a toro zero turm mower with a car battery and jumper cables?
Better to not jump them can burn the leads up. Pull it out and slow charge it
Jul 17, 2014 | Toro NEW 42 TIMECUTTER 21.5 HP KAWASAKI...
Timecutter z4200
If you were able to jump start mower then the problem lies with the battery connections or battery itself
Jul 11, 2014 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Toro timecutter won't turn over with key
Sounds like the solenoid is bad. Most solenoids connect positive + from the battery. One side will read 12 volts (with the black wire of a test meter or test light. (The side connected to the battery). Energize the solenoid (loud click) And with the key held, check the other side for voltage. No voltage, bad solenoid. Be careful when you buy a replacement. Many look the same but do different things.
Apr 09, 2014 | Toro TimeCutter Zero Turn Lawn Mower...
John Deere Z225 trouble starting - turning the key to start, you hear the starter engage. The engine trys to turn over but struggles. Sounds like the battery is low. Bought a new battery, charged it...
The symptoms described may indicate a bad starter. First check all connections from the battery to ground and from the battery to starter You may want to have the starter tested at Advance Auto or Auto Zone. It will need to be removed from the mower, and I am not sure if Auto Zone, Advance Auto can test small mower starters. They test the starter under load, so if you remove the starter and hook it up to a battery, it will run probably, but it will not indicate whether the starter is good or bad. It needs to be tested under load. Good luck.....
Mar 18, 2014 | John Deere EZtrak Z225 Zero-Turn Riding...
1642Z won't turn over
jump direct to the starter if it cranks over check the safety swithes
Aug 11, 2012 | Toro TimeCutter Zero Turn Lawn Mower...
TORO ZERO TURN MOWER WON'T TURN OR MOVE ONE WAY
This page says there's one solution. What is it? Where is ti?
Apr 13, 2012 | Toro 60'' Zero Turn Lawn Mower Enclosed...
I have purchased a Toro zero turn mower and can't get it to start. It has gas, I charged the battery. It makes a clicking noise when I turn the key but motor won't turn over. Is there any special way to...
no,,just turn the key to start her up!,,,if the engine is free to turn i gess it has a stuck starter relay or a jamed starter, or a dirty power/earth lead or joint some were
but check that this battery you charged up is any good first if the battery has been left standing in a discharged state it wont be any good any more,,try a set of "jump leads" from a good car battery!
Jul 27, 2010 | Toro 60'' Com Zero Turn Lawn Mower 27hp...
Toro 42''  Zero Turn Lawn Mower 22hp Kawa Consumer Logo
2,385 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
