Question about Sony KDL40EX400 40 in. HD-Ready TV
It pause temporarily at times during regular tv programming. What can the problem be?
    President:
  • 1,140 Answers
I'm not quite sure what you mean by "pause", but if you mean the picture freezes or pixellates and the sound cuts outs then it's caused by a bad signal - know as "Digital Cliff Edge" - see attached image.
If you are using an aerial, check all your cables are connected properly and that your aerial is securely mounted, pointing in the right direction and none of the elements have become detached - particularly the dipole where the co-axial cable attaches.
If you are using a dish, again check all your cables are connected properly and that your dish is securely mounted. If the bolts are loose and you can move the dish by hand, then it's possible that your dish has moved from the correct alignment. You will ideally need a signal meter to correct this although it can be done by trial and error.
You should also note that dishes are susceptible to signal-loss during bad weather, particularly strong wind, heavy rain and snow. If you are only losing picture in bad weather, there isn't much you can do apart from making sure the dish is rigidly fixed.
If your aerial/dish is OK, try replacing your fly-leads (the short section from the wall socket to the TV) and/or the cable from the aerial/dish to your TV.
Hope this helps.
BElectric
Posted on Nov 05, 2010
  • DILLIGAF
    DILLIGAF Nov 05, 2010
    Copy and paste this link for an explanation of Digital Cliff Edge.
    http://www.aerialsandtv.co.uk/_wp_genera...
  • peterkoke Dec 23, 2010
    I had the same problem (picture randomly freezes). In my case, IT WAS NOT a signal issue. TV was under warranty and I got a new one from SONY. Hooked it up to my system and guess what - same problem!!!! Turns out it was an incompatability with the Surround Sound system (also SONY - HBD-E570). I switched to another model (SHARP) and the probelm went away. So one of two things is possible, either the HBD-E570 is incompatible with the EX400 OR my HBD-E570 is defective. I plan to hook it up to a different model SONY to test my theory,
6 in 1 universal remote
With Sony almost any Sony remote made for any of their regular sets and projection sets from 1985-2005 will work without programming for basic things---you may and are likely not to be able to use PIP and a few menu features---during that time Sony codes numbered less than 6 different types--the differences being mainly some features were not there.
Apr 23, 2012 | Televison & Video
Clean light flashes on and off 7 times, then a pause. Then repeats the sequence. Machine will not start regular cycle.
The clean light blinking 7 times can indicate a heater failure.
Press Heated Dry, Normal Washer, Heated Dry, and Normal Wash.
This sequence will run a diagnostic test and clear the error temporarily but if the dishwasher is not heating the water the error will happen again.
If the problem is a reoccurring one then I recommend checking the heater amps if you have access to a clamp-on volt/amp meter.
Remove power to the dishwasher and remove the access panel. See image below. Clamp the meter around the black or white wire at the junction box and restore power and run the test cycle. During the test the heater will come on and the meter should pick up about 8-10 amps. If you get no amp draw then the heater is not working and is the cause of the clean light blinking 7 times
Thank You and please ACCEPT my answer and Rate my answer if it was helpful..
Jul 01, 2011 | KitchenAid 24 in. KUDS01FLSS Built-In...
How do i program my remote
Hello;
Without knowing the codes for the specific brand names and models of your devices, this is how you program the Zenith MBR3447 for your TV, VCR, DVD Player, CD Player or Audio Receiver:
TV
1. Push the "Power" button on the TV to turn it on.
2. Press and hold the "PRG" button in the upper left corner of the remote. Release when the indicator light, located in the top center of the remote control, comes on.
3. Push the "TV" mode key located at the top of the remote.
4. Enter 0 -- 0 -- 0 on the remote's number pad, then press the "Enter" button.
5. Aim the remote control in the direction of the TV's IR sensor and push the "Power" button. Pause a second. If the TV fails to shut off, push the "Power" button again. Repeat until the TV does shut off. Each time the "Power" button is pressed the Zenith MBR3447 tries using a different TV device code from its code library to turn the TV off. Therefore, when the TV finally does shut off it's an indication that the remote is temporarily programmed with the correct device code to control the brand of TV you're using.
6. Press "Enter" to save the current code.
VCR
1. Push the "Power" button on the VCR to turn it on.
3. Push the "VCR" mode key located at the top of the remote.
5. Aim the remote control in the direction of the VCR's IR sensor and push the "Power" button. Pause a second. If the VCR fails to shut off, push the "Power" button again. Repeat until the VCR does shut off. Then press "Enter."
1. Push the "Power" button on the device your programming the remote to control to manually turn it on.
3. Push the "AUX" mode key located at the top of the remote.
5. Aim the remote control in the direction of the device's IR sensor and push the "Power" button. Pause a second. If the device fails to shut off, push the "Power" button again. Repeat until the device does shut off. Then press "Enter."
Mar 11, 2011 | Zenith MBR3447 Remote Control
When I got incomming call Samsung GT-I9000 Galaxy S turn to silent by itself
This is a new feature in Samsung Phones called Etiquette Pause. If you turn over the phone the phone is temporarily muted. Its handy during meetings, in theater etc.
If you do not like it find a setting called Etiquette Pause in phone settings and disable it.
Feb 16, 2011 | Samsung Galaxy S GTI9000 Smartphone
I need help finding the code for my tv. i have a Philmore universal remote pm-rc13. My t.v is a white-westinghouse
Here is the code for your TV 0154 along with the advanced codes.
Advanced Codes for TV_0154TVs ------------------ <TV Group>
0154 244 ACM 165 Fine Tune Up 251 SAP 167 Surround Mute
244 Auto Chroma 244 MTC 231 Speaker In 168 Surround Vol dwn
251 Bilngual 234 PIP Location 233 Speaker Out 164 Surround Vol up
169 Fine Tune Do 228 PIP Select 247 Stereo 129 Component 2 (discrete)
TELEVISION. Uses with:
TUNER/CD/TAPE/PHONO/AMP..CDs................AUX2 088
TELEVISION...............TVs..................TV 154
VCR......................VCRs................VCR 047
VCR......................VCRs................VCR 104
On some models,
100|AM/PM|1-- may be 100/Enter;
Func|Sel may be Digicon;
Level Up|R may be Control Right, Level Up/Minute or Menu Up;
Level Dn|L may be Control Left, Level Dn/Hour or Menu Down;
Review|Qck View may be CH Recall or Quick View;
SetTime Fast may be Stereo Matrix;
SetTime Slow may be Time/Day, Set Up, Clear or Menu;
TV/Video/AV may be TV/AV, Video Mode, Input or A/V;
Wide|TV|Loud may be Stereo Matrix, Surround or Mode;
MTC|OBC|Auto may be ACM or Auto Chroma.
181 0...............0 185 1...............1
120 ENTER...........1-- 120 ENTER...........100
183 2...............2 187 3...............3
180 4...............4 184 5...............5
182 6...............6 186 7...............7
053 8...............8 057 9...............9
185 1...............A 123 A/B.............A/V
120 ENTER...........AM/PM 059 CHANNEL DOWN....AM/PM
183 2...............B 187 3...............C
249 RECALL..........CH Recall 059 CHANNEL DOWN....Channel Down
055 CHANNEL UP......Channel Up 122 PROGRAM.........Clear
250 STOP............Control Left 246 PLAY............Control Right
250 STOP............Cursor Down 059 CHANNEL DOWN....Cursor Left
055 CHANNEL UP......Cursor Right 246 PLAY............Cursor Up
180 4...............D 055 CHANNEL UP......Day
184 5...............E 120 ENTER...........Enter
182 6...............F 121 SHIFT STOP......Fine Tune Dwn
117 SHIFT PLAY......Fine Tune Up 248 PAUSE...........Function
186 7...............G 053 8...............H
250 STOP............Hour 057 9...............I
123 A/B.............Input 181 0...............J
059 CHANNEL DOWN....K 250 STOP............Level Down
246 PLAY............Level Up 122 PROGRAM.........Menu
250 STOP............Menu Down 246 PLAY............Menu Up
246 PLAY............Minute 116 SHIFT PAUSE.....Mode
245 MUTE............Mute 230 SHIFT FFD.......PIP Freeze
235 FAST FORWAARD...PIP On/Off 232 SHIFT REW.......PIP Replace
119 POWER...........Power 052 DISPLAY.........Recall
249 RECALL..........Review 248 PAUSE...........Select
122 PROGRAM.........Set Up 118 REWIND..........SetTime Fast
122 PROGRAM.........SetTime Slow 056 SLEEP...........Sleep
116 SHIFT PAUSE.....Stereo Matrix 118 REWIND..........Stereo Matrix
116 SHIFT PAUSE.....Surround 122 PROGRAM.........Time/Day
056 SLEEP...........Timer 181 0...............Timer Set
056 SLEEP...........Timer Start 116 SHIFT PAUSE.....TV
123 A/B.............TV/AV 123 A/B.............Video Mode
058 VOLUME DOWN.....Volume Down 054 VOLUME UP.......Volume Up
116 SHIFT PAUSE.....Wide
Hope this helps. Let me know if I can help you with anything else.
JimmyC
Sep 29, 2009 | Televison & Video
Wash cycle stuck
You can attempt to unplug the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). This is the main computer for the washer. Sometimes resetting it is all that is required to correct momentary program glitches. If the problem reoccurs following a CCU reset, then you have a legitimate problem. Let me know if you still experience problems. I hope this helps you.
Jul 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
3d frog frenzy 1
I cant find anything which lets you skip or select levels, sorry.
But this is the best I could find:
Press [Ctrl] + [Shift] + L during game play Easy Win Press [Ctrl] + [Shift] + T during game play. Freezes The Time Press [Ctrl] + [Shift] + I during game play. Gives You Unlimited Lives, Makes It So You Can't Run Into Traffic Press [Ctrl] + [Shift] + P during game play. Pauses The Game
Press [Ctrl] + [Shift] + L during game play Easy Win Press [Ctrl] + [Shift] + T during game play. Freezes The Time Press [Ctrl] + [Shift] + I during game play. Gives You Unlimited Lives, Makes It So You Can't Run Into Traffic Press [Ctrl] + [Shift] + P during game play. Pauses The Game Press [Ctrl] + [Shift] + L during game play Easy Win Press [Ctrl] + [Shift] + T during game play. Freezes The Time Press [Ctrl] + [Shift] + I during game play. Gives You Unlimited Lives, Makes It So You Can't Run Into Traffic Press [Ctrl] + [Shift] + P during game play. Pauses The Game
Press [Ctrl] + [Shift] + L during game play Easy Win Press [Ctrl] + [Shift] + T during game play. Freezes The Time Press [Ctrl] + [Shift] + I during game play. Gives You Unlimited Lives, Makes It So You Can't Run Into Traffic Press [Ctrl] + [Shift] + P during game play. Pauses The Game Press [Ctrl] + [Shift] + L during game play Easy Win Press [Ctrl] + [Shift] + T during game play. Freezes The Time Press [Ctrl] + [Shift] + I during game play. Gives You Unlimited Lives, Makes It So You Can't Run Into Traffic Press [Ctrl] + [Shift] + P during game play. Pauses The Game EASY WIN: Press [Ctrl] + [Shift] + L during game play.
FREEZES THE TIME: Press [Ctrl] + [Shift] + T during game play.
UNLIMITED LIVES: Press [Ctrl] + [Shift] + I during game play.
PAUSES THE GAME: Press [Ctrl] + [Shift] + P during game play.
I hope they help
Mike
May 14, 2009 | Cosmi 3D Frog Frenzy for Windows
The lower half of the screen is a black box on one channel
Check your closed-captioning settings. You probably have it set for "text". Make sure you turn captioning off and the problem should clear up.
Feb 12, 2009 | Recoton Advent Advent Q2035A 20" TV
Trying to connect a new high definition digital box to tv with hdmi but keeps flashing and saying its searching
Turner,
I looked through the Hitachi web site for your owners manual, no luck. If you're trying to use HDMI as the type of connection from your digital TV box to the TV, keep in mind that HDMI is not a network, but a one way point-to-point connection. That said, make sure that the cable is seated firmly at both ends. Next, grab the owners manual from the cable box and make sure it is programmed to be sending HDMI. The cable box MUST be programmed before it will send HDMI. The TV is most likely ok, check the cable boxes programming.
If the cable box has a regular "video out" connection, temporarily use that to be able to "see" the cable box and go through it's menus. Find the HDMI section, turn that signal on and you should be good to go.
Jan 21, 2009 | Hitachi 55HDS69 55 in. Plasma Television
Sony Wega
Please count light flashing again. Light flash time is "0.3 Sec" and there would be pause (light Off time) for "3 Sec". Start counting after pause to next pause.
May 31, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony KDL40EX400 40 in. HD-Ready TV Logo
208 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
