Question about Bose SoundDock Digital Music System for Apple iPod - White
Bose sound dock
My Bose Sound Dock just makes a static ticking sound when I plug it in. Can anyone recommend a solution? or suggest what might have gone wrong?
  • 8 more comments
  • Anonymous Jul 05, 2008
    Same for me. It was working a couple of days ago. Now when I plug it in it makes steady reptitive clicking sounds, and no music.
  • kknudt Jul 05, 2008
    I have the same problem. It was working yesterday, but today it only makes steady repetitive clicks through the speaker; no music.
  • user_irvine Jul 18, 2008
    Same problem. Took it to Bose store in Fashion Island, CA and was told it was my iPod not the sound system. Reset iPod and it worked again.
    Next day, same problem arose. iPod purchased with sound system. Over "90 day warranty," reported salesperson at store. Resolved to call tech support for Bose electronics again today....
    A nuissance.
  • bandit1dawn Aug 02, 2008
    My Bose SoundDock just started making a clicking noise when I plug the dock in ~ and when I place the IPOD in ~ no sound, clikcing or music
  • skiphill7 Aug 14, 2008
    sounddock clicks when ipod is placed on dock. stops and starts. sometimes clicks in the middle of song, then stops itself. I checked pins on both sides and all seems to be in order.
  • Anonymous Aug 27, 2008
    Same symptoms here, no music - just a clicking sound. Hopefully someone has a brilliant solution?
  • Anonymous Oct 08, 2008
    I have the same problem with my docking station, but I immediately took it apart and pinned it on the speakers. My only question is, can I just go out and buy new speakers for it? rather than going out and buying a completely new docking station.
  • Anonymous Oct 30, 2008
    Same problem . The plug orientation is NOT very obvious . If you look closely there is info molded on the plug that you can only see if it's facing up,, but shame on Bose for making this so easy to screw up !
    Thanks for the solution !
  • Anonymous Jan 26, 2009
    My bose soundDock just doesnt work any suggestions?
  • Anonymous Apr 29, 2009
    Unit made ticking sound. I made sure the plug was in correctly and it works fine!
Had the same problem, worked just to rotate the power cable into the back of the sound dock. Printing on the plug goes on top. It worked like a gem, after trying new batteries, resetting, etc...it was just an incorrectly placed plug!! Thanks for the help!! Listening now to some great music!
Posted on Dec 14, 2009
Hi Mike, I had exactly the same problem that I tracked down to the docking connector. Fortunately I run a design company so I made a replacement docking connecter board with USB Iphone charge upgrade built in. We took great care to keep the noise and channel croos talk way down. If anyone is interested then thet are for sale at www.invebo.com Forgive me for using your forum for advertising. When I had the problem I had a frustrating time - this should make it easier for Bose Dock owners.
Posted on Aug 17, 2010
  • oakmonde Feb 08, 2011
    Fantastic idea and site. I'v just ordered a repacement board. Hope it works!
Mine was also just a matter of simply rotating the power cord.
Posted on Dec 07, 2009
I had a similar problem.
If your handy..read on
Check to see if the power supply is providing +18 VDC and -18VDC.
If OK, then open the sounddock and examine the power supply connector....very very closely.
The power connector had intermittent connection to the sound dock circuit board. Looking closely (mangifing glass) you might see cracks in the solder around the connector pins. This is a cold solder agravated by rough handing of the power cord.
Resolder the pins on the connector on the bottom side of the board. Make sure the solder flows around the pin and through the board.
Posted on Aug 25, 2008
  • 3 Answers
Had the same problem and suspected a bad solder joint at the power connector; see kadaro's post. Resoldered it but no success; resoldered again, this time removing the old solder (using solder braid) and adding fresh, and two 100nF blocking capacitors for good measure.
I still get occasional dropouts, though much less frequent and persistent (or so I like to imagine). I suspect the root of the problem is a faulty power supply producing spikes, noise or something, but have no 'scope or spare unit to check this.
Posted on Sep 14, 2008
    New Friend:
Thank you so much! I rotated the cord with the writing facing up and hey presto - all working again.
Posted on Apr 09, 2013
    New Friend:
So my speakers have done the exact same thing.. but when your all saying to rotate the power cord, i am unable to do this as there is a plastic clip which clips in.. suggesting i already have it in the right way? but unless i break this i will be unable to rotate the cable. what else can i try?
Posted on Feb 16, 2013
Hi, this happened to mine and it turned outr to be short circuit pins on thedocking connector. I got a huge quite to fix it but I found a replacement docking assembly made by Invebo.com and fixed it myself. Problem solved!!!
Posted on Oct 25, 2010
Where can I get a bose sounddock replacement cord?
Posted on Nov 18, 2010
Rotate the power cord! Works like a charm. although it appears square, the power cord is oriented to only fit in one way. Two of the four connectors have clipped corners indicating the correct way to insert into the back of the sounddock. This was very frustrating until I read the previous posts. Thanks!
Posted on Oct 14, 2008
  • ianhthompson Jul 15, 2010
    So many thanks!! I was worried that the speakers had blown!
  • vcg3 Dec 19, 2010
    Thank you so much for posting this. I was going to leave mine out by the curb with a free sticker on it. It was so simple that my wife is sure that I am an idiot for not thinking of it - oh well.
I had the same problem. First, simply rotate the power cable where it goes into the back of the sound dock. There is a slight difference in configuration/shape. They try again. Worked immediately for me when I had the power cable plugged in correctly.
Posted on Sep 18, 2008
Mine started doing it as well and I think its a problems with the port that plugs into the ipod. I notice mine was chipped. So I am going to send it in and hopefully that fixes it.
Posted on Jul 12, 2008
4 Suggested Answers
  • 17 Answers
SOURCE: connection to sound dock for ipod is disconnected
See the Bose Sounddock pcb replacement description at http://www.chargeconverter.com/shop/connector.htm?connboser.htm
Posted on Jan 26, 2009
VOTIT
  • 2071 Answers
SOURCE: Bose Sound Dock - Opening the case
Screwed are placed in button of the base covered by rubber footings,and also you can take the front screen cover its only fitted,so you can access the amplifier screws.
Good luck...
Regards:
VOTIT
Dont forget to rate:
Posted on Jul 01, 2009
SOURCE: Bose Portable sound dock remote not working with iPod Classic
I have the same problem with mine. Called Bose Belgium and waiting for answer but it seems there's nothing to do.
Wait and see
Posted on Sep 22, 2009
My bose ipod speakers are making a knocking noise and not charging my ipod
bose ipod speaker been turned of for a few months just plugged it in making a knocking noise is this normal
Jul 11, 2009 | Bose SoundDock® (Black) Docking Station...
My bose dock has power but no sound the remote dont work but it charges the ipod wot can be wrong
i spoke with bose tech support today because my docking system had no sound...everything else was fine, but no sound. they told me to take the battery pack off of the back, then reset my ipod by holding down the center button at the same time as the menu button for about 5 seconds (the apple icon will display), then reconnect the battery pack to the back of the dock and retry. it worked! good luck.
Jul 07, 2009 | Bose SoundDock® (Black) Docking Station...
I get a static ticking sound when plug in my sound dock
I noticed a ticking sound when I pushed the mains connecting plug into the Sounddock. It turned out the plug was upside down! It shouldn't be possible to insert it this way but it is.
Jun 27, 2009 | Bose SoundDock Digital Music System for...
Bose Ipod docking station not working!
Make sure the power supply is connected properly. If the power supply is connected upside down or sideways, the system will make a thumping noise, or will not play at all. However, no damage will be caused by connecting this wire incorrectly.
Mar 29, 2009 | Bose SoundDock digital music system...
No sound from Bose SoundDock
I had this problem on my SoundDock. My iPod would charge on the dock just fine and when I played my iPod on the dock, it would look like it was playing, but have no sound. Since my Bose was out of warranty, this is what I did to fix it. #1 Unplug the adapter. #2 Unscrew the four large screws on the bottom of the speaker and the three small screws under the dock. #3 You'll see one long ribbon connection and one very short one. Check to see if the ribbon connector coming from the front of the speaker system came loose from the green board. You'll only be able to see 1/2 an inch of it sticking out, and it's not easy to plug it back in, but it's possible. Just take your time. #4 Carefully put everything back together being very careful not to let the ribbon fall out of the plug again. #5 Make sure to plug in the DC adapter the correct way. There's a very subtle difference, but there is a difference. There are four prongs - two are square and two have slightly rounded corners. If it's not plugged in the correct way, the dock will have a static clicking sound. On my adapter, the words "DC power" are on the top of the plug.
Jan 14, 2009 | Bose SoundDock digital music system...
Bose SoundDock Digital Music System for Apple iPod - White Logo
14,505 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
