Question about Linksys DMA 2200 Media Center Extender (DMA2200)
I am using my media extender with windows 7, using an airport extreme to connect wirelessly to the network. so far everything has been working fine until it stopped during startup, with a message in the upper right and on the front of the dma22000 that says network is connected. after that, the unit doesn't respond to commands from the remote or the front panel. turning the unit off then on results in the same problem. any ideas?
    Problem Solver:
  • 5 Answers
This problem is affecting all US Linksys DMA units at present -- see this Fixya discussion for more information.
It should be fixed soon by Cisco without further invervention on your part.
Posted on Nov 08, 2010
  • 3 Answers
I have the same problem on two of mine. A 2200 and a 2100. It started yesterday (which means, 'all of mine').
Also, I've ruled out a cable problem because I have two seperate terminated ethernet ports (does it on both... and on wireless).
It is not happening on my non linksys extender.
Posted on Nov 06, 2010
My d-link DAP-1320 connects to my wireless airport extreme but not internet
REINSTALL THE DRIVERS AND SOFTWARE FOR DLINK. TRY A DIFFERENT TYPE OF USB WLAN.
Mar 14, 2014 | D-Link DAP-1320 Wireless Range Extender
My wireless network will only allow one device on the net at a time.
most like the modem is faulty as you can have any number of devices operating together
is it a wifi modem with ethernet
make sure that you add each device by going to the add devices in the control panel
Mar 09, 2017 | Apple AirPort Extreme Base Station
Not connecting wirelessly to mac
Thank you for contacting Fixya Support, I am glad to assist.
Depending on what type of Internet service you are using, your Intel iMac comes standard with an Airport Extreme wireless card built in. As a result, if you are unable to connect wirelessly to the Internet, you will need to try this:
- Click on the Apple menu icon, located in the upper left corner of your screen and select System Preferences from the drop down menu.
- Now locate Network from within System Preferences.
- In the side window, make sure you see Airport and check also to see that it is turned on. If it is, then check the left side window to see if the AirPort connection is active.
Keep in mind, your modem or connection router of course, has to be able to provide wireless connectivity, otherwise, if you do not, there will be no need to try connecting via your AirPort Extreme card.
If your network has been physically set as a wireless network, then just turning on the AirPort card in System Preferences>Network will start discovering all networks within its range, including your own network.
So whether you are using an Airport Extreme, Express or a 3rd party (non-Apple-branded) router, you should be able to connect wirelessly.
If you are still unable to connect with these basic steps, here are a few articles you will need to review from Apple Support informational database:
Requirements for wireless Internet access with AirPort
Airport & Bluetooth interference (for connectivity issues)
So here are some basic steps and resources you can try.
If you have more questions please feel free to post a comment.
I hope this information helps.
Regards,
-Mactechtrainer
Aug 29, 2010 | Apple iMac Z0CY Desktop
Attempting to connect new Acer netbook to existing Mac network
Had the same problem. What i did was in the Airport Configuration program goto "Airport" then to "Wireless" and then to "Wirelesee options" In this menu deselect "Use wide channels". Also i decreased the power of the 5.0 Ghz transmission, because i don't use it yet. But i think the "Wide channels" is the reason of the problem. It is a bit weird thoug, on my Airports Guest acount with no password and incryption, the Acer One loged on perfectly, but on my private network with WPA2 it did not. Aparantly the Guest network does not use "Wide Channels" Hope this helps, but take care, maybe the menu's are called differendly because i had to translate them from Dutch. Good luck.
Aug 11, 2009 | Apple AirPort Extreme Base Station
Wont connect to each other
connect the airport extreme to the voyager using a network cable... factory reset the extreme and then connect to it using the airport utility... you should get a setup screen where you can switch the extreme to "bridge mode" .. everything else should happen automatically.. you will then have 2 wireless networks?
May 03, 2009 | Apple AirPort Extreme Base Station...
MX310 - Wireless network printer used on an Apple Airport Extreme
Here's what worked for me: I had everything set with my wireless network which included an Airport Extreme base station and two Airport Express units to extend range. I still couldn't plug and play with my printer. 1. You have to plug your printer into the Airport Express, turn it on, then select a document to print from your computer. 2. Select print from the pulldown menu (or select 'command P' on the keyboard). 3. When the print dialog window appears, go to the "Printer:" selection bar near the top of the window and select "print & fax preferences..." 4. This opens a new window, "print & fax." Near the bottom left of this window just below an icon list of your printers are a "+" button and a "-" button right next to each other. 5. Click "+". Yet another window opens which will reveal a list with your printer on it. 6. If you don't see your printer, click the "default" icon in the top left hand corner of the new window. 7. Select your printer, then click "add" on the bottom right hand corner of the window. The window will close automatically and return you to the "print & fax" window. 8. You should now see your printer in the list. You may say, "My printer was already in the list," but that's not good enough. The process you just went through enabled the computer to detect it on your network. You may want to use the "-" button to remove any previously listed printers from the list in the "print & fax" window. 9. Now you should be able to close the "print & fax" window and get some wireless printing done.
Mar 19, 2009 | Canon PIXMA MX310 All-In-One Printer
Airport extreme / Windows XP with VPN problem
have you reset the airport extreme? theres a tiny hole you can push in w a paperclip. Also, do you have the latest firmware?
Mar 10, 2009 | Apple AirPort Extreme Router
Apple extreme bridged to apple extreme (Windows network)
OK, do you have the latest version of Apple's Airport Utility: Version 5.4.1 (541.9) ?
If you don't, get it... it's got an excellent interface that will walk you through bridging two wireless routers together.
Once you get your hands on it, you will need to choose which airport will be the primary and which will be the secondary. Ideally, pick the one connected to the highest speed and most reliable internet access.
Connect to the secondary airport and configure it as bridge to the primary, the Airport Utility will walk you through it step by step.
Jan 13, 2009 | Apple AirPort Extreme Base Station...
Macbook Pro airport extreme
You should only use Windows xp for running a program that is not yet available from Apple. There shouldn't be much reason to link to the net while in Windows. Also while in Windows you are wide open to any viruses that exist. Try getting your work done without getting on the net, then go back to your Apple format. There you are 99% free of viruses. … Still need to link onto the net let me know I will ask at our Apple Computer Club on Monday
Dale
May 10, 2008 | Apple MacBook Pro Laptop Computer with...
Linksys DMA 2200 Media Center Extender (DMA2200) Logo
236 people viewed this question
Top Linksys Televison & Video Experts
Electro Med Services...
Are you a Linksys Televison and Video Expert? Answer questions, earn points and help others
