FM receiver not working - Audio Players & Recorders
  • 2 more comments
  • Anonymous Dec 12, 2008
    My fm tunner barly picks up any stations
  • allenhiland Apr 03, 2009
    have technics sa 300 reciver fm works but dont pick up stations,just staic
  • Colin L.Swan May 11, 2010
    Much more info. needed
    Need a bit more info. re just what is happening or not happening when you plug in and switch on mains
Problem solved.
I appreciate you prompt response
Thank you.
Posted on Jun 16, 2008
2003 grand marquis radio am does not work
Does anyone broadcast AM radio any more?
If you know you have a good AM station in your area, and you can verify its frequency, and your radio can't receive it but CAN receive FM stations... then that radio just isn't going to get AM. It's probably not worth fixing.
Aug 07, 2014 | Sony CDX-GT320 FM / AM / XM Radio / Sirius...
No FM in vintage technics receiver
Connect a long wire/antenna wire to the respected fm antenna screw on the back of the receiver.
Mar 11, 2014 | Panasonic Vintage Technics Stereo Sa-500...
Fm radio works fine but the dab will not find any stations, I have tried different aerials and still no good
What's the make & model of the radio?
Most DAB/FM radios work from the same antenna, so if you receive FM stations, you should receive DAB stations in your area.
It should be noted that DAB transmitters work on lower power than conventional FM transmitters, and so you may be in a weak reception area (for DAB). It should also be noted that DAB uses different frequencies than regular FM stations and household appliances such as laptops,WiFi, microwave ovens, etc can affect DAb reception.
Nov 18, 2013 | Audio Players & Recorders
FM radio does not work on receiver
Unfortunatly it sounds like the FM tuner pack is faulty and only replacement can cure it.
Jan 12, 2013 | Car Audio & Video
Str-de985 humming noise only when using FM tuner. Everything else works fine with no humming noise
Have you got a FM Antena hook up to it for the FM ,Sations, If not that could be causeing it to hum.
Dec 06, 2012 | Sony STR-DE985 Receiver
FM antenna is not providing reception, despite cable connected to powered antenna amplifier. TV also connected to powered antenna amplifier (splitter) works fine. FM mode produces only static. I purchased...
If I understand your setup, you've connected the receiver antenna terminal to the output of the antenna amplifier. If this is true, I'd suggest trying the receiver using a plain old FM dipole antenna (available at Radio Shack and other stores) or even just a piece of wire hooked to the antenna terminal. You should be able to pick up some local FM stations then.
What might be happening is that the FM is being filtered out by the amplifier. Some amps made mainly as a TV signal booster have an FM trap designed to block the FM broadcast band. In the analog broadcast days, the FM band was right near the sound part of a TV signal, and the trap was there to prevent interference. It may be filtering out your FM band.It may also be possible that you're just overloading the FM antenna input with the amplified signal. Sometimes a signal can be too strong. Using a simple wire antenna will let you test the receiver by itself.
Other than connecting an antenna you shouldn't have to do any setup for FM reception. If you still get no stations at all when using a simple antenna, then the receiver may need service. But I doubt Circuit City would have sold a floor model that was defective, even at the very end, unless it was clearly marked as such and sold "as-is". I'm pretty sure you'll find that the receiver works with an antenna made for FM.
Sep 14, 2011 | Denon DRA-37
I receive only one FM station and it is very close. AM stations come in OK Naxa xn680
go to radio shack and have them show the assortment of fm antennas that work in your area.
Feb 27, 2010 | Naxa Electronics Naxa Stereo AM/FM.MPX...
Radio reception
Say goodbye to this unit if FM matters to you
Mar 11, 2009 | Kenwood DPX-440
No Signal After Reconnecting Roady2
Try playing the Roady 2 through a fm radio with the audio jack(middle connection) disconnected and the FM Frequency & Fm Radio set to the same station. At least this will tell if the receiver is working. I suspect that you got an aftermarket audiojack for your stereo. Might want to check that. Go back to the manual FM Modulation setup instructions. Any FM receiver will work. Good Luck
Oct 21, 2007 | Delphi Roady2 SA10085 XM Radio Receiver...
41 people viewed this question
 Grubhead
Grubhead
