My old Sony Trinitron TV model KV M1621U still can give a good picture but it doesn't have a SCART connection. I had it working with a digibox for a number of years but when that failed I bought a Euroline DTR (DVT 3600). Unfortunately I can't seem to be able to get it to connect through the aerial in the usual manner. The TV doesn't seem to want to know the new digibox. I have mislaid my Sony manual and I do not know how to tune it manually. Does anyone have any (polite) suggestions?
techman
  • 3130 Answers
SOURCE: Sony TV - Loss of half the picture
sarge, it sounds like the vertical output IC went bad on you. If it was a bad connection or a bad capacitor, your picture would have been a straght line across the screen. They call the output section of the IC a push-pull type of amp, so the top half of the sweep IC went out. If you have had some soldering experience, and or experience with solid state repair, locating the bad IC and replacing it is no big deal. If you havent, stay safe and call in a pro to assist you in this repair, as there is alot of high voltage inside this puppy that is still present even if the set is unplugged. It should not cost an arm or a leg to repair this set. An honest repair on a set like this if you take it in should not exced 125 to 150 bucks. Good Luck PS Please dont forget to rate this thread.
Posted on Oct 22, 2006
  • 22 Answers
SOURCE: Can't access AV Channel on Sony KV-C27TD
If the TV has no RCA inputs, then there is no "AV channel" option for it on any remote, just channel selection.
The purpose of a RCA to SCART converter (aka RF modulator) is to convert one of your channels to an A/V input. They operate (standard) on either channel 3 or 4 as selected by a switch on the converter.
If your converter is unpowered, it's entirely possible that the signal coming out is not good enough to overpower your antenna signal. In this case, you may need a powered unit (such as this one http://www.bestbuy.com/site/olspage.jsp?skuId=5806345&productCategoryId=abcat0107025&type=product&tab=7&id=1067388827858#productdetail) which can actively "shut off" the antenna input when signal is received from the auxiliary device.
Posted on Nov 13, 2007
SOURCE: sony trinitron kv-x2982u - how do I tune a channel in?
my sony trinitron wont turn on, its just come back from the repair shop and they had it up and running for 2 weeks. it came on breifly then went back to not turmnning on useing to remote.
Posted on Feb 09, 2009
SOURCE: Sony TV Trinitron is on standby
standby light flashes tv wont turn on
Posted on Jun 01, 2009
SOURCE: RC codes for ge-24914-d to control sony Trinitron TV KV-27S42.
the codes for sony are 0128, 0013, 0002, 0071, 0380, or 0152
1) Make sure the tv is on.
2) Press and hold the set up button till the red light on the left hand corner stays on.
3) Then press tv then release quickly so that the red light flashes once. (its pretty quick so pay attention).
4) Then enter one of the four digit codes and the red light will turn off.
5) Then press channel up.
If it goes up u have the right code. If not start from the begining (holding the setup button down) and do the same steps for each of the codes, one of them should work if not u have to do a code search. Follow steps #1, 2, 3, and 5 but on step 5 press it repeatedly (for up to 300 times and it says that on the instruction manual) until the device can be controled. The red light blinks then stays lit
6) press and release mute to install the code. The light will go off.
Posted on Aug 21, 2009
I have a tv sony trinitron model KV-32FX68E 32''.
try to plug the tv to other socket that is working before suspecting the tv set
Jul 18, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have a Sony Trinitron model kv-a2921b. The TV
HELLO MIKE
I don't think your TV is totalled! It's more than possible that a speaker connection on the main board has come adrift and just needs pushing back in. Check connections on the speakers themselves and when you trace back the cables there will one or two push in connectors.
It may be a good idea to get the speaker connection plugs checked and resoldered. It is also possible that the fall could have jolted the audio IC and this should be checked for dry joints or cracked print on the board too.
Hope this helps (:-)
Oct 03, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Green screen and distorted picture sound is good but no picture
It must be connected with the color circuit of your tv, a board connected to back end of the tube. Could be dust, cob web or carbon deposit shorting a transistor. Popping noise if loud enough can be attributed to high voltage circuit fault and picture tube.
Have it service by a qualified person.
Apr 04, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
No colour when digital set top box attached
Ensure the set top box is set to the correct video out. Probably RGB if scart lead or CVBS if coax lead.
Jun 10, 2017 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Have a 32 sony trinitron
Can you give me a model of the TV. It will be KV32?????
Nov 29, 2007 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony Trinitron KV-1670 TV
please visit www.serviceinfo.com after site is open go to search and give model no Sony Trinitron KV-1670 TV. you will get the map. good luck
Sep 20, 2007 | Televison & Video
Digibox connection
Try looking on the links from a thread on connecting a PVR on bbc.co.uk's POV digital pages
Sep 17, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Televison & Video Logo
139 people viewed this question
Top Televison & Video Experts
