Question about Reddy R60A Utility Heater
HAVE OLD LAWN BOY 150 BTU HEATER WONT STAY FIRED EVERY THING ELSE WORKES JUST WONT STAY BURNING ON AND OFF AS FAR AS THE BURNER
  • 232 Answers
There are a number of things that will cause the symptoms described. From as simple as water in the fuel to a more complex problem such as a defective Ignition Device (transformer, Spark box).
You will need to read & follow the tips attached and attempt to narrow the problem down.
Troubleshooting tips
Posted on Nov 06, 2010
GX90-715A wont stay fired
1) Product manual has burner info page 11, maintenance 12, and troubleshoot flow charts starting page 17
Otherwise, Rheem does not post service manuals.
http://bostonheatingsupply.com/Rheem/Rheem%20Commerical%20Gas/Rheem_CommGas_Extreme_Use%20and%20Care%20Manual.pdf
2) Post question on pro water heater forum.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
3) Is air intake clear? Is the burner sooted? Is the flame large and clear blue? Is the vent obstructed? Does air draft when blower activates?
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Feb 14, 2013 | Rheem RUUD GX90-715A Water Heater,gas,90...
Pilot stays lit, burner comes on but only a portion of the burner area has flames.
remove burn tray clean out all burners sounds like all sooted up then check gas pressure to see if adequate gas pressure
Sep 13, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
Have an electric Reddy Heater 55000 about 4 years old that we have been burning diesel fuel in. Laterly we have been having touble with it starting, takes many attempts, Also the fumes are so bad we can't...
It sounds like you are not getting complete combustion and need to adjust the air flow to the burner so it will have more air/oxygen to burn. You may try cleaning the fan and burner also.
Sep 26, 2010 | Reddy Heater-30-55,000 BTU Variable
I have a Jandy LITE2 LG325. Only two years old.
Does the pilot light stay light? Or light then go back out? If it is doing that then it is the thermocoupler. looks like a wire that is in the flame of the pilot light. Other than the sparker. That is what dectects that there is fire in the pilot light before it starts the gas. Safety thing. So if that isnt detecting fire, then it will never let the gasvalve open up, Try taking some steel wool or real fine sandpaper and clean up that sensor. The wire. It builds up a thin film on it from gas burning.
May 11, 2010 | Jandy Laars Lt 400,000 Btu Heater
Hello
There are a few things that you will need to check on these pool heaters if your unit is ignited, but your burners wont fire. First, and this probably seems obvious, make sure that the knob is set to the on position. Next, cycle the ignition sequence until the air is out of the gas line. If it will still not fire, replace the gas valve.
May 03, 2010 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Fire inside burner
Hi looked on the wedsite it sounds like the air mixture is wrong casuing it to light back on to the injector (ORFICE) A slong as the orfice is clean and the burner is not blocked then the screw on the burner should adjust the air flow , turn it out as far as it will go with the burner on adjustthe srcew keep tuning slowly in , if it lights back it might make you jump but it won't do any harm , its just getting the mixture right, try this and see if it works ,
Jan 20, 2010 | Heating & Cooling
R 150 B wont stay running
Most common problem is the CAD flame sensor, two wires in a round rubber boot about 2 inches long facing the combustion chamber. You can get one from Mr.heater for 3 bucks and even though the wires are a different color you can just splice the to your old wires and it will work fine, just did the same thing with mine and it's perfect now.
Jan 21, 2009 | Reddy Heater-30-55,000 BTU Variable
Reddy R60A Utility Heater Logo
239 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Paul Carew
Superior Maintenance
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
