Question about RCA D52W15 TV
Please help When i turn the tv on, it turns on and off three times.I have sound and picture for about a second,it turns green with white lines and shuts off
  • 131 Answers
I suspect if you have green lines .you have a bad crt. there are three tubes red green and blue i suspect blue tube. tubes cost is around 300.00 to fix.
thanks doctor video
note sometimes you could adjust screen voltage located near the front grill black box . becareful high voltage ony a pro should do.
Posted on Jun 14, 2008
No picture, has sound. Black screen with green lines.
Probably a power supply issue in a 7-year-old TV
Feb 13, 2014 | Sharp LC Televison & Video
I posted a problem on how to remove panel but I solved it. Now as I mentioned the tv comes on goes green then black no picture just sound. I followed instructions on adjusting G screw but it doesnt work...
Its possible one of two thing have occurred, you have maladjusted the G screen control on the high voltage screens and focus assembly. Turn down (counterclockwise) all three of the screen drivers. Adjust each until a light appears in the each lens, red green and blue. Go slow or lines will appear if set too high. If all three lamps stay lit after this adjustment the look at your screen with color level down to zero using your remote and the picture menu. Adjust the three color drives to get a good black and white balance appearing on the screen. Now adjust the color level from the picture menu back up to normal range.
If you still get green diagonal lines after this adjustment then I would suspect that the green lens has a heater to cathode short in the tube.
Oct 12, 2017 | Televison & Video
Picture went out and red light on the front by power button is blinking. When I turn TV on I can hear sound but no picture,, then TV turns off automatically after a few seconds.
It seems problem with low screen voltage to three picture tubes in this rear projection tv.
If standby light blinks 5 times after three seconds long pause then adjust screen volts of each picture tube to solve this issue.
Screen volt adjustment requires expertise and job of professional so please call local tv repairman to help you.
Feb 27, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
My tv quit with no picture or sound and only a white line
It's more than likely that the white line is from left to right, is that the case?
Apr 16, 2010 | Proton MM2701VT 27" TV
The picture is green
your picture tube is wearing out . there is a way around it it will work for a while .you need to lower the drive for the green . on the board on the neck of the picture tube there are three adjustments marked red , blue, green on the front of the tv turn down the color all the way down . normally you would have a black in white picture but now you have a green and white find the screw adjustment marked green and carefully turn it down untill the picture is black in white and your fixed . adjust color back up .... dont do this repair unless you are confortable working around high voltages a wrong move inside a tv can kill you , this adjusment must be made with power on so you can see the picture as your going ... so this may not be for you . use your own judgement ........Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob .
Mar 26, 2009 | RCA Televison & Video
Sony KF-60WE610 Screen and Sound On/Off
All symptoms in your TV shows that you need to replace its Lamp as it has been consumed its life hours and TV requires new lamp. Lamp can be obtained from Sony Website. Price is $200, Hope this info will help you to enjoy your Sony TV in coming days.
Aug 17, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
Sudden color/picture distortion
you have a shorted green CRT that is affecting the other crts the short is internat to the crt that leaves what is called retrace lines. if the set is more than three years old then replace all three guns.
Feb 25, 2008 | Samsung TX-R3080WH 30" TV
Problem with picture and sound
A board (signal) bad ? or possible B board.....proof is by
substituion = can get expensive.................T.
Oct 13, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
RCA D52W15 TV Logo
82 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
