Question about Maytag EPICz 3.7 cu. ft. Washer
My washer turns on all the light go on but when i start the washer it turns off
  • 36 Answers
Check for codes Temperator sensor wire may have fell off back of drum code F-24
Posted on Dec 07, 2010
Why does my top load whirpool washer restart on its own after it finishes the last rinse and spin cycle. It does this on all settings, delicate, normal or heavy.
  1. Turn the washer off.
  2. Set the mode selector dial to NORMAL.
  3. Turn the dial counter clockwise ONE click (LEFT), clockwise THREE clicks (RIGHT), counter clockwise ONE click (LEFT) then clockwise ONE click (RIGHT).
  4. Now press the start button.
  5. All the cycle indicating lights should be illuminated.
  6. Press the Start Stop button once.
  7. Rotate the dial until Rinse, Wash, and Stop light illuminate.
  8. Turn the washer off and unplug it for 10 seconds.
  9. Finally, turn on the washer and it should now be reset.
  10. Run a test load empty to be sure the reset worked. If not perform the reset procedure one more time.
Oct 07, 2016 | Whirlpool Whirpool 3.5cu ft Top Load...
Start button doesn't work on King Size Washer
Are there any lights on at the washer? If not check the washer circuit breaker in your house main circuit breaker/service panel. If it is tripped reset it and try start button again. If it trips again you need a service call. If there are lights on try turning the washer main knob to off and unplug the washer from the wall outlet...wait 10 seconds then plug in and try start button again.
Mar 16, 2014 | Bosch Nexxt 100 Series WFMC1001UC Front...
1650 husky pressure washer starts and then stops
If you are not squeezing the handle to let the water out, it will shut off.
Nov 30, 2013 | Garden
FRIGIDAIRE FRONT LOAD WASHER WON'T START. DOOR LOCK WILL NOT LOCK. DOOR LOCK LIGHT IS OFF. PULL START HANDLE OUT/ NOTHING. HEAR CLICKING WHEN TURNING SELECTOR SWITCH/BUT WILL NOT LOCK DOOR OR TURN LIGHT ON...
Good Morning REDS, thank you for your inquiry!
I understand that your door indicates it is open and your washer will not operate. Try resetting the unit by either unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn on the washer. Select a normal cycle, confirmed the latched is securely latched and verify if the washer will start. If the washer will not operate then it possibly have a faulty door lock assembly or a communication problem with the control board. At this point, it would be advisable to contact an experienced appliance repair tech to assist further.
Sep 11, 2013 | Frigidaire ATF6000ES Front Load Washer
WHIRLPOOL DUET WASHER THE WASH LIGHT IS NOT LIGHTING UP WHEN WASHER IS STARTED AND THEN I GET "LF" CODE
LF flashes when the water level does not change for a period of time after the valves are turned on OR water has disengaged the basket but control does not detect a water level change.
Is water supply connected and turned on?
Are hose screens plugged?
Is water entering the tub? If so check pressure hose connection to machine/motor control.
Oct 12, 2012 | Whirlpool WFW9151YW Duet 3.5 cu. ft. Front...
Replaced the whole top panel. now start lights only flash wont start washer
You might have blown a fuse on the circuit board or fried a transistor on the board
Oct 07, 2012 | Whirlpool Duet GHW9150P Front Load Washer
The lights go on, but washer will not start.
door not closed try open door and then closing again
Feb 11, 2010 | Maytag Neptune MAH5500B Front Load Washer
STARTED WASHER, THEN HIT PAUSE TO ADD A GARMENT. WASHER WILL NOT START NOW. I HAVE EVEN TRIED TURNING IT OFF, BUT THE LIGHT STAYS LIT, AND THE WASHER WON'T START.
have you turned off the power and unplugged the unit for 5 mins?
plug back in and progress the timer to where you left off?
Mar 12, 2009 | Whirlpool GHW9400 Duet Washer
Maytag EPICz 3.7 cu. ft. Washer Logo
134 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
