Question about Acer AL2017 20" LCD Monitor
I have noticed recently that the screen words flicker.
I have only had this monitor less than 1 year. Just recently it started flickering from the left side of the monitor to about the center of the screen.
  • hollya Jun 26, 2008
    Thanks for putting in the link for me!
  • 3,940 Answers
If the monitor is less than a year only, then your best bet is contact the manufacturer for warranty support.
http://www.acerpanam.com/synapse/forms/webpage.cfm?siteid=7117&areaid=2&website=AcerPanAm.com
Posted on Jun 14, 2008
Acer Laptop Screen Flickers & Jumps
Please connect the laptop to an external monitor. If no flickering on monitor screen, from my previous experience, this is more likely loose connection of video cable connected to the LCD. So talk to Acer support again and require the replacement of LCD.
CompQ
May 11, 2010 | Acer Aspire 6930-6082 Notebook PC
Had my monitor for four years, great performance
jlallen54, When lcd panel goes to a dark condition please shine a bright flashlight 1 inch from screen an tell me if screen data is still displayed during this "blackout" condition. It might be just a single (1) poor and now thermally intermittant solder connection on the printed circuit board inside the monitor. Do some reading first and then you will understand the problem that your monitor has. 12fixlouie
Jan 17, 2010 | Sony SDM-HS73P 17" LCD Monitor
Screen flickering on and off.
I have the same problem with mine. I've kinda narrowed it down to it being the power supply in the monitor. was told it is about a $20 fix but we'll see
Nov 16, 2009 | Samsung SyncMaster 731B 17" LCD Monitor
My HP w1907 monitor less than a year old is turning pink!
A flickering screen with pink colour is a sign of a CCFL lamp problem.
The CCFL lamp is a mini fluro tube and it provides the back-lighting, it is definitely faulty and about to fail completely.
You need to get it repaired while it is still under warranty.
Oct 05, 2009 | HP w1907 LCD Monitor
Hi my Toshiba M110 laptop model PSMB0A-0IL00D screen flickers some times. It has gone all black few times as well. Is it cheap to fix? will it crash? Cheers Theo
According to the manual for my Toshiba laptop, the price of the screen is about the third of the price of the laptop. Do the math.
Before looking for a repair shop, investigate first the reason foe the Flicker.
I just remembered: all screens flicker. But if they flicker at 50 Hertz you might notice it. The higher the frequency the less noticeable the flicker is. Check your graphics properties to find out if you screen cannot refresh at a higher rate than the current one (60Hz, 75Hz or higher). But beware! if you force it to flicker at a frequency that it cannot handle, you will damage it.
Hope it helps.
Sep 06, 2009 | Toshiba Satellite A105-S4004 Notebook
Samsung 215TW Monitor Flicker
Its the capacitors on the backlight power supply. Samsung installed crappy ones and they blow up after a year or two. Change out the caps and you're good to go
Jan 30, 2009 | Samsung 215TW SyncMaster 21" LCD Monitor
Blueish flickering
Try to put speaker distance from monitor.
Try to remove the display card and fixed it again.
Then boot up your and see .
Apr 21, 2008 | Acer AL1913 19" LCD Monitor
Monitor flashing
I have a similar problem with my screen, same one, 15". For a period of two years it would turn black for an instant and resume functioning. Since two weeks it only flashes the picture for an instant and then turns black again. We opened it up to check the wiring but nothing wrong there. We are 99.99% sure that the problem is in the screen itself and has nothing to do with drivers or anything else in the computer.
If you bought it less than 3 years ago and since it is probably a result of faulty construction, it should fall under warranty (by european law).
I am going to take mine to a repairman tomorrow, i will inform you wether the screen can be repaired or not.
Greetings,
Rengenier.
Oct 10, 2007 | LG Flatron L1715S 17" LCD Monitor
Flickering crispy screen
maybe ur screen was put into a lot of magnetic interference. so check for any magnetic rays emitting devices like speaker adapters etc. a simple check would be to degauss( its in the screen properties). raja
Feb 28, 2007 | LaCie Electron IV 19" CRT Monitor
Flashing on and off
I would suggest trying another monitor to rule out your PC or monitor card. I would also check the video settings on the PC. Then assuming your cable/connector and video card are okay, it sounds like a lamp or lamp driver (a.k.a. ballast or inverter) issue. In other words, an internal issue that probably needs component-level troubleshooting.
Jan 08, 2007 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Acer AL2017 20" LCD Monitor Logo
155 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
