Question about Medion md40298 Notebook
I have Mod 41199 . changed batteries and can not receive out door temp. can you help me?
    President:
  • 4,070 Answers
Hi! Please try this. Remove the battery again and press hold the power button for 15secs. to reset the computer's system. After 15secs. install the battery, turn the pc on and see how it goes. If still no luck, I strongly suggest that you reinstall the computer's driver. Hope this helps and thank you for using FixYa!
Posted on Nov 05, 2010
Power windows wont roll up or down on 2006 Cadlliac cts
With the electronic's involved ,your best bet would be to take to a qualified repair shop . The door 's have electronic control module inside that control door lock's an window operation . Hooking up a professional or factory scan tool an viewing input data an checking DTC'S - diagnostic trouble code's would be the first step any professional technician would do . You probably have no idea what these are ? Messing with these systems can render your vehicle unuseable if you do not know what you are messing with .
Power Windows System Components
The following components are used to control the power windows:
• Driver door module (DDM)
• Passenger front door module (PDM)
• LH rear door module (LRDM)
• RH rear door module (RRDM)
• Driver door switch assembly (DDSA)
• RH front power window switch
• LH rear power window switch
• RH rear power window switch
• LH front power window motor
• RH front power window motor
• LH rear power window motor
• RH rear power window motor
• Class 2 serial data link
• DR MOD PWR C/B 30 Amp circuit breaker
• DRIVER DR MOD 10 Amp fuse -- DDSA and DDM logic, DDM internal driver operation.
• PSGR DR MOD 10 Amp fuse -- PDM logic and internal driver operation.
• REAR DR MOD 15 Amp fuse -- LRDM and RRDM logic and internal driver operation.
Power Windows Operation
The vehicle is equipped with power windows controlled by the door modules. Each passenger door window can be operated, either from a power window switch built into the driver door switch assembly (DDSA) , or, from a power window switch mounted locally on its associated door. The driver door window can be operated only from the driver door power window switch built into the DDSA.
When the driver door module (DDM) receives a driver door window switch request from the DDSA, the DDM examines the request and inspects to see if it has received any messages from any of the other vehicle modules prohibiting the movement. If no prohibitive messages have been received, the DDM then applies power and ground to the driver door window motor to move the window as requested.
When a passenger door module, passenger front door module (PDM), LH rear door module (LRDM), or RH rear door module (RRDM), receives a window switch request from, either the DDSA or the window switch mounted locally to its door, the passenger door module examines the request and inspects to see if it has received any messages from any of the other vehicle modules prohibiting the movement. If no prohibitive messages have been received, the passenger door module then applies power and ground to its associated window motor to move the window as requested.
So do yourself a favor an take it to a qualified repair shop.
Nov 22, 2017 | Cars & Trucks
Samsung fridge freezer mod SRS615DP door open warning comes on and alarm is beeping then temp reading will fluctuate . But the door is not open not even a little all the seals are in excellent...
HI,
First try a reset by unplugging all the cords of your unit and leave it for 4 hours.Also open the refrigerator door.After that plug in all the cords,close the door and let me know the result.
Sep 14, 2008 | Refrigerators
Can't find the window fuse for 2003 caddy cts
Check inside trunk under carpet on rear seat back support.
Nov 12, 2016 | Cars & Trucks
I have a Maytag frig. Mod. # MFI2269VEW and some items in the refrigerator keeps freezing lettuce, soda, carrots, etc. Had a tech out said he couldn't find anything wrong
maybe the pre set temp for ur unit too low. ask for dealer how reset if its digital ... u want to change ur settings call first the dealer so he can give u trainings
Feb 22, 2015 | Maytag MFI2269VEW 22.0 Cu. Ft. French-Door...
1997 volvo 850R cold start issue
could be an air temp sensor,you need a computer to check it but it controls air fuel mixture at different temp,almost like a choke but for modern day vehicles
Nov 18, 2012 | Volvo Cars & Trucks
Need key code radio 5000rds serial m218670
Good evening,
I have an Opel Corsa Edition 2000.
I changed the
battery but have not received the secret code to unlock the stereo.
The mod is 400 TIPE.CAR
Ser no. 09,119,904.
Will you help me find the
code?
thanks
Jun 04, 2012 | 2000 Ford Focus
During and after the cold snap here near Ft. Worth Texas the remotes do not open the garage door. I replaced the battery in one with no change. In warmer temps it works fine. The house button always...
If none of your remotes work and they all failed at the same time it is most likely the receiver that has quit. It is part of the logic board. The wall control is hard wired and doesn't use the receiver.
Feb 12, 2011 | Sears Craftsman LiftMaster Chamberlain...
Windows won't roll down
Does the rear window work from the passenger switch?
Oct 07, 2009 | 2003 Cadillac CTS
Pioneer deh 5800mp receiver
Bass and treble settings are adhusted only when u r in custom setting of equilizer mod.in any predifned mode u cant change the bass and treble settings.
Dec 30, 2008 | Pioneer DEH-P5800MP CD Player
Medion md40298 Notebook Logo
79 people viewed this question
Top Medion Computers & Internet Experts
Larry Chandler
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
