After power outage, unit apparently needs to be reset. I can't figure out how.
  • gklauminzer Nov 08, 2010
    This is a Cadet wall heater, model RM 162. After a power failure (and return of power), it has not worked. It has a reset button, but I can't make it work. I need a diagram and clear instructions. Can you help?
    Genius:
  • 1,035 Answers
Hi. May i know the brand and model of your Air conditioner?
Posted on Nov 05, 2010
My unit wont get cold, had power outage and think it needs to be reset. How do u reset compressor or unit?
See this video for the "reset" function of some refrigerators:
Easy Refrigerator Fix Reset Defrost Timer Switch if it stops running...
Does My Refrigerator Have Reset Button
How Do Reset My Frigidaire Refrigerator
Said this, I don't mean to "panic" you but if you can't find this "restet" function, your refrigerator suffered a surge effect and might have some electronic cricuir damaged; in best case, some internal security fuse, typical as result of power outage, when power returns.
If you can't find that "reset" call repair service.
By the way, get a surge protector for your refrigerator as soon as possible. See some typica protectors at Amazon, but you can buy one at your local home depot or outlet store.
1800 Watts Refrigerator Surge Protector
Sep 01, 2015 | Refrigerators
Power interruption and now my plug,n go seems to be frozen. Cannot set time or clear anything. Screen reads 9.80 or something close
I had a similar problem with my Bosch wall oven after a recent power outage-restart-outage-restart cycle that lasted only about thirty seconds altogether. The difference would be in that while I could reset all the things like day, date, time, etc., the oven would arbitrarily go off on its own and make up the day, time, date, year, etc., with no apparent correspondance to reality. Here's what I did: I completely shut down the oven at its outside breaker (you will need to do whatever it takes to remove the power from the 'plug-n-go'). I waited five or ten minutes before turning the power back on and resetting the various items. Two days have passed and there have been no more mind-of-its-own excursions into another time zone. Problem solved, unless/until another power outage cycle comes along. Hope this helps, or at least gives you an idea about where to start.
Dec 15, 2014 | Hardware & Accessories
I have a GE model JGBP335 gas oven. Since power outage about 3 wks ago it flashes "unlock door" when you try to preheat oven. The oven will not come on at all. We have tried unlocking and locking door...
I would suggest set unit in self clean then cancel, this should rotate the lock and reset the lock position for you, apparently the unit was in a cycle when the power issue accrued and is unable to reset on its own. Try this and see if this corrects this issue for you.
Good Luck
Dec 06, 2013 | Ovens
Wall scoreboard clock model #0028 not working after outlet blew
Remove several screws around perimeter of clock. Open up clock and find small (quarter -sized) battery. Remove this battery - it may be hot glued in place but you need to remove this. You don't have to replace it just remove it. Apparently this battery is used when you have a power outage to retain date / time, but when it goes dead it won't allow the clock to operate. So just remove it and put the clock back together and all should be fine except you will have to reset the date etcetera when you have a power outage.
Jun 09, 2013 | Computers & Internet
Had a power outage does not turn on is there a reset
Hello - I understand the unit has previously experienced a power outage, however have you try unplugging the unit or flipping the household breaker off? Wait approximately ten minutes; is there power to the unit? I suggest touching each button individually on keypad, do any lights turn on or does the display change? If any proves to be ineffective, I would recommend contacting a professional to move forward accurately because it can possibly have a defective keypad.
Nov 04, 2012 | Frigidaire 24 in. PLD2850 Built-in...
Plantronics cs50 red power light is not lit
Sorry to hear about your bad luck there. If a hard reset does not work and its not simply the power button is not correctly aligned (try fiddling the pressure up and down if it is loose) then it's likely the device has failed. Even though it's survived other power outages it's still entirely possible the most recent one has caused this failure. I've seen failure of electronics from operating on unstable voltages from solar panels and less than perfect inverter systems and it's always the case that "it's been working fine up until now!"
Mar 01, 2017 | Plantronics Radio Communications
Power outage need to reset - blinks "CL"
remove the power adapter and remove the battery from the handset. Now replace the battery and power the base unit , place the handset on the base and select intercom or search remote.
The base unit must automatically set the frequency to mesh with the handset and handshake to connect.
Sep 19, 2011 | GE 25932 Cordless Phone
After a power outage, my wall a/c unit will not power on. We have checked the breakers and reset button. The unit blinks the temp that it was set on when the outage occurred, but will not operate.
Possible that the processor has hung and so you need to remove power for some time to help it reset. If this wont solve then remove the program controller unit and check the +5 on the processor. Check the circuits and see if there is any fault on the power supply .
Jul 16, 2011 | Frigidaire FAH106N1 Wall/Window Air...
Cannot unlock ratings on my Panasonic DMR-ES20!
Apparently it is caused by power outages.
Here's the fix: Put in DVD mode.
• While the disc tray is open, press and hold [* REC] and [PLAY/x1.3] on the main unit at the same time for 5 or more seconds. Press until you see INIT on front screen of unit.
Oct 19, 2008 | Panasonic DMR-ES10S DVD Recorder
Reset after power outage
You just need to reset the time to fix this problem. There were three buttons on the back of the base for the day, hour, and minutes. I didn't know they were there!
Sep 07, 2008 | Uniden Cordless Phone
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
