Question about Sport & Outdoor - Others
I RECENTLY BOUGHT A COPPERHEAD 150 VIPER CROSSBOW THATI AM HAVING TROUBLE WITH.I DON'T KNOW HOW TO ADJUST THE WINDAGE. IT SHOOTS TO THE LEFT ABOUT 1&1/2 FT TO 2FT FROM BULLSEYE. IT HAS 2 MOUNTED FRONT RED TIP SIGHTING PINS [TOP FOR SHORT RANGE-BOTTOM FOR LONG RANGE]. I TRIED ADJUSTING THE PINS IN AND OUT BUT THE CROSSBOW STILLS SHOOTS OFF TARGET TO THE LEFT. IT DIDN'T COME WITH A MANUAL WHEN I BOUGHT IT THE REAR SIGHT HAS AN ADJUSTMENT DIAL ON IT BUT I BELIEVE IT IS FOR THE ELEVATION. CAN YOU HELP ME WITH THIS ISSUE? SIGNED: GUNDOG MASTER !
jaballou
  • 63 Answers
SOURCE: Problem sighting bushnell lazer boresighter
If you are attempting to use a red laser in daylight, you have to wear special glasses to see it well. You may have to complete this project with less light, such as after dark, or indoors. Only green lasers will show up in daylight. If this is not helpful, then I suggest that you change the batteries to brand new ones that you are sure of. There is probably no adjustment possible. Best wishes for your safe shooting!
Posted on Jan 05, 2009
  • 302 Answers
SOURCE: Accurate adjustment of open sights
each notch should move your point of impact back on target for each 25 yards you add to the distance at which you are shooting
Posted on Jul 24, 2009
  • 30 Answers
SOURCE: scope elevation adjusted allthe way up & still shoots low
Bushnell sells nylon inserts for scope rings that fit inside of the scope rings and will affect the height of the ring to correct the problem. If you install them on the front scope ring, it will correct it and realign the rings correctly. It appears that the front ring towards the muzzle is not as high as the rear ring near the breach. This is why that even though the scope's adjustment is elevated as high as it will go, it is still hitting low because it is actually pointing down because apparently the rear ring is higher off the barrel than the front ring. The Bushnell inserts can correct this.
Posted on Sep 01, 2009
bigcass
  • 35 Answers
SOURCE: How do I sight-in(zero-in) my handgun(S&W
The problem with this is, the Sigma comes with Fixed Rear Sites. Non Adjustable.
I also have a good buddy of mine that was in the Police Academy who bought that gun for his duty weapon and was having the same problems you are. Hitting Way Low.
Now, another side to this problem Ive heard of is that the Sigma Series has a really heavy trigger pull. And a lot of shooters (More than 20) have come together with the fact that due to the heavy pull, it causes you to pull the muzzle downward as you squeeze the trigger...without even knowing it. Causing you to hit low.
If this is the case, I would take a guess that if you are a left handed shooter, you have too much finger on the trigger causing you to pull left...mixed with the heavy trigger pull, forcing downward. Or a Right handed shooter with the correct amount of finger on the trigger, but such a heavy pull, your pushing to the left. Just another thought for ya.
But from what my research has led me to find, there is no option yet for adjustable rear sites.
Here is a LINK to a website discussing the heavy Trigger Pull causing dropped Bullet Impacts. Read what they say and it might help ya. If you change some things, let me know. Id be interested to hear if it changes your POI. (Point of Impact)
Hope This Helps!
Posted on Oct 17, 2009
jyackle5
  • 8197 Answers
SOURCE: Have bought Ruger .270 rifle
Yes there is a screw on cap covering the adjustments. Here is one of there general manuals on the link below.
http://simmonsoptics.com/downloads/manuals/archive/HSI_Simmons%20Generic%20Scope%20Adjusting%20Instructions.pdf
Posted on May 23, 2011
HOW DO I ADUST THE LENS ON BARNETT 4X32 SCOPE
4x32 mm Illuminated Crossbow Scope Owner's Manual - Crosman
https://support.crosman.com/hc/en-us/article_attachments/.../432RGMK-515.pdf
E. Windage (horizontal) Adjustment. F. Objective lens. 2. EYEPIECE FOCUSING. Without using your scope, look at a distant object for several seconds.
[PDF]4x32 Crossbow instructions - Mission Archery
missionarchery.com/wp-content/uploads/2014/07/4x32-Crossbow-instructions.pdf Keep the protective lens covers in place when the scope is not in use. ... This optimum adjustment may also require the rings to be moved along the scope rail.
Barnett Crossbow Scope Review - 4x32mm - HuntingOptics.net
huntingoptics.net/crossbow-scopes-reviews/barnett-crossbow-scope-review-4x32mm/ This is a bit above the curve for 32mm objective lens scopes, so I'd call the field of ... The Barnett 4×32 multi-reticle crossbow scope is very easy to sight in, once ... Thanks for reading my review of the Barnett 4x32 multi-reticle crossbow scope.
How to zero a crossbow scope (Tutorial) - YouTube
? 7:55
https://www.youtube.com/watch?v=Td-qESCt7Gw Nov 7, 2013 - Uploaded by Weaponsandstuff93
How to zero a crossbow compatible scope to shoot accurate groups with bolts. ... Some of them crossbows ...
Sighting in a Crossbow Scope - YouTube
? 3:03
https://www.youtube.com/watch?v=TnOIy1ZTe1U Aug 23, 2012 - Uploaded by Ghostkamo
Easy steps to sight in a Red Dot Scope. ... Just bought a Barnett Ghost 410 and needed to check how to ...
HOW DO I ADUST THE LENS ON BARNETT 4X32 SCOPE - Fixya
www.fixya.com/support/t26743320-adust_lens_barnett_4x32_scope 25 mins ago - If your rifle is taped for scope rings this is a easy thing to do, if you do not have any screw holes on top of the barrel you will have to have a smith ...
Sighting in my Barnett scope - HuntingNet.com Forums
www.huntingnet.com > HuntingNet.com Forums > Archery Forums > Crossbows Sep 1, 2009 - 10 posts - ‎7 authors
I have the Barnett 4x32 Multi Reticle scope and as per the instruction it tells me to set the top reticle line at 10 yards. So after about 10 shots I ...
barnett 4x32 scope Questions & Answers (with Pictures) - Fixya
www.fixya.com > Forum > Tags Get free help, tips & support from top experts on barnett 4x32 scope related issues. ... I have a chipped lens on the inside of the scope how do i get it fixed this will need to be sent to ... How do I adjust the reticle for a Simmons Mag 4X32 ...4X32 ... ADUST THE LENS ON BARNETT 4X32 SCOPE Google Search
Sep 18, 2017 | Optics
I recently bought a Barnett RC-300 Crossbow. But the string was broke on it. I'm looking for a manual, video, or a detailed explanation on How to Restring a Barnett RC-300 Crossbow. Place n tks
Try searching youtube for a video.
I am not sure if any preload is applied to the prod when restringing, but the Barnett is a popular crossbow and they are sold and serviced by a great many serious hunting, shooting and fishing shops and suppliers as well as a few sports outlets. You should have no trouble finding spares and information.
Apr 29, 2016 | Garden
Fore end loose
If you contact the manufacturer all PSE crossbows have a lifetime warranty and for safety reasons they will repair for free.
Mar 27, 2014 | PSE Precision Shooting Equipment PSE...
Can't pull string back
Have you tried a cocking aid or rope ?
Aug 19, 2013 | PSE Precision Shooting Equipment PSE...
Haveing problem with the windage adjust and elavation adjustment it is working backwards.
If your point of impact needs to move up, turn the knob the direction that says up. If it needs to move left, turn the windage knob the direction that says left.
Jan 21, 2011 | Optics
I have a Bushnell Sprotiew 4x, 15mm scope mounted on a Mossburg .22 rifle. My shots are hitting left six inches and low. Can you please tell me how to adjust this scope? Thank you.
Keep in mind Diane this is for a set distance. if you are taking a shot at a target further than your are set for (ie a target you wont get 3 shots @) remember how the bullet is travelling as it goes down range
one idea would be to set your rifle up down range and zero it in on a target (preferably paper) now adjust 1 MOA (try and have target @ 100 yards and 200 yards)
see how far the bullet moves for each moa adjustment. then check it against the next range.
this should remain constant @ a set number of inches per 100 yards.
so if you zero in @ 100 yards and then move 1 moa any direction and it adjusts (lets say and hope it is 1.047 inches") then you do the same for 200 yards. it should be twice as much movement. ie 2.094"
once you know what 1 moa represents on your scope you can adjust alot more accurately.
REMEBER the total inches of movement / adjustment per MOA is directly related to range (a precise range helps in shooting) so if your squirrel is 150 yards and your first shot is off 9" to adjust you divide 9" by the inches per moa so 1.5 (150 yards /100) X (Inches per 100 yards per moa you measured hopefully 1.047") its 9" divided by 2x1.047 = 9" / 2.094 = 4.29799
this number needs to be rounded to the nearest click on your scope (most are 1/4 MOA scopes and you can tell by looking at how many clicks/lines are inbewteen each large number on your windage and elevation dials
so to turn this into an adjustment we round 4.29799 to 4.25 which is 4.25 MOA or 17 clicks on a 1/4 min scope.
GL and any questions just post and ill help
not please rate this as fixya :)
Note i can provide EXACT information that would allow you to determine range, and windage and elevation adjustments by looking through scope and estimating range
then factoring in weather variables. NOTE you hafta enjoy math or just want to know how to shoot really well. :)
Dec 22, 2008 | Barska Optics Barska 10-40x50 Ao Varmint...
Windage adjust correction
Go to; www.bsaoptics.com for the manual and parts.
You do not say if the WINDAGE Adjustment KNOB is 'broken' or what? If you have dropped it or somehow broken it, it's unlikely that you will be able to repair it yourself, in which case I refer you again to BSA.
If there's nothing wrong with the scope or your rifle, and you are simply having difficulty getting a good ZERO, I can help you with that, just respond and let me know.
Good luck. :)
Dec 09, 2008 | BSA Deerhunter Riflescopes Deerhntr 3-9x40...
Sport & Outdoor - Others Logo
77 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
