Question about Goldstar Heating & Cooling
Gold star model: LW-G0710CL
I know it's old- but I've cleaned the slide out filer well. Is there any other way to clean the rest and make sure it's running to the best of it's capabilities?
    Problem Solver:
  • 7 Answers
Buy a new filter ensure your filter is clean as it can be replace it make sure the coil on the out side is clean as well
Posted on Jun 15, 2008
Where can I find a replacement dial/knob for my gold star LW-G0710CL. It's made of plastic and has cracked in half
Contact Sears parts direct at get on the chat on the web site and ask for the rotary switch - the part number most likely is 1h00598E.
I am assuming that your item is an air conditioner from the model number you provided.
Aug 13, 2014 | Washing Machines
Whirlpool gold water filter
Drain few gallons of water, it should clean up.
Apr 01, 2014 | Refrigerators
How can I remove the broiler drawer from my oven so I can clean under and behind it?
Since I don't know the manufacturer, most broiler drawers will slide out to maximum and then you lift upwards. This will permit you to pull the drawer out the rest of the way so you have access to the opening.
Semper Fi,
Jan 30, 2018 | Kitchen Ranges
Tools needed to change oil on 2000 saturn lw 3.0 L
Hi, all you need is a oil drip pan, 17mm and 32mm wrenches, cleaning cloths and appropriate oil and oil filter. Slide under your Saturn LW 3.0 and start changing the oil.
Jul 24, 2011 | 2000 Saturn LW
I have two black lines down the middle of page on Toshiba 1360. How do you clean all mirrors on this
remove the glass [two screws on the scale] very carefully clean the mirror that is near the lamp that is mirror 1 then clean the two mirrors that are nearest the side that the paper comes out that is mirrors 2+3 then remove the black lens cover i think it is held in place with two screws then clean the mirror that is there dont try to cean the mirror under it yet then open your machine and remove the cleaner unit follow the wire that goes to the unit and remove the black cover and unplug the unit, remove the toner cartridge you eill see either a black screw or a gold screw remove it slide out the unit and put one side gently.then look in the machine you will se a black cover slide your fingers in on the plate nearest you and you will feel a black screw remove the screw and then the cover will be loose remove it and clean the two mirrors there as well as the discharge lamps look in the optics cavity there are two slots near the lens, slide the two pins on the cover that you removed from the inside of the machine into them and slide upwards and retighten the black screw the rest is done in reverse good luck
Mar 16, 2011 | Toshiba 1360 Black and White Copier
We tried using the self clean on our Whirlpool Gold Accubake Duo system range. It locked the oven door and gave code e1 f5. We disconnected the power and turned back on to the same codes. HELP!!!!!!
take the trim peices off. take the screws that hold it to the wall out slidee unit out a little to remove the 2 screws from the consol lift the consol up and off. make sure that you have turned the power off inside the unit you will see a tech sheet that will tell you what that error code means. let me know how it goes the tech sheet is usually on the left side.
Jun 16, 2009 | Whirlpool GBD307PDS Electric Double Oven
Thunderbird 2002 jump started and ran for 30 seconds then shut off, won't re start. Car has been idle for over a year. Battery is relatively new.
clean out all of the old fuel, change plugs, check all vacuum lines, replace coolant. Change air filer and check the aire flow meter between the air filer and the throttle. before you try to start the car.
Jun 08, 2009 | 2002 Ford Thunderbird
Jenn-Air S136 Grill-Range--auto clean not working
Selector to Clean
Temperature to Clean
Move lock lever to the right
Press the enter button Twice
Mar 19, 2009 | Jenn-Air JES9860 Electric Kitchen Range
Disposal of a Gold Star dehumidifier model DH2510A
Most communities have either private or charitable organizations that take old appliances and computers. I took an old window air conditioner and they took it with no prep.
Sep 26, 2007 | Goldstar DH2510A Dehumidifier
Heating & Cooling Logo
212 people viewed this question
Top Goldstar Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Dan Webster
Dan Webster
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
