Trying to connect to Westell 6100G but lost password. What are the defaults after reseet button is held in?
    Problem Solver:
  • 6 Answers
After reset... defaults for Westell.... should be
Username=Admin
Password=password
IP Address= 192.168.1.1
Posted on Nov 06, 2010
Cannot connect through verizon dsl westell 6100g modem
Call verizon dsl and make sure you have your account username and password (given to you by verizon when the connection was put in your home) when you get them on the phone. also make sure you have the username and password for your Linksys device.
Aug 14, 2012 | Linksys Wireless-G Broadband Router
Hi I want to know on how to setup the verizon Modem/Router I already have a Westell 6100G and i want to upgrade to the new one called Verizon Wireless modem/router model:GT704WG.
Are you on Consumer Verizon DSL? Fair warning if you are using Business Static- the Actiontec is a poor choice due to issues working on a static IP circuit. - I'd use a 6110 and a third party router! However, by default, the only thing you would need to do to setup the modem is go through the activation page when you plug the modem in. If you require an user name and password, it would set that up. Bar any problems, you can contact Verizon technical support since the Actiontec Gateway is fully supported.
Aug 28, 2010 | Actiontec GT704WG Wireless Router...
AT&T Westell modem keeps dropping internet and i have to unplug power cord and reconnect to regain connection at least twice an hour
If that is a westell 6100F series, that is the problem. Westell admits they had trouble with that series staying connecting. Try finding a westell 6100G. I had the exact same problem with verizon.
Nov 08, 2009 | Westell Wirespeed LiteLine 6100...
Im looking for westell 327 passwords i bought a router at a yardsell and didnt know i had to have a password will u please helpme PLEASE?? thanks
Default user is: admin
Default password is: password
Reset the router (hold the small button for at least 10 secs while router is on) and try above.
Nov 07, 2009 | Westell Wirespeed VersaLink...
Westell 6100g has a solid orange DSL light.
It is verizon faught. I had a tech guy told me if there i no green dsl light your are not getting any signal from the co.
Sep 18, 2009 | Computers & Internet
I have a Westell router through Verizon. My wireless connection is working fine, but I want to login into the router so I can change the default user name and password for better security. (For those who...
sometimes the default gateway is not always 192.168.1.1 sometimes it is actualy your ip adress for example 192.168.0.1 but that won't always work so go to command prompt and type 'ipconfig" and press enter first try your ip and then try the default gateway... for any more help please pm me for any more help...
Jun 06, 2009 | Westell Wirespeed VersaLink...
What Is The WEP For A Westell Modem, Model 7500 A90-750015-07
The WEP key is located on the silver label on the bottom of each unit under the Serial Number and is clearly marked on my unit.
Mar 21, 2009 | Computers & Internet
Westell versalink 327w i need default password
If the 327 was never set up for wireless you need to connect to it with an Ethernet cable and plug that into your Mac and one of the RJ45 ports on the back of the 327. Type http://192.168.1.1 into your browser, this should take you to the Westell Home Page (Your Router). The default for wireless in this router is disable. There are tabs across the top on the page, select Configuration>Wireless>Basic. This opens the Wireless Operation Window. If Wireless is disabled, click arrow to enable. You can also enable and disable encryption in this same window and if you choose to use the basic WEP in the device, the WEP key is on the label on the bottom of the router. If all this is good your laptop should be able to detect the wireless connection, the default is the serial number on the bottom of the router so you will know which connection is yours. REMEMBER TO CLICK SAVE before exiting the window! Hope this helps.
May 21, 2008 | Westell Wirespeed VersaLink...
No connection
basically if the internet light on a westell modem is red there are just some settings that has to be change on the modem set up,, it depends in the protocol that you are connected.. for westell 6100 lite,, the default address for the settings is 192.168.1.1,,,,,, click start button then click run on start menu, input http://192.168.1.1 then ckick ok...you will directed to the westell set up page,, default username for modem security is admin and default password is password,, then edit conection - if it promts to input a connection name, account id and password pls contact your ISP to get the infos.... if not just ckick release then renew
Mar 14, 2008 | Westell Wirespeed LiteLine 6100...
Computers & Internet Logo
100 people viewed this question
David Payne
David Payne
