Question about Lightning Audio Bolt B2.150.2 Car Audio Amplifier
No start, no ligth indicate,,need electric diagram. can help,me? francisco javier davalos jaramillo. thank,s
How to reset maintenance indicator ligths of 2002 chevrolet venture
Your vehicle should have come with a reset key. You need to insert that into the keyhole to reset the maintenance indicator.
if you need a auto tool you can click here: great tools
Oct 27, 2012 | 2002 Chevrolet Venture Passanger
My battery ligth is on an car won't start
The battery light indicates the cars alternator is no longer suppling voltage to the car and charging the battery, so the battery has gone dead.
Sep 13, 2012 | Cars & Trucks
HI THERE, I'M FROM ACAPULCO, GUERRERO, MEXICO. MY DODGE CHARGER IT'S A 92 MODEL, V8, 5.9 LTS, AUTOMATIC T., EXCUSEME IF MY WRITING IT'S WRONG, I'M STILL LEARNIG.OK? WELL, I LOVE MY DODGE AND THE THING IS...
Amigo Francisco , si el computador es del mismo modelo del anterior , lo primero que debe cuidar es que la bateria este desconectada , los enchufes si estan en buen estado no entran en el lado incorrecto del computador pues tienen unas guias , suerte
mecanica03@hotmail.com , @mecanicasesoria
May 31, 2017 | 1987 Dodge Ramcharger
The brigth of the rigth head ligth is dimished
you mat have a shorted bulb try changing the bulb if that doesnt work you probably have a bad ground
Feb 06, 2010 | 2003 Suzuki Grand Vitara
Mant Req reset ligth
Hello, My name is JShreader. Thank You for choosing fixya.com.
There is 2 ways to do this on this year model...depending on the Month the vehicle was manufactured. 1 is using the Key Slot on the Cluster (on the earlier models). You can do this by inserting the ignition key into the slot located on the front of the instrument cluster lens. When reset, the indicator's colored tab will return to green.
The other way (on the later models) is to use the Reset Button on the Cluster. With the Ignition Switch 'OFF', press and hold the Reset Button. Now turn the Key to the 'ON' position (not starting) while continuing to hold the Reset Button. Hold the Reset Button down for more than 10 seconds. Your Maintenance Required Light should now go out.
I hope this helps you. If you have any more questions or need any more diagrams, please don't hesitate to ask...Thanks again, JShreader.
Mar 31, 2009 | 1999 Honda Accord
THE LIGTH INDICATOR IS ON ALWAYS, NO THE OVEN LIGTH. EVEN WHEN EVERY THING IS OFF AND COLD.
ifthe "hot surface" indicater light is on, its as ighn that the coresponding element is bad( actually only a safety switch within the sensor, but the entire element needs replacing).. hopefully on oyour unit there a 4 indicators one for each burner(helps to see which burner is bad)
Feb 23, 2009 | Magic Chef CER1115AA Electric Kitchen...
DI-524 WAN LIGTH
ensure that the electrical plug is intact, if you saw no led light lit at all on all indicator check the adaptor itself, if you have a tester you can try to test the end connector to see if there is a DC power line that is coming out.
if not either the adaptor is defective nor the reouter itself is burned out
Nov 27, 2008 | D-Link AirPlus DI-524 Wireless Router
Lightning Audio Bolt B2.150.2 Car Audio Amplifier Logo
43 people viewed this question
Top Lightning Audio Car Audio & Video Experts
80stech
Tygh Duval
Tygh Duval
Richard Lukszys
Richard Lukszys
Are you a Lightning Audio Car Audio and Video Expert? Answer questions, earn points and help others
