Question about Porter Cable Variable Speed Quik Change Tiger Saw Kit 9746
My porter cable "tiger saw" with quick change
rowdy45176
  • 2176 Answers
SOURCE: The saw blade on my Porter cable 423mag saw is jammed tight.
Unless you can get a wrench on it I can't see anything else on the breakdown. You are aware that the knob is Left Hand thread I hope.
Posted on Mar 22, 2009
  • 59 Answers
SOURCE: I have a Porter cable Tiger Claw saw model 9750.
detent latch broken
Posted on Nov 22, 2009
Mentorcase
  • 5 Answers
SOURCE: Can't take off front off porter cable tiger 747 (rubber boot
Remove 2 screws from under front grip and the swivel foot should slide forward and out (might need a bit of a twist to loosen) plastic grip should now slide forward and off.
Posted on Dec 08, 2009
  • 2527 Answers
SOURCE: I have a Model 737
Its hot pressed onto the shaft its made not to come apart because if it did in use it would not be good. I use sawalls all of the time and fine if the blade snaps low you can get them out with a strong magnet if you hold it up side down and turn the collar shake it around mabey spray some WD40 in side first it may take a little doing but it beats takeing that change collar a part.
Posted on Jan 14, 2011
  • 142 Answers
SOURCE: Porter Cable Tiger saw 9735 stopped working
blow it out and spin the motor by hand you may have saw dust blocking the brushes. If that's not it check the brushes to see if they have life left in them. If not that check the cord for an open with a volt ohme meter.
Hope that helps!
Posted on Feb 28, 2012
Portercable 737 tigersaw can't keep a blade in the quick latch
You can try spraying some lubricant into the blade holder. Sometimes the "ball" in the shaft gets stuck from dirt. Otherwise you will need to disassemble it by removing the roll pin that holds the collar on the shaft.
Mar 08, 2014 | Porter Cable Variable Speed All-Purpose...
What weight oil do I use in Porter Cable 637 Type 1 Variable Speed Tiger Saw?
use sewing machine oil, or 3 in 1 oil, you could use WD40 as well. but not motor oil
Mar 21, 2011 | Porter Cable Variable Speed All-Purpose...
Dec 07, 2009 | Porter Cable Variable Speed All-Purpose...
Need to change the blade on my sawsall
Make sure the cord is out of the plug! grasp the knob where the blade enters the machine, turn it 1/4 turn R or L and pull the blade out
Sep 29, 2009 | Porter Cable Variable Speed All-Purpose...
How do I replace the blade?
Hi rq,
Look at the base of the blade, there is either a half twist quick disconnect or an allen screw.
Safety first: Unplug the saw.
If its the allen screw it will be located to one side of the blade. Just loosen it , pull the blade out.
The half twist ring doesa what its name implies. Twist it as far as you can (holding the saw with the bladed to the ground allows it to drop out) to free the blade.
Best reqards
Mike
Sep 11, 2009 | Porter Cable Variable Speed All-Purpose...
How to remove the blade on a tiger saw quick-change,model#737?
At the base of the blade where it attaches in the saw you will see a round in shape with ridges fixture. Turn it so the slot is in line with the blade. Then you will be able to remove the blade. If the fixture does not turn, move the blade up and down while you turn the fixture.
Jun 19, 2009 | Porter Cable Variable Speed All-Purpose...
Broken blade on a porter cable 737 tiger
This is a jigsaw miscatagorized as a chainsaw. Do you have a blade big enough to drop 24" tree? We don't answer jig saw questions in the chainsaw section.
Mar 30, 2009 | Porter Cable Variable Speed All-Purpose...
Mar 22, 2009 | Porter Cable Saws
Porter Cable Variable Speed Quik Change Tiger Saw Kit 9746 Logo
152 people viewed this question
Top Porter Cable Saws Experts
Frank Mangiapane
Level 1 Expert
Jim Thurston
Are you a Porter Cable Saw Expert? Answer questions, earn points and help others
